Printable Version of Topic
914World.com _ 914World Garage _ Speedo cable
Posted by: jeffdon Aug 23 2014, 02:53 PM
Here is a pic of my new speedo cable. This is the tranny end. The boot appears to be on the wrong way. Got this from the bird. Any one else have this issue? I am starting to loose faith in these guys.
Posted by: Dr Evil Aug 23 2014, 03:19 PM
How is that on the wrong way? It is supposed to slide over the collar that you screw onto the speedo drive
Posted by: mepstein Aug 23 2014, 03:33 PM
its correct. you'll see when you install.
Posted by: jeffdon Aug 23 2014, 03:40 PM
QUOTE(mepstein @ Aug 23 2014, 02:33 PM)
How can it be right? I tried inverting the boot while on the cable, and it looks nothing like the one I just cut off my car. I am pretty sure this got put on wrong at the factory. I see no way of getting it off and re-installing the other way.
Posted by: Dr Evil Aug 23 2014, 03:48 PM
Jeff, I am not following you. You dont take it off. You screw the collar onto the speedo drive and then slide the rubber cuff over the collar. That pic you have is correct. I have no idea what you had, but the pic is correct.
Posted by: JawjaPorsche Aug 23 2014, 04:30 PM
QUOTE(Dr Evil @ Aug 23 2014, 05:48 PM)
Posted by: jeffdon Aug 23 2014, 06:25 PM
QUOTE(Dr Evil @ Aug 23 2014, 02:48 PM)
Isn't this a boot that is to go over the tube in the fire wall?
Posted by: mepstein Aug 23 2014, 06:44 PM
QUOTE(jeffdon @ Aug 23 2014, 08:25 PM)
No. Read above.
Posted by: jeffdon Aug 23 2014, 08:05 PM
QUOTE(mepstein @ Aug 23 2014, 05:44 PM)
No. Read above.
Ok, the cable has two boots. On that fits snugly over the end that screws to the speedo. The one in the picture fits well over the angle drive connection, but there is no boot for the tube where the cable goes into the tube in the firewall. That would need to be on the cable already, right?
Posted by: bluhun Aug 24 2014, 01:51 AM
QUOTE(jeffdon @ Aug 23 2014, 07:05 PM)
No. Read above.
I have the same issue. The problem is that the boots on the cable were installed incorrectly at the factory, i.e., the boot that should seal at the firewall is down at the speedo angle drive end and the boot that is supposed to slip over the angle drive is at the end that goes through the firewall. At least that is the problem with my cable.
Posted by: bluhun Aug 24 2014, 02:05 AM
No. Read above.
The cable is supposed to have two boots, one for the speedometer angle drive, which you have, and another for the speedometer end. It appears that you only have the boot that fits over the speedo angle drive. My cable has both boots but they were put on backwards at the factory. It appears that there's a serious quality control issue at the factory.
Posted by: bluhun Aug 24 2014, 02:20 AM
No. Read above.
My observation directly above regarding your cable is incorrect. What you have is the boot that fits over the tube at the firewall, fitted backwards on the cable. What you appear to be missing is the smaller boot that seals at the speedometer angle drive. Sorry for the confusion.
Posted by: jeffdon Aug 24 2014, 06:41 AM
QUOTE(bluhun @ Aug 24 2014, 01:20 AM)
No. Read above.
Thats what I thought. So there should be a total of three boots, right?
Posted by: bluhun Aug 24 2014, 09:14 PM
QUOTE(jeffdon @ Aug 24 2014, 05:41 AM)
No. Read above.
No, just two boots. The smaller one fits over the speedo angle drive and the large one (the one in your picture) fits at the firewall.
Posted by: Dr Evil Aug 25 2014, 08:37 AM
Here is the official pic from the PET. The lower part is the part that attaches to the transmission. Upper attaches either to the gauge or the angle drive depending on year.
Posted by: Dr Evil Sep 5 2014, 06:50 AM
OK, I just replaced my speedo cable with a new Gemo one and now understand the issue that prompted the start of this thread.
