Here's what I did to a 901 transmission case to make it easier to adjust the side shift forks.....
Reverse
First
Second
Third
Fourth
Fifth
how do you put the piece you cut off back on? weld? glue?
Seems like some fluid might leak out thru that big hole.
Nope.. gonna run it like that..... Imagine the cloud of smoke behind my car from all the gear oil it would be slinging........
Actually, the transmission case in the pictures suffered from half shaft trauma. The cv bolts backed out and the half shaft spun around at speed and knocked a hole in the case. I cut the part out for the fork adjustment. That case is now just a fork adjustment jig.
You should see the side shift console......
Betty just came in for lunch... She is just that good with photoshop so she made a transparent transmission for me...
She also suggested "transparent aluminum" to fix it (Geek Check).....
I figure I can fix it like Charlie Davis fixed his transmission.... Duct Tape!!!!!
Damn good idea!
I've got a busted case and I almost trashed it last week.
Thanks Bob
I run my head like that so the brain I borrowed can be replaced easily.
M
QUOTE (ClayPerrine @ Feb 24 2005, 01:25 PM) |
She also suggested "transparent aluminum" to fix it (Geek Check)..... |
post a photoshop file where you can hide/show the transparent layers....so i can see how this thing moves
QUOTE (bd1308 @ Feb 24 2005, 02:17 PM) |
post a photoshop file where you can hide/show the transparent layers....so i can see how this thing moves |
Clay,
I'm confused...
why do you need an adjustment jig?
can't you just align the shift forks with an alignment tool when the stack is pulled out?
brant
if clay could take all the pics from the same angle this would have worked mucho better....
QUOTE (brant @ Feb 24 2005, 03:40 PM) |
Clay, I'm confused... why do you need an adjustment jig? can't you just align the shift forks with an alignment tool when the stack is pulled out? brant |
QUOTE |
Oh, and Aaron... I took the pictures free hand. If I had known you wanted to make an animation of them, I would have just taken a movie of it. |
QUOTE (Aaron Cox @ Feb 24 2005, 01:50 PM) |
if clay could take all the pics from the same angle this would have worked mucho better.... |
QUOTE (SirAndy @ Feb 24 2005, 02:57 PM) | ||
ever heard the word "offset" before ??? angle is still off, but at least on mine the tranny isn't jumping left/right ... Andy |
Brant,
I made one of those from an old case a few years ago too. The problem with adjusting it outside of the case (or with the facotry jig for that matter) is that it wants to flop around and doesn't stay securly held the same way that the case does. I've got a design for a jig that holds everything together just like the trans case does, but the cost would be to high, and cutting a trashed case is way cheaper.
Very nice pictures ! Always wanted to see what is inside the tranny.
Can you describe, using the pictures, what goes awry when the first tries to jump out gear ? I would like to know more about this problem before I visit the tranny shop.
QUOTE (Aaron Cox @ Feb 24 2005, 05:59 PM) | ||||
andy - im not a compuguru like you ..... so BITE ME my trans looks like it is haveing a seizure! |
Here's some new images taken Sunday with a tripod of a transmission in the jig. It shifts from neutral to fifth.
This one doesn't jump around......
Hey Clay, got any kind of jig for setting the pinion and ring gear depth
inside joke...my tranny is very noisy
why not put a caption on each frame to show us neophites what gear is being engaged? great thread, you guys. thanks.
QUOTE (jfort @ Mar 1 2005, 08:28 AM) |
why not put a caption on each frame to show us neophites what gear is being engaged? great thread, you guys. thanks. |
QUOTE (ClayPerrine @ Feb 24 2005, 11:25 AM) |
Just for fun, I did this is anyone is interested.
http://www.rockaria.com/914gears/
QUOTE (Rockaria @ Mar 1 2005, 12:28 PM) |
Just for fun, I did this is anyone is interested. http://www.rockaria.com/914gears/ |
Man, you guys are awesome! A bit too much time on your hands, but awesome none the less.
Clay's animation might make a good avatar.
if clay could take all the pics from the same angle this would have worked mucho better.... :( |
Rockaria,
Thats awesome! I think I just set a new record for the fastest shifting 901 tranny using your ap
Must be that newfangled transparent alum case
Tony
Mark, you are right, it IS more acurate.....
Rockaria.. love the animation. It puts to shame the one that I was working on........
Thanks for the kind words everyone. I tried to do it to the original pics but failed. But the tripod ones were easier to use. A few people asked for info on what each gear was and now they have it. Reverse seemed to be missing, so I hacked it together from other photos. And there seems to be missing a small gear somewhere in the 1/rev area, I think. Oh well... Maybe its just the angle.
Too much fun,
The tripod pictures were taken of a transmission without a reverse gear installed . So the reverse idler was missing. I assumed that you used reverse from the other set of picts.
Good work!
This is cool Clay. And I'd like to see the other animation as well. Hope it's being updated.
Not worth it when you consider that the jig is <$20 But hey, its your mess to clean up and store.
The jig works fine for me. But there are tech sessions with my PCA region where this would be a wonderful thing to have on display. I don't have a scrap 915 case to do the same thing with but it's a good idea to explain gearing to folks who just drive their cars without knowing what's in 'em. I just threw away two of these cases that were cracked. Dangit.
Jig doesnt always work? What are you smoking? I have never had it let me down on over 100 builds
I intend to make one of these, more stripped than yours, for demonstration purposes. As a jig, this is way overkill.
I see a jpg image that looks promising but no animation.
I have a similar case that was sacrificed for my constant changing of gears in the stack.
Made me sad to move it around the other day….but I might do one more in my lifetime….
