Has anyone tried to build a flat 8 with two type 4 motors?
Theoretical questions.
Assumptions
2 motors each producing 100 HP and 100 Lb/ft of Torque
The motors are end to end, front to rear.
The cranks are fastened together either bolted or welded.
1) Would you get 200hp and 200 lb/ft or torque? or is there some multiplier...seems like you would produce more torque..
2) could it be done with a single ignition system available for sale off the shelf.
3) could you do it without two distributors? crank fired ignition system..I am thinking that there could be a wheel placed in between the motors to give you something to time from.
4) I am assuming either a nice FI system, or four carbs.
Has anyone done this?
I would like to see some articles or web pages if this has been done in the aircooled world...
Thanx in advance
Rich
yep, a few have been done........I know I've posted pictures as a well as a few others....
for a 914 application, the motor wouldn't fit unless you moved the assembly back a few inches...even without the cooling fan, I don't think it would fit in the stock location
for the cost/time/ it would take to make one, there are a dozen better engine choices unless one just wants to do it for the novelty of doing it....
since it's already been done a few times, there is no novelty in it....nothing ground breaking....kinda boring
I thought of it but I think it would be
too long to fit in a 914 and
you would loose 1 fan for cooling
now on the other hand If some one made a 6 case that took t4 or t1 P/C,rods, and heads it may work
but that just my thoughts
forget it! you would need a 6 crank, and cam
Just get a chevy v8 or a porsche 6 and be done
i was hoping you would answer...you always think outside the box...
So what about the torque numbers...is it simply double???
It just seems that is would be multiplied somehow..
and where would i find some pics....
Rich
It's been done both ways. I saw a pic years ago of a specially cast block for 8 cylinders. Also, the Fittipaldi brothers raced a Bug in Brazil where they coupled two motors together similar to what you describe, in a mid-engined configuration. They were apparently very successful with this car. Interesting way that they ducted air to cool the motors: they slanted the windshield back into the driver compatment. Air was ducted over the driver, then down to the two motors.
Andy
honestly cooling seems like a simple part of it ...
A custom horizontal system would work.
What are the numbers...in theory???
Rich
Double displacement does not usually equal double torque or horsepower. Not sure why.
In WWII, Pratt & Whitney took 2 14 cylinder radials and joined them onto a single case, resulting in a 28 cylinder that made 50% more HP. In the '90s Honda simply upped the size of a 600cc four to 900cc and got 20% more power (50% more displacement). Granted, the stock T4 is restricted, so using a RAT 2270 as a basis, maybe 250 HP would come from a T4x2. Just guessing.
i would think that you could never get double the power. maybe 150%, 175% if lucky.
entropy's a bitch.
Already have a print in with moldex on the crank.
Already dissected 4 engine cases to find the best mating points.... Just need time
asked the same question a while back....
here's what I got.
Hans Dahlbeck? Isn't he the brain donor in 'Young Frankenstein'? Seems fitting.
QUOTE (Cloudbuster @ Jan 28 2005, 03:23 PM) |
Hans Dahlbeck? Isn't he the brain donor in 'Young Frankenstein'? Seems fitting. |
You'd be better off starting with two early 2.0 911 engines. By cutting the center two cylinders out of one case and placing them in the center of the other case, you add two cyclinders to an already superior design. Having small cylinders to begine with (width wise) helps keep the lenth of the motor down too. Then a Scat crank and some custom cams, you have the better overhead cam design, better cooling, and better head flow. Plus with the early cases, they're all aluminum like the 914 case, making welding them together easier... and stronger.
Nah.... Can't make a statement with a 911 engine!
Plus, they cost too damn much to play with at this level..
I'm using 964 heads though..
Engine will go in a mid engine 1961 VW Single cab truck, under the bed.....
QUOTE (Jake Raby @ Jan 28 2005, 01:47 PM) |
Nah.... Can't make a statement with a 911 engine! Plus, they cost too damn much to play with at this level.. I'm using 964 heads though.. Engine will go in a mid engine 1961 VW Single cab truck, under the bed..... |
QUOTE |
I may try to get this done, just to see if it can be done smoothly, easily, and if it has benefit. |
An aviation supplier / builder / design company called "Able Experimental" has done this with full success--albeit a T1 engine---Developed over 210 HP and almost 280 ftlb of TQ---key was 90.5mm P/C and a 80mm stroke---it was made for experimental aircraft--the same company makes the altimizer carburetor--this is an injected carburetor which automatically compensates the mixture for changes in air density--very popular carb in aviation.
