Just got the pic from my brother in GA.
did you just drill a hole to mount an amp?
Rich
Is that gas from the fuel tank?
or water from the radiator?
Yes it is
Gonna need another cup or two.
Expensive amp installation.
3 gallons last time I spoke to him
not that I know, but remove the tank strap, pull up on the tank, really hard.
pull up on passenger side.
A tank can be removed in less than 30 seconds....
Thank-you, I am sure a lot of us are feeling slightly less dumb with regard to the worst eff-up we have ever committed while working on our cars.
Well at least I am.
Tell ya"ll story 'bout a man named Jeb........
Workin on his Teener tryin to keep his family fed.....
Then one day .....while workin near the wheel....
Bubblin out the front and feeling like a heel.....
Sorry guys couldn't resist....lest I doom myself to do the same. Thanks for sharing the misfortune so I don't.... or less likely to.
OMFG, thanks for sharing.
a long, long time ago, in a past lifetime, i made the same mistake...
i woke up my room-mate and dear friend to hold his finger over the leak, dutch boy style while i crawled beneath to drain the fuel.
can't blame that one on some dumb p.o.!
Nice reminder for people!
If you laughed at this then maybe you won't forget it later.
John
Actually I see tons of stuff like this from stereo shops. It never amazes me what they drill through.
fast syphon needed.
though i can not believe the tank is that close to the floor board that it would flow thru itself and thru the floor board so completely. hum
Hopefully he pulled the car out of the garage. It's bad enough to torch a car. Hate to see the house or garage go with it.
A while back I watched one of those "cops" shows where the fire department and police were called to a house on fire. The distraught friend was explaining that he was fixing his car in his friend's garage messing with the gas tank and it ignited. Very scary to think about.
Hope he gets it resolved peacefully.
OK, I was stupid once too. I had the car parked outside in a make shift car port and thought it was a good idea to put some rolled roofing under to keep moisture from coming up... I had a fuel leak. that turned the roofing into a gooey mess and a extreme fire hazard connected to my house. I had to build a 1800 sq.ft. shop to fix it.
It is good to see he grabbed a cup before taking the time to take the photo.
That's a strong stream to be coming out of the tank and hitting the fire wall hole just right.
on 2nd thought don't light that.
I drilled into a brake line on my old Corrado once ! I cried !
Measure twice cut once they say !
I was changing a fuel pump on my Rabbit (outside in the rain) and I put a towel on the ground so I wasnt laying down on wet concrete. The towel got some fuel on it and when messing with the pump, tightening it down the tool arc'd against the power wire for the pump and the towel caught on fire. I dragged it out into the rain and watched it burn. The HOA wasnt too happy with me lol
Thanks Scotty , I will take you on that offer.