See the pics. The old and the new are different. The boot on the firewall end is too small on the new one, and the collar on the gauge end is not captive like on the OE one. Makes for a bit of fun. Best way to install is to put tape on the gauge end just behind the collar to keep the collar from sliding back.
Posted by: eyesright Sep 5 2014, 08:36 AM
I have bought two cables for two cars in the past two years and both are wrong. I wasn't smart enough to send them back and complain...figured I just didn't understand these things yet... ...but they're on now and driving. Grrrr. I should have posted here and learned something. The next one will be returned to the supplier.
Thanks guys.
Posted by: Dr Evil Sep 5 2014, 09:15 AM
I bet if we get Glenns attention to this thread he may be able to enact a change I dont remember his screen name.
Posted by: Jacco Sep 5 2014, 02:06 PM
Had the same experiece with the speedo cable.
Asked the question about the rubber boots to a couple of european resellers with pictures as above, comes down to this: factory claims they are exactly according to factory drawing. I decided to heat the rubber in hot water and carefully removed it to place it back correctly.
Jacco
Posted by: rgalla9146 Sep 5 2014, 07:56 PM
I don't know about the bulkhead boot.
I do know that the angle drive boot on any replacement cable that I've seen in twenty years has been wrong.
I'm lucky, I have one real original.
Now I have to check the bulkhead boot.
Posted by: ClayPerrine Sep 6 2014, 07:09 AM
The boots have been reversed on the cables for years. I have attempted to let them know, but frankly they don't care. They have a captive audience in us. We can't go elsewhere to get a cable.
Posted by: mepstein Sep 6 2014, 07:23 AM
QUOTE(Jacco @ Sep 5 2014, 04:06 PM)
Jacco
Good idea
Posted by: rgalla9146 Sep 6 2014, 08:15 AM
The problem is not with the boots. It's a hardware issue
The GEMO replacement cables don't have a collar on the transmission end to hold the boot.
See photo
The speedo end does not get a boot, only the angle drive and the bulkhead.
Posted by: Jeffs9146 Sep 6 2014, 09:44 AM
QUOTE(ClayPerrine @ Sep 6 2014, 06:09 AM)
I was able to get one off and turned the other inside out and put the one that I took off back on the other side. It was very tough and I did end up with a small tear in one of them!
Posted by: jeffdon Sep 6 2014, 09:55 AM
How is one supposed to get a proper cable?
Posted by: mepstein Sep 6 2014, 10:06 AM
Is it worth keeping the old parts to remake a new cable
Posted by: rgalla9146 Sep 6 2014, 10:49 AM
Sure, remove the angle drive end from the sheath of the new cable.
DO NOT CUT OR SHORTEN THE SHEATH
Remove the end from the old cable with care to save the end pieces.
Expand the crimped part some way.
Slip the new boots on the the right way.
Slip the old end pieces on.
Find a way to crimp the end on.
Easy
Posted by: jeffdon Sep 6 2014, 01:53 PM
QUOTE(rgalla9146 @ Sep 6 2014, 09:49 AM)
Easy
Yeah, really easy, especially the parts above I have emboldened.
Posted by: rgalla9146 Sep 6 2014, 02:43 PM
......my response was a bit tongue-in-cheek.
maybe not easy, but possible.
On the other hand, has anyone ordered one from the dealer by part number ?
914 641 111 00
Posted by: bluhun Sep 6 2014, 06:08 PM
QUOTE(rgalla9146 @ Sep 6 2014, 01:43 PM)
914 641 111 00
I ordered the cable directly from Porsche (over $100). The cable arrived with the boots in the correct orientation, but after installation the needle fluctuated wildly from 0 to 120, so I replaced it with one of the cheap aftermarket ones with the reversed boots. Hey, at least the speedo works now!
Posted by: jeffdon Sep 6 2014, 11:08 PM
QUOTE(bluhun @ Sep 6 2014, 05:08 PM)
914 641 111 00
Oh hell. What to do. At least I have a speedo ap on my iphone that works well.
Posted by: jeffdon Sep 17 2014, 08:56 AM
BUMP
Anyone come up with a source for a proper cable?
