Printable Version of Topic
914World.com _ 914World Garage _ Time for Gauges
Posted by: Cairo94507 Feb 14 2015, 06:50 PM
Hi everyone- Scotty just sent me my original Six gauges so I can take them to Palo Alto Speedometer and have them restored. So the speedometer is pretty straight forward, it will just be totally restored and the existing mileage retained as it is the true mileage of the car and worked until the car was taken apart.
The tachometer is a different story. It will be restored and converted to work with the 3.2 Motronic motor going in the car. I am also considering having an oil pressure gauge installed into the tachometer, similar to the turbo gauges on the 930's. I figured that was the most obvious place to put this critical gauge. I am curious what other people think about that though. So please let me know your thoughts.
Now the last gauge is going to convert to a triple gauge. I am thinking oil temp, cylinder head temp and possibly amps. I want that gauge to retain a fairly stock look with the typical 914-6 warning lights and symbols in it.
The fuel gauge is going to move down to the storage compartment right below the dash bottom with possibly another gauge next to it. I really do not want to add a clock but can't really think of another gauge for that position. I would like to have two gauges in the storage box for balance.
Please feel free to add your thoughts. Of course we will be keeping the silver dot feature of these gauges.
Here is my stock tachometer:
Posted by: Cairo94507 Feb 14 2015, 06:51 PM
Here is the the stock Six combo gauge:
Posted by: Cairo94507 Feb 14 2015, 06:52 PM
And finally, my original speedo:
Posted by: Cairo94507 Feb 14 2015, 06:53 PM
I was also thinking about asking Palo Alto Speedo to change out the odometer to the newer 911 style that adds one more digit so when the car turns 100K it does not go back to zero. Thoughts? OH and you may have noticed the extra combo gauge in the background of the second picture. That is likely the one we will be using to make the new combo gauge so I can retain the original Six combo gauge in storage with the other original Six parts we will be replacing with newer stuff - thanks Scotty for that gauge .
Posted by: screenguy914 Feb 14 2015, 07:38 PM
An ammeter? I think you'll have more electrical info with a voltmeter.
Essential gauges:
Oil pressure
Oil temperature
Fuel level
Speedo/Odo
Tach
Nice to have:
Cyl. head temperature
A/F ratio
Voltmeter
Exh. Gas Temp (EGT)
MHO
Posted by: Steve Feb 14 2015, 07:50 PM
If this is a street car a head temp gauge is overkill IMHO. I would either go with a stock 911 pressure and temp gauge and add the fuel gauge to the tach or install a triple gauge like i did and be done with it.
Posted by: scotty b Feb 14 2015, 07:59 PM
250 on the speedo
Posted by: Steve Feb 14 2015, 08:06 PM
QUOTE(scotty b @ Feb 14 2015, 05:59 PM)
250 on the speedo
They drive pretty fast in the bay area.
Or maybe its KPH instead of MPH, so it looks like they are driving fast!!
Posted by: Cairo94507 Feb 14 2015, 11:07 PM
WTF are you guys talking about? The speedo is stock at 150. I will concede it is a volt gauge I want, not amps.
Posted by: earossi Feb 15 2015, 01:28 AM
I have a set of gauges sitting at Palo Alto right now for my /6 conversion car. I did something a little bit different.
First, I purchased a used set of gauges out of a 930 turbo. Palo Alto has replaced the center mounted boost gauge on the tach with a fuel level gauge. And, the tach face will have the red line altered to match my 3.2 motor.
The gauge space that normally carried the fuel quantity/oil temp combo gauge will now house a 911 combo gauge that monitors oil pressure and oil temperature.
And, the speedo was left pretty much stock.
For those who have not had their gauges rebuilt.....it is not cheap! Refurbishment of the above gauges and reconfiguring them as noted will end up costing very close to $1200.
North Hollywood would have been a tad less expensive (maybe $1000 for the work), but they are under new ownership and have gone through a loss of personnel and quoted me a backlog of over 4 months! So, I passed on them. Does not sound good for their company.
Posted by: ConeDodger Feb 15 2015, 01:35 AM
QUOTE(earossi @ Feb 14 2015, 11:28 PM)
How recent is this sale of the company? I just had some gauge work done in December and the turn-around was a week!
Posted by: earossi Feb 15 2015, 01:52 AM
QUOTE(ConeDodger @ Feb 15 2015, 01:35 AM)
I'm not absolutely certain, but I think that the company was sold about a year ago. i first contacted them in the Fall of last year (Oct or Nov), and spoke with a guy who was very knowledgeable. At that time, he quoted about 4 weeks for a job the size of mine. And, he provided approximate pricing.
When I called back in early January to confirm things, I was told that my contact had just left the company and that they were now backlogged about 4 months. Since that won't work for me, I moved on to Palo Alto. But, to me, it sounds like they are going through some sort of shake up resulting in loss of personnel.
Just my 2 cents.