It won't cost a whole lot for me to do it, other than the crank and heads... The rest of it I have gobs of....
Its all in time and putting the imagination to work..
Its no fun if you don't push the envelope.... I'm sure I'd learn something beneficial to my other normal engines from doing it!
QUOTE (jwalters @ Jan 28 2005, 05:06 PM) |
An aviation supplier / builder / design company called "Able Experimental" has done this with full success--albeit a T1 engine---Developed over 210 HP and almost 280 ftlb of TQ---key was 90.5mm P/C and a 80mm stroke---it was made for experimental aircraft--the same company makes the altimizer carburetor--this is an injected carburetor which automatically compensates the mixture for changes in air density--very popular carb in aviation. |
Yea they do---imagine there is allot of machining and welding up a crank and cam and MAGNESIUM case ( Can you say,,sparkler??) Those engines require even more prep than or = to Mr. Raby does to his to make them a viable high power aero engine If the balances of the entire assembly are off more than .10 inches per second the crank will grenade itself--even at the max rpm of 3600 these engines are rated for--and bye bye propellor--the cranks are rough prepped by CB's--they actually forge a crank just for this purpose---kool stuff indeed
Don't know ifn I would ever get into something like that, manufacturing wise--the liability factor is an ass pucker!!!
But it would be kool to see Jake the man do it---400+HP anybody???
I myself have a really doable engine make-up I am dreaming of---it uses the stock bottom end--but the cyl and up is off the shelf from a manufacturer that has been in business since 1908--
Not going to reveal it yet,,need to get measurements and geometric values looked at--plus I don't want to get sand bagged just yet!
screw two motors! put four of them together!
QUOTE (Mueller @ Jan 28 2005, 08:13 PM) |
considering thier 100 hp /4 motors cost $6000, I'd hate to see the price of that /8 motor they do have some cool stuff... |
I am hoping to squeeze by with $5000,
buying that Passat stole the rest of my milk money!
Here it cost 6K for a stock rebuild, but you can add 50HP for another 2500 in most cases.
5000 will go a long way really soon, especially in the beginning!
how would you do oiling on the rear engine???
Seems like you would have to eliminate the oil pump on the rear engine and connect the two oiling systems in some way...
Rich
or connect them at the cranks...
if you're going that far, might as well go the route of merging two 911 cases...
Screw pistons...........someone stick a Huey Turbine in a 914 (hey...I saw an Allison V12 in a Opel GT once....."point and shoot" as someone put it)
Yeah, deals are out there if you wanna WAIT for them and are constantly searching for them Anyway...
After reading about the Ferrari's and Lambo's that have eight plus cylinders and how folks drool over the carbed versions of these engines I think it would be something neat. Heck, you wouldn't need monster big jugs, either, as these cars didn't, just lots o' cylinders. My initial guess would be getting two balanced STOCK engines and make sure the timing 'tween the two engines was spot on, then mate 'em From what I read, the older Ferrari eight cylinders run like two, four cylinder engines mated together, which also contributes to their distinct sound. I'm guessing their cylinder firing order is different than American V8's.
Now, getting a vehicle to accept the engine is another issue. But from my point of view I think it'd be neat and who gives a crap if it's already been done before? If you were successfull and DOCUMENTED it so others could follow you could develope a cult following
Just do like the fiero / lambo conversion guys---stretch that puppy and put a flat 12 lambo in it!!!
THAT would be kool to say the least----
ok,
When if any was the earliest time that an overhaed cam was used on a /6 motor???
I have never taken one apart....yet...
Rich
Thinking out loud:
Couldn't you slice one case disecting it between the bores (that would require an angle or zig zag)
then slice the ends off of the other case to insert it in between the front and back of the other two halves.
That make sense?
QUOTE (DuckRyder @ Jan 30 2005, 04:18 PM) |
Thinking out loud: Couldn't you slice one case disecting it between the bores (that would require an angle or zig zag) :sawzall: then slice the ends off of the other case to insert it in between the front and back of the other two halves. :welder: That make sense? :blink: :burnout: |
Rich, before i start in on Air Cool'd, the 901 (911) was an overhead cam from the get-go. They had some drawings for a single cam like the TIV, but it didn't prove itself like the overhead cams. The first 911 was in '65, but the project started in about '60. It wasn't set in stone till '63 or so, because Porsche wasn't sure if they wanted to go with a 356 looking car or not. Granted the 911 is close to the 356, they had other designs that they were looking at. Also, there was the 356 Carrera engine, which was the 4 cam motor back in the early '50s (550 spider). They the 901 had its first twin cam race engine in '67 for a few of the 911R's, which were 2.0L with around 200bhp.
