I have had several ignition switches fail in m 1973. I am on the third "new" ignition switch in 4 years. I think these are a repro part and not up to the original standards.
What usually happens is either the ACC does not switch on so the fuel pump does not run or the starter does not switch on leaving me stranded.
Are these 3 position switches or just 2?
Does anyone have a diagram for how to wire a switch for the ACC and a starter button? I notice there are 6 terminals on an ignition switch module so I assume this is not simple.
I would keep the key just for unlocking the steering column and maybe rig a second, hidden switch for the fuel pumps.
So far my engine has been very reliable and it has always been electrical problems in the relay board (now thankfully removed by Joe O'Brien from Series9) and the stupid ignition switch that have caused my car to not run.
Thanks,
John
Most ign. switch wear and tear is due to current flow in the "Start" or "Crank" position that energizes the starter solenoid. You can reduce ign. switch wear by installing a separate momentary switch (push button, toggle, etc.) to energize the starter solenoid. Use the ignition switch only in the "ON" position to activate all other circuits (fuel pump, ignition, radio, lights, etc.).
Here's a link describing the circuit for a 911 (generic for most cars):
http://members.rennlist.org/911pcars/RemoteStarter.htm
Hope this helps,
Sherwood
Hello John, here's a diagram of what I did for mine, the button only works when the
key is ON , and this fits under the dash, I also use a hidden pump switch (ground based for my fuel injection) ,
if you stall the motor while driving just push the button , no need to turn the key off and back on again, I hope this helps Bill D.
Does the yellow wire going to the original ignition switch require a diode to protect it when the button start is used ?
I think this is a good case for the "hot start relay" A simple relay located by the starter. The ignition switch pulls the relay and the relay contacts engage the starter. Look at the size of the wire that pulls the starter solenoid. It is a pretty big conductor. Your switch needs to handle all this current. Put the load on a cheap relay and save the load on the switch
I'm using this push button...it handles the amps easily http://m.delcity.net/store/Heavy!Duty-Push-Button-Switch/p_8065.
How much load is on the accessory part of the switch?
This can be a significant amount if the lights are on.
I don't want to ever have to take apart my ssteering column to fix this again.
John
Double post.
