Does anyone have a picture of a 914-6 fuse panel they could post? I'm re-installing mine after replacing the harness and new style fuse block. I've got 4 relays (3 round ones and 1 square one) and 4 mounting holes on the fuse panel. But I'm not sure which relay goes in which hole. My manual only shows a 914-4 fuse panel.
Will try to get pix and / or info by tomorrow.
Ed - down south in Morgan Hill
Thanks Ed!
not sure if this helps, this is out from the factory repair manual:
914-4
A - low beam
B - fresh air blower
C - additional high beam
D - buzzer
(I hope my translation is correct )
A - buzzer
B - fog lamps
C - horn
I added both types because you wrote about 3 round and 1 square relays - and this is shown only at the -4 board
QUOTE |
not sure if this helps, this is out from the factory repair manual: |
I'm assuming that Wolfgang has answered your question as well as I could.
If it would help to SEE one, take a drive south.
... Ed
Ed,
I'll be passing through Morgan Hill on the way to Long Beach this weekend. How does Saturday mid-morning sound? PM me with details if this sounds doable.
The picture Wolfgang sent agrees with what I saw on a local 914-6 yesterday. However, I have an extra square relay (?) that I don't know where to mount.
Thanks,
Mike
The Diagram I have that matched your ignition Question, shows ;
1 addtional headlight relay .
2 headlamp flasher.
3 horn relay,
4 square turn indicator and hazard warnig flasher unit
Will it go in location D in Wolfgangs 6 pic.?
Hpoe this Helps , Jeff