QUOTE |
Yeah, deals are out there if you wanna WAIT for them and are constantly searching for them Anyway... |
QUOTE |
After reading about the Ferrari's and Lambo's that have eight plus cylinders and how folks drool over the carbed versions of these engines I think it would be something neat. Heck, you wouldn't need monster big jugs, either, as these cars didn't, just lots o' cylinders. My initial guess would be getting two balanced STOCK engines and make sure the timing 'tween the two engines was spot on, then mate 'em From what I read, the older Ferrari eight cylinders run like two, four cylinder engines mated together, which also contributes to their distinct sound. I'm guessing their cylinder firing order is different than American V8's. |
QUOTE |
Now, getting a vehicle to accept the engine is another issue. But from my point of view I think it'd be neat and who gives a crap if it's already been done before? If you were successfull and DOCUMENTED it so others could follow you could develope a cult following |
QUOTE (r_towle @ Jan 30 2005, 08:37 PM) | ||
ok, ill bite, why would i do that versus cutting the back off one and the front off the other....... BTW It looks like the oil galleys can line up if it is cut in the correct place. I would go with a dry sump. Rich |
Here's what you need...
QUOTE (Special_K @ Jan 29 2005, 07:18 AM) |
Screw pistons...........someone stick a Huey Turbine in a 914 (hey...I saw an Allison V12 in a Opel GT once....."point and shoot" as someone put it) |
QUOTE (URY914 @ Jan 30 2005, 06:09 PM) |
Here's what you need... |
QUOTE (r_towle @ Jan 30 2005, 06:14 PM) | ||
looks kinda heavy to me. I know you looked at it and said, hey he could make it lighter if he did this and this and this.... Rich |
QUOTE |
Ya, its called a 944 and a 928... The only difference is the crank and block. Same heads, pistons, rods, etc. But just because it has half the cylinders doesn't make it easy to make over. I too don;t know what the firing order is, but a 6/8 cylinder engine is WAY more naturally balanced than a 4 cylinder engine. In fact, the 6/8/12 cylinder engines are the the best for being balanced. |
QUOTE |
Cults are for those who like Coolaid[sic]. If a project like this ever made it to production, there would be very few who would undertake it. |
QUOTE |
Your going to be spending money either way you look at it, so why not start with a better designed engine and parts? |
Wonder how the T4 would respond with a crank that has throws at 90 degrees at each other--instead of the 180 degree config---this and change the firing order to reflect a burn event on one side of the engine at a time--like : 1, 3, 2, 4
Instead of one side-followed by two same side, then last one side again---: 1, 4, 3, 2---
There would have to be a radically ground cam for this--
Ala Ducati--if the Duc had four cylinders.......
QUOTE (jwalters @ Jan 31 2005, 01:47 PM) |
Wonder how the T4 would respond with a crank that has throws at 90 degrees at each other--instead of the 180 degree config---this and change the firing order to reflect a burn event on one side of the engine at a time--like : 1, 3, 2, 4 Instead of one side-followed by two same side, then last one side again---: 1, 4, 3, 2--- There would have to be a radically ground cam for this-- Ala Ducati--if the Duc had four cylinders....... |
yes, but what if you welded up the two motors to be in the 90 degree position???
That is what I was thinking....
Rich
QUOTE (jwalters @ Jan 31 2005, 04:47 PM) |
Very nice pic of a Duc!!! I am spanking to it right now----always wanted one--900SS super light was the one that I lusted for--
I did not mean use the valvetrain--no--I was thinking of the inherent smoothness of a 90 crank--but because the cylinders are still 180 deg. the extra two throws would balance out like it was a 90 deg. crank in a 90 deg. cylinder layout-
And yes-those cam lobes would have to be whittled down in width quite a bit--but it could be done......
QUOTE (jwalters @ Jan 31 2005, 07:52 PM) |
Very nice pic of a Duc!!! I am spanking to it right now----always wanted one--900SS super light was the one that I lusted for-- |
I know were're getting off topic here, but mmmmmmm Desmosedici = very nice. Man are they fast in testing this year too, wow. Looks like another fun MotoGP year.