Posted by: 914forme Feb 15 2015, 08:41 AM
I would do a tripple or a quad gauge and load it with what ever you want, go with a 930 tach, and convert the boost gauge to what ever you want. 4-5 aux. gauges in the stock location. No cutting, no gauges in odd location in the car. If you don't mind losing all the stamped details of the triple gauge(904 style) the 924 combo gauge has 4 windows, and Palo Alto should be able to use it and be very crafty, build you a quad gauge.
But then again, I would goto SpeedHut, and get all the gauges done, modern internals, shorter mounting depths, nicer harness, and all matched faces than $700, and you get nice things like a GPS speedo, ability to make them just the way you want. But thats just me, I see know reason to use stock gauges
And I happen to know a lot about how to do fun stuff with stock gauges!!!
Posted by: ConeDodger Feb 15 2015, 10:02 AM
QUOTE(earossi @ Feb 14 2015, 11:52 PM)
Just my 2 cents.
Hmm... Well like I said, I just had a one week turn-around for a speedo and tach from an 87 Carrera for my 3.2 914...
Posted by: mepstein Feb 15 2015, 10:51 AM
I'm keeping mine pretty simple. Stock 150 mph speedo. Stock tach from a 3.2 911. Stock 911 oil pressure/temp gauge modified to a triple gauge to include fuel. I will have the mod done by Timothy once I get a triple gauge face plate.
If you want a bunch of gauges in your 6, maybe place the extra gauges in a removable box with snap together connecters. Have it while your doing your shake down runs and remove it once you have a comfort level with the car. It could all be built into a center console deposit box.
Posted by: Hank914 Feb 15 2015, 11:07 AM
QUOTE(ConeDodger @ Feb 15 2015, 08:02 AM)
Just my 2 cents.
I used PA Speedo (walking distance to me), and was quite satisfied.
But they have called my cell phone twice since I picked it up (about six months ago) to inform me that my speedo was ready to be picked up. I think their admin assistant has mixed up various customer's contact info, and yes I did inform them of their mistake so that they could call he correct customer to get the message to them.
And I used the opportunity to inform them that when I got the speedo back the calibration was way off. They said no problem, just let them know how off it was at 30mph and 60 mph, and they would calibrate it for me. Once I get new tires, I will do just that. I'm a happy customer, but I almost went the DIY route on speedo repair, as this internet thingy (both here and Pelican) does provide pretty clear instructions.
Posted by: Cairo94507 Feb 16 2015, 10:36 AM
So, I know what I think I want but this is one of those things where I believe it never hurts to ask questions first so I don't have one of those "I could've had a V-8" moments later.
Case on point, "914forme" brought up Speedhut for gauges. That is intriguing as it could give me new electronics possibly. I have contacted them and am awaiting their reply to see if they can take my gauges and install all new electronics in them or if they actually have a gauge that replicates the stock gauges from our cars. Granted that may be a reach.
In evaluating the gauges I want, I agree it is oil pressure, oil temperature, volts, tach with 3.2 redline, speedo and fuel. So given that, it would appear I could do a triple gauge with gas, volts and temperature and then add the oil pressure into the tach (hopefully). I would then not need any additional gauges.
I really do want to change the speedometer to have a new odometer that will not roll back to zero when the car hits 100K as my car is only 10K away from that give or take. Not sure how others feel about that but my mileage is documented and I want it to remain accurate. The new odometer, if that is possible, would be set to my existing mileage.
Thanks for your patience and assistance. I always respect (intelligent ) opinions and appreciate your experience.
Posted by: Cairo94507 Feb 16 2015, 12:31 PM
OK- Heard back from Speedhut and they do not offer anything close enough to our gauges to make it viable. They also will not work on gauges supplied by the customer. So Palo Alto Speedo it is. I am OK with that and glad I looked at other options to make sure I wasn't missing something.
Posted by: mepstein Feb 16 2015, 12:54 PM
Too much?
Posted by: Cairo94507 Feb 16 2015, 08:26 PM
Hmmmm that seems just about right.
Posted by: zambezi Feb 16 2015, 09:09 PM
You should consider a quad guage and not have to modify your tach.
Posted by: TargaToy Feb 16 2015, 10:07 PM
QUOTE(zambezi @ Feb 16 2015, 10:09 PM)
Oooooooh... I like that!
Posted by: LukeD Jun 10 2015, 11:08 AM
QUOTE(zambezi @ Feb 16 2015, 08:09 PM)
Where can one acquire this quad gauge?
Posted by: billh1963 Jun 10 2015, 12:50 PM
http://www.paspeedo.com/porsche914combi.htm
http://www.914world.com/bbs2/index.php?showtopic=229630&st=0
http://www.914world.com/bbs2/index.php?showtopic=224126&hl=combination++gauge
http://www.newvintageusa.com/bigmarkdesign
Posted by: Cairo94507 Jun 10 2015, 01:27 PM
Been a while but I switched to a later electric speedo to add the additional digit on the odometer, Kept my Six tach and had it converted to the redline for the 3.2 and I added an oil pressure gauge in the bottom, like the turbo gauges. I then went with a triple combo gauge that has oil temp, oil pressure, and fuel. Palo Alto Speedo is doing them and I can't wait to see them. All silver dot gauges of course.
