Well I had been very happy about the water tightness of my car after replacing so many of the seals. But tonight it was hammering rain and I felt a drip on my leg. It was coming from somewhere around the front trunk latch pull.
The only thing I could think of is the seal around the windshield.
Any thoughts on what to check? I think I am pulling off the windshield chrome.
Do you have an antenna on the drivers side? Could be leaking from the hole in the fender where the antenna cable goes inside the trunk.
Also check where the two evap hoses enter the trunk.
All of these enter from the inner fender well right above where the trunk latch mechanism is located.
The water can splash up in the wheel well and hit the underside of the antennae and the antennae wire and then travel on the wire and through the grommet if it is not sealed well. It will then drip onto your leg inside the car.
I'd squirt a hose only on the trunk seal, not the windshield. . flood it exactly as it was when it was pouring. . Open hood and look above drives pedal area where you felt the drip. . if you don't visually see anything, wipe it with a Kleenex. . which will pick up any trace water amount.
Are your drains on the air vent opening connected and not plugged up?
If it's leaking at the windshield glass, it would have to overcome the height of the inside sealing lip. . or have found a rust hole. .
Did you take your prostrate medication today?
Wow I must be posing my mind. I thought I posted an update, but that was a couple of beers ago!. I will try again.
The winner is a leaking windshield.
Found that the windshield was not attached to the adhesive in the corner where I saw the leak. A little pushing and probing showed that the chrome trim was all that was really holding the windshield in. Except for that one spot that caused the windshield to crack all the way down.
But it provides great access for changing the dash vinyl!