Nathan, I second that! MotoGP sould be great this year!
Duck, good point!!! Even though the Desmo is an awsome working system, the adjustments that are required to keep them up to spec are extreamly time consuming.
Its like the early 356 Carrera 4 cam motors... book time is 40hours!! I'm not kidding. They figured it would take you 3 times to get it right... Its all bevel gears and shafts, first you adjust the exhaust cam, then the intake cam. Pro's know how to compensate so that once they tighten the intake cam gear, the exhaust doesn't move. The good thing is once the adjustment is done, you never have to adjust it again solong as nothing breaks!
I was out at Chuck Beck house (he lives outside Atlanta now) last fall and the first thing I saw was a 4 cylinder 911 engine he built. I can't remember when he did it but I would say early 80's. I also have an old HOT VW's Mag from the "energy crisis" days where they built a 2 cylinder Ty1. I think there is an aero ty 1 engine that runs 2 cylinders on the same side.
QUOTE (Al Meredith @ Feb 27 2006, 05:34 PM) |
I was out at Chuck Beck house (he lives outside Atlanta now) last fall and the first thing I saw was a 4 cylinder 911 engine he built. I can't remember when he did it but I would say early 80's. I also have an old HOT VW's Mag from the "energy crisis" days where they built a 2 cylinder Ty1. I think there is an aero ty 1 engine that runs 2 cylinders on the same side. |
QUOTE (Al Meredith @ Feb 27 2006, 04:34 PM) |
QUOTE (Cap'n Krusty @ Feb 27 2006, 05:37 PM) | ||
Ya coulda bought a REAL Porsche flat 8 yesterday at the Ustabedunkel's swap meet! The Cap'n |
QUOTE (Cloudbuster @ Jan 28 2005, 12:23 PM) |
Hans Dahlbeck? |
QUOTE (cbenitah @ Feb 27 2006, 06:10 PM) | ||
Ahh a swede, I should find out if its a relative.. imagine the typ of engine I will have when I'm done |
How about something like this???
QUOTE (ClayPerrine @ Feb 27 2006, 06:51 PM) |
How about something like this??? |
i wanna say thats a photoshop.....
nice 907/908 motor
Dude! is that at your house? Thant thing is awesome!
this whole subject to me is about the cool factor. I like the idea of tryin to build a a flat 8 from a bucket of parts and a tig welder. Who cares if it can even run. I would be cool to try.
i'll see if i can dig up two bus motors....
The VW guy owes me....
b
Mike...while your in there pouring aluminum, how about adding a few more pounds to the crucible.....
Do a straight 8 using the 911 heads arouind a chevy crank???
QUOTE (Aaron Cox @ Feb 27 2006, 06:00 PM) |
i wanna say thats a photoshop..... nice 907/908 motor |
FINALLY!!!
I was wondering when someone would pickup on the errors in my picture.
I actually would LOVE to do this. I have been thinking about it for a long time. I want to make molds of a 911 case, and make wax castings to cut apart to stretch. Then make molds for the stretched cases and cast them.
I would use a 3.6L case. If I were to do this, I would want to go BIG displacement!!!
Photoshopped??!! Well, if I were designing this thing in CAD, you'd do almost the equivalent in terms of "cutting and pasting" (well sort of)... this picture is excellent inspiration though for a very doable flat 8 using 911 parts and some off the shelf V8 stuff...
Mike.. think Propane, propane, Propane......
The crank would have to be custom made. That would be the big expense. The cams and cam carriers could be made from existing 911 parts. Just cut and paste using a welder and a dial indicator for the cams. Setup each cylinder as if it were #1. Get the cams onto the proper lift with the crank at the correct degree setting and weld them together.
Make an extended oil pump drive shaft, and a flat fan. Use a distributor cap from a mercedes v-8.
It's doable, it would just take time, paitence, and money.
And it would be REALLY cool in a 914....... 4.8L air cooled flat 8.
Mueller... you up for making a couple of custom cranks?
Well Actually no, never thought about doing a type four engine, However, my little devious mind has always wanted to do a three liter V8 using two Hyabusa (GSX1300 Suzuki) That have been over bored using a billet block and a custom crankcase and dry sump oiling system. Thought I would put it in a small formula car for hillclimbs. Used to get 260-280 out of 1480cc Bus motors back in the day, So I would say 475-480 on good gas would be the number. BTW, the reason you can't get double the hp is due to friction. More parts means more friction, there is a point of diminishing returns when it comes to adding cylinders. That it why many F1 cars stopped development on V12's. V10 WAS The best choice. now just freaking V 8's they suck.
