Any ideas what might be up here? Obviously the cable is turning. Is there a little plastic gear inside the guage that connects the two that could be broken?
Thanks
John
Yup, it's a gear on a shaft that is no longer spinning the shaft.
The fix is to open the gauge and re pinch the gear onto the shaft.
I believe there is a detailed tech article on pelican parts that describes the repair process with pictures
http://www.pelicanparts.com/techarticles/Mult_gauge_repair/mult_gauge_repair.htm
Thanks but that really looks like a pain in the ass.
Probably much easier to swap out the entire guage or just ignore it.
Nah, it's a quiet evening.
The hardest part is opening the gauge.
Once you do that, you can get in there with a small set of needle nose pliers and crush the shoulder...it think I used pliers and small (really small) wire cutters and crushed the shoulder tight.....worked fine.
Use an assortment of screw drivers to peal back the lip of the gauge face.
You will never see that part of the gauge.
Put the gauge on a towel to keep from scratching it.
It's an evening in front of the TV, work on a cookie sheet...
there is a plastic gear inside off the speedo that works the odometer. . my experience is it starts slipping on the shaft. . not a hard fix to do but you have to pull the case off the speedo assemble. . 2 screws in the rear after you pry off the bezel. . . .
or like you said ignore it or buy a different speedo [ and guess how long that one will last] as this is a common issue. .
I did not take anything apart from what I recall...
Once I saw it, I just got in there with the tools and crushed the shoulder till it stopped spinning...
Keep track of the mileage before you start....it get moved around while you do the work....then you can reset it to the right mileage..there is a stopper in there, but you can see how it works when you are looking at it.
I repaired a few by injecting some locktite with a syringe on this gear
John, dude....seriously...
Send you gauges to Tim and have him add the LED lights for you....and fix that gear.
You will love the gauges.
I agree
Send it to Tim. The pelican article is not precise . I broke my first gauge before figuring it out.
It's a bit confusing.
um, ...
Hey, I did find the wiring harness a couple of weeks ago
I have to say sending my gauges to Tim was the best thing I ever did! He fixed my odometer, changed out the crappy plastic lenses, repainted the needles, and installed the LED lights. Could I have figured out the odometer repair? Sure with lots of time and effort. Tim did so much more than I ever could have in a very short amount of time. I am cheap and it was hard to shell out the bucks but man it is worth the investment.
I know its a bit off topic, but what causes the speedometer neddle to bounce? Mine starts at about 60 mph and bounces like crazy till 90 mph.
BTW thanks for the info on the odometer I have been meaning to do that for some time.
Often, it's a speedo cable that is starting to die.
--DD
Look for this pot metal gear.
This is the one that was loose on both of the ones I fixed.
The picture you posted is the plastic gear...not the pot metal one that spins on the shaft all by itself, if it's loose.
Here's another take on the odometer repair thing, from back in the 90s...
https://web.archive.org/web/19970606030646/http://www.estinc.com/porsche/speedo.html
--DD
This is the gear
