Since I had the plate installed in my left forearm, and the Dr. told me on the 17th of Dec. to start doing a few things with that arm, i have stripped all of the wiring/tinwork off of my engine and cleaned it all up. It is slow progress, but at least it is progress !! I didnt get a pic of the engine tonight, but as of now it has the cooling fan and most of the tinwork back on it !! IF I get the pieces that I have ordered from the bird and 914rubber, then this thing may go back in this weekend, and may actuallu run next weekend !!!!
Before ......
After ........
I doubt installing an engine is what the Dr. was thinking when he said "a few things".
Looks nice.
Good luck!
It's great to have a little helper. It also instils an interest in cars.
What did u use part wise... stock or larger pistons, carbs or fi, ect and more Picts r always nice.
Dave
Nice project! Looks good.
John
I'm with John, Nice Work.
You didn't take the engine apart? Unbelievable ...........
Did you use a Magic Eraser .............. ??
That looks splendid. Very clean work!
Wow what a difference. That is just unbelievable. Nice work - keep it going.
The engine was not taken apart other than the rocker arm covers and push rod tubes. We spent about 2 hours with some degreaser and a steam cleaner ... not just a hot water washer, but an actual steamer. It got the crud off and the case was discolored and stained so I shot it with DupliColor Aluminum engine paint. It has really turned out looking better than I was expecting it to !! This one didnt get torn apart because it is going in the project as a test mule until I get enough time and $$$$ to rebuild the 2.0 that is in my parts car. This one is just a 1.7.... and I have had it running after I stripped the car down !! If it lasts, fine ... If it doesnt, then that will be more reason to get the 2.0 built !!! Thanks for the compliments and more pics will follow ......
Engine as of last night !!! It now has all of the intake/injection system on it. Just need fuel lines, vacuum lines, and the front engine mount bar and it is ready to go in !!!!
It's been too long David. Set your sights on the Route 66 event and getter done! Bring your young helper with.
Wasn't that the engine they found buried with King Tut?
Very clean engine & tranny - nice work!
The finish line is now in sight and motivation becomes easier to find. Your first drive is right around the corner.
Keep rollin!
I keep plugging away at this, and keep finding little speed bumps !! Luckily there havent been any road blocks yet !!!! I had my goal set of stabbing this a few days ago, but have been going through the 73 1.7L vacuum hose hell, but slowly figuring it out. Then, I found a broken motor mount, and should have a new mount and new throttle and speedo cables here on Friday !! HOPEFULLY ..... it will go back in this weekend and run if everything goes better !!! This pic was as of a couple of hours ago ....
Nice work!
John
Engine is FINALLY stabbed back in the hole !! Now I get to sort through all of the wiring nightmare and hopefully fire it up tomorrow !!!