The other idea I had was to use two FZR400 Yamaha Cylinders and heads and a custom made crank using the stock bore, but reducing the stroke so that I retained 640cc. This would give me a really nice bore to stroke ratio, and after some intake port epoxy and a scatter cam (one inlet valve opens before the other one to promote swirl) I think I could make 130-135 hp out of this one. Very cool. Counter rotating barrel valves, and injection with 4 valve cylinder heads. Very high tech, and very cool sounding. Would be a great FSAE engine. Little tiny gasps of air through that 20mm orifice. Yes, yes, yes, Oops I soiled myself.
Erik Madsen
Hi Clay,
When you say a custom crank MUST be used, is that because the Porsche head and barrels are at too wide a pitch(i.e spacing of journals vs barrel width)??
Otherwise, just customize the parts AROUND the cheap crank.....
Intention would NOT be to be a 908 replica, but just a powerful lightweight flat 8 that can slip into the engine compartment without hacking it all up...
QUOTE (Brian Mifsud @ Feb 27 2006, 08:42 PM) |
Hi Clay, When you say a custom crank MUST be used, is that because the Porsche head and barrels are at too wide a pitch(i.e spacing of journals vs barrel width)?? Otherwise, just customize the parts AROUND the cheap crank..... |
If you do a different firing order, then you'll have to do custom cams to match the new crank.
I would just offset one engine's crank 45 degrees. Exactly. Then no two cylinders are ever firing at once, and you could use a V8 ignition system, since all timing would be evenly spaced.
We're all lucky that flat engines are naturally counterbalanced.
QUOTE (ClayPerrine @ Feb 27 2006, 06:46 PM) | ||
Nope. The porsche crank uses a separate rod journal for each cylinder. So we need to add 2 more rod journals and 2 more main journals. I suppose you could cut up a BUNCH of 911 cranks and put together something that would work. But I would not try it with a custom made case. And I don't know what firing order to use either. This idea really gets me thinking... This would be SO cool with 4 dellorto/weber style throttle bodies and electronic fuel injection. Bet it would sound really nice too... |
QUOTE (Thorshammer @ Feb 27 2006, 06:42 PM) |
The other idea I had was to use two FZR400 Yamaha Cylinders and heads and a custom made crank using the stock bore, but reducing the stroke so that I retained 640cc. |
Can't use a chevy crank for a flat 8.
Here's a thought, use a crank from a V8 engine like a Chevy small block. Build a case around it, and add cylinders and a custom cam. Easy peasy...
QUOTE (alpha434 @ Feb 27 2006, 08:51 PM) |
If you do a different firing order, then you'll have to do custom cams to match the new crank. I would just offset one engine's crank 45 degrees. Exactly. Then no two cylinders are ever firing at once, and you could use a V8 ignition system, since all timing would be evenly spaced. We're all lucky that flat engines are naturally counterbalanced. |
The 180 degree 8 has a problem with second order imballance. It will shake at most street rpm levels. Most of you guys don't want to deal with that.
The 917 12s had problems with harmonics and crank vibration. This is why the fan and oil pump are mounted in the middle of the engine. You have to do this to keep those items alive.
You are better off just buying a Porsche flat eight. They aren't that expensive, when you look at what is involved in making your own.
One of the problems must be the design of a crank that does not extend the overall length of the engine by too much. This could be a major problem. It will probably have to use rods that are adjacent to each other liek a small block to keep the cylinder bore spacing decent.
As for the previous comment about bevel drive gear Carrera engines needing 40 hours to build. Yes that is true, if they are a new parts build up. However, if the time is taken upon disassembly to check tolerances and shims are kept in the proper order, then it is less than that. many Carrera Maestros (HA, HA, HA) keep the black art thing going to ensure no one else plays with them. Ensuring they have a place from now forth. But the main issue with 4 cam engines is parts availability or the ability to make some part that are NLA. This is the real issue. and thats why only two guys in the country do most of the 4 cam work. its either MT or CT, anything else is just a myth.
If you can work on a bevel drive Ducati, you can work on a carrera 4 cam.
BTW, why not make the V8 Type four monster use some Ducati Desmo air cooled cylinder heads. I have built many of those engines, the best we ever got in 750cc form was about 90-92 hp depending on the day. Which would mean 225 hp or so from 2.0 liters and 450 from 4.0 liters.
