Background:
For the stock D-Jet, the ECU gets the signal to fire the injectors from a set of mechanical breaker points inside the base of the distributor. There is nothing wrong with the factory method except for the fact that if you want to run the D-Jet injection, you have to keep the factory distributor...not anymore
I have successfully been able to electronicly trigger the ECU from a pair of optical sensors inside of the billet Mallory distributor....so far I have only put a few miles onto the car with this setup and I don't know how it'll work when the temperature is much higher (currently it is 45° outside.....)
it's ugly right now, but give me some time to clean it up...
So for my ignition, I have the Mallory distributor, accel coil and new 8.5mm plug wires....starts right up and idles fine, but I might install a CDI box anyways...
i love it..dont need it but i love it anyways!
Will this be a kit, or will you be selling the dizzy with the sensors installed?
I really hate the limitation of the sotck dizzy, and the age or it makes it less than accurate.
Tell us the price!!!
VERY nice job mueller -- this idea was a long time coming. Hope the field testing works out well -- this would be a nice contribution to the longevity of Djet!
schweet dude!
PS: i still have your specially calibrated MPS here in my parts box.
PPS: you still have my roller bearings!
maybe we should hook up for lunch and exchange goodies ...
Andy
Is that ......
JB WELD!!!!!!!!!
no, that is not JB Weld
it's a 3M brand potting epoxy for electronics....
QUOTE |
Will this be a kit, or will you be selling the dizzy with the sensors installed? I really hate the limitation of the sotck dizzy, and the age or it makes it less than accurate. Tell us the price!!! |
Whew, I feel so much better.
Make one that fits in the stock distributor and includes your own electronic points and sell it for less than Pertronix + Trigger points. Should be easy at $150+ to replace both those items. I know I'd recommend it to anyone who is replacing points with a Pertronix. I can't imagine that the electronic points could be that hard to replicate.
Nice work there Mueller! Keep us posted how it run's out. What's on the shaft that triggers the sensor's. Did you build somthing in the rotor? And the pickup's what are they? Do they hook up directly to the FI harness and have there own fast acting gate switch or do they connect to a board you made then to the FI / ECU ?
I hope you don't go Colonel Saunders on us and keep the secret reciepy
QUOTE (McMark @ Jan 23 2005, 12:53 AM) |
Make one that fits in the stock distributor and includes your own electronic points and sell it for less than Pertronix + Trigger points. Should be easy at $150+ to replace both those items. I know I'd recommend it to anyone who is replacing points with a Pertronix. I can't imagine that the electronic points could be that hard to replicate. |
QUOTE (DJsRepS @ Jan 23 2005, 08:14 AM) |
Nice work there Mueller! Keep us posted how it run's out. What's on the shaft that triggers the sensor's. Did you build somthing in the rotor? And the pickup's what are they? Do they hook up directly to the FI harness and have there own fast acting gate switch or do they connect to a board you made then to the FI / ECU ? |
QUOTE (Mueller @ Jan 23 2005, 08:58 AM) |
the coil is no longer even and the windings freak out releasing the energy within producing spark......sorry for the simple simon description, LOL |
Good job mike!
Mike,
What timing relationship did you keep between the "ignition points" and the the "trigger" signal??
With your setup can that relationship be varied??
Ken
QUOTE (KenH @ Jan 23 2005, 02:54 PM) |
Mike, What timing relationship did you keep between the "ignition points" and the the "trigger" signal?? With your setup can that relationship be varied?? Ken |
I was just looking at the stock trigger points....the timing relationship on those do change with wear of the phenolic blocks....
Some time ago - sombody indicated there was an optimum relationship, depending on driving conditions. I will try and find the info.
Another way to do it might be to "trigger" an IC "divide by 2" off the points and feed that to the ECU. Hummm
Ken
QUOTE (KenH @ Jan 24 2005, 08:46 AM) |
Some time ago - sombody indicated there was an optimum relationship, depending on driving conditions. I will try and find the info. Another way to do it might be to "trigger" an IC "divide by 2" off the points and feed that to the ECU. Hummm Ken |
Very cool Mike
QUOTE |
You say mickey mouse engineering.. are those optical sensors out of an old fashioned ball-type mouse?
QUOTE (bondo @ Jan 24 2005, 11:39 AM) |
You say mickey mouse engineering.. are those optical sensors out of an old fashioned ball-type mouse? |
You're a creative guy Mike, but is this a solution without a problem? Stock dizzys work fine, replacements are available...
So why the need for this other than its new?
QUOTE (bowlsby @ Jan 24 2005, 01:29 PM) |
You're a creative guy Mike, but is this a solution without a problem? Stock dizzys work fine, replacements are available... So why the need for this other than its new? |
I wouldn't call it mickey mouse engineering! Pfrototypes always look questionable! Good work!
Hey Mike, How about a cheap LSD or a way to modify the 915 or G50 ones to fit in our transaxle. That would be cool!
Mike, I'm lurking in the background awaiting final setup. This sounds great. I run two '73's with D-jet. Love to see this work. Our SCCA rules allow for any distributor, but don't mess with the fuel injection or your up a class or three!
Keep us posted.
Gary
nice job mueller!
(Mickey Mouse EngineeringWerks Rock!)
GARY,
Call Paul - you can buy replacment gears with the "coarse spline" that will convert a 915 LSD. He cloned a ZF and has all the internals - disks & spacers.
http://www.guardtransmission.com/lsd_info.htm
Ken
Opps it was Rick who wanted the LSD info.
Ken
