Do you think one could use the later 2.0 series heads to fill and air tank with compressed air using the air injection ports?
This would be for an adjustable air ride suspension.
How many maximum psi?
on a running engine?
Probably more efficient to run a pump on a pulley like the air injection pump. But what would you need the air for? The water squirters
I run an old a/c compressor for on board air on my jeep with a switch to turn on the clutch to run the compressor. with the idle up a bit I can air up big tires quick and run air impacts on the trail.
Honestly I can fix your problem for about $65 and a trip to Home Depot
http://www.amazon.com/Ryobi-P731-Function-Inflator-Compressor/dp/B006NKLHOY/ref=sr_1_3?ie=UTF8&qid=1416379254&sr=8-3&keywords=cordless+air+compressor
Sorry forgot for suspension. If you used a 12v pump you could power off the battery, you would just need a tank to store the compressed gas, which you would need either way. The electric pump would be way more efficient, especially on our little motors. How much horsepower to you want to rob?
Rich,
I liked your idea of using the air injection to run a couple of small turbos. What ever happened to those plans?
Not much pressure in an exhaust system. Be kinda like blowing up a broken balloon.
The Cap'n
I like the AC compressor idea. The magnetic clutch would toggle on and off with a pressure switch. Plus adding a train horn along with the air ride would be cool
ummm, those horns give me a new idea....wow, wonder what those are from?
a locomotive? there is a rail car in the background.
Systems available for the BRZ use the electric compressor technique:
http://www.airliftperformance.com/vehicle/subaru-brz/
Yah I like those horns. Warp speed Mr Sulu!!
electric pumps and air ride are used in mini-trucks all the time. It's very well established. electrical isn't a problem as the pump doesn't run that often if the tank is a good size.
You could always increase alternator output and add a battery if you had to. Most modern cars are moving to electric A/C as it is more efficient. Less spikes in HP demand as they kick on. For suspension I would doubt you would even need to add the extra capacity.