Just a thought.
Erik Madsen
Why we couldn't use a Chevy crank:
Counter balancing, and angle offsets for timing.
A 60 degree V8 with a firing order 1-2-3-4-5-6-7-8
and shaped like this
1----2
3----4
5----6
7----8
The crank is at 0deg for 1. The crank is machined so that the piston one is -30 deg off center. Two is 45-30=15. Three is 60. Four is 95.
QUOTE (Brett W @ Feb 27 2006, 08:56 PM) |
The 180 degree 8 has a problem with second order imballance. It will shake at most street rpm levels. Most of you guys don't want to deal with that. |
QUOTE (alpha434 @ Feb 27 2006, 07:03 PM) |
Why we couldn't use a Chevy crank: Counter balancing, and angle offsets for timing. A 60 degree V8 with a firing order 1-2-3-4-5-6-7-8 and shaped like this 1----2 3----4 5----6 7----8 The crank is at 0deg for 1. The crank is machined so that the piston one is -30 deg off center. Two is 45-30=15. Three is 60. Four is 95. |
QUOTE (Cloudbuster @ Feb 27 2006, 06:52 PM) | ||
Just in case you didn't know, somebody is most of the way there http://home.mira.net/~iwd/ |
QUOTE (lapuwali @ Feb 27 2006, 07:18 PM) |
The wackiest design I've seen was a "V8" made by simply gearing the output shafts of two complete ZX-9 engines together to a common output shaft (one through an idler), with the engines sitting "cheek to cheek". This made complete engine changes very easy, as long as you had a supply of used ZX-9 engines. It was very wide, but was built for a class of sportcar racing that required two side-by-side seats, anyway, so the width wasn't a problem. I believe a pair of ZX-12 engines were used by the same guy in a different car. |
Sorry I was referring to a 180 degree V8. Don't know much about the flat 8. I would guess it would be pretty close to balanced.
QUOTE (DuckRyder @ Jan 31 2005, 03:45 PM) | ||
Trying to make a desmo valve system work without overhead cams would be ... probably impossible. Once you've adjusted the valves on one, you won't ever try to convert something TO Desmo. And there is a 4 cylinder Ducati, the DesmoDeci (vs DesmoDue) |
It's time for this to finally happen
Parts heading to the machine shop with a goal of a spring firing
wow a Aircooled Pushrod Flat 8
Yes, you are.
At least it am staying in the family.
Theres a guy down in Melbourne who has made flat 8's out of 6's, says they are really easy and has moulds for the 908 style fan shrouds... problem is my last boss has been trying to get parts off him for some years now. This is one of my all time projects I wish to make. Cudo's to you for trying it with the type 4 stuff... will be fun to fallow your progress.
Totally do-able with some planning. I'll be watc hing this one!
The 2 factory 914/8 cars had 908 engines in them. The orange one had the full race MFI engine, and the grey one had carbs and was de-tuned for street duty.
There is one in the Porsche museum.
I will be doing this someday if no one else does...probably even if they do.
Doc you should do a flat 12 Covair
V16 inspiration
http://www.gtspirit.com/2012/02/01/video-custom-speed-buggy-with-v16-engine/
and these heads;
http://members.home.nl/r.vd.meulen/photopage.htm?./pics/dist07.jpg
http://home.swipnet.se/motor/custom/
Back to the flat 8 talk....
Found out Ferrari uses flat-plane crankshafts in some of their V8's so I went on eBay and voila... I found this crank from a 328, 73mm stroke instead of the Porsche 908 66mm stroke.
Guy wanted $850 plus shipping, I offered about half that, he didn't quite tell be to F off, but I think he wanted to with his response, asked me to call if serious.
Anyway, while not as accurate as the 908 crank it seems like a cheap alternative.
There was a guy, Richard I think, who used to show up at the G&R all the time who planned to build an 8 cyl. type IV. Richard are you out there?
Isn't there a guy working on casting new 3.6 cases? Maybe he could cast one for an 8
There are people reproducing basically all of the parts of the 908 engine. You don't want to know what they cost....
--DD
I know there was a Swedish guy building one and putting it in a buggy. Not sure if it was based on T1's or T4's.
edit: found this when searching....
https://www.youtube.com/watch?v=2GpMGPUMyXE
Direct link to "boxer 8" page
http://home.swipnet.se/motor/custom/boxer8.html
