is it toast?
Easily fixable, if you cant do it, bring it on up and I can do it for you. Just bring me some metal.
another view. when I poke at teh long, it is solid
For a guy from Cali.....yes, sell the tub to me.
For a guy from newengland....it just needs a small amount of mig wire....
Seriously, take off the jack plate and get a new one, weld it back together...done.
Rich
NO!
A= buy a new piece and put it in
B=cut it off and replace rotten metal with new piece and forget about jack post
C=waste time repairing rusted post
Most likely there will be rot on the long behind the post so you should go ahead and remove it
Get rid of it.....grind it smooth, paint it....fill the hole in the rockers and fuggetaboutit...
teh car is for sale. I just dont want to screw anyone
No one uses the stock jack....you REALLY should lift it from the donut under the car....
When I re do a car...that's the first thing that goes....
QUOTE |
No one uses the stock jack |
And when it lets go? You get a scar from the rocker halfway up the door....stoopid place for the jack point.
It's his car he can do anything he wants...."I" just think it looks cleaner with it removed and safer when it's not there to be used...
QUOTE (trekkor @ Mar 1 2005, 04:52 PM) |
I *always* use the jack point with a floor jack lift plate. Lifts the whole side of the car at once. Fast. |
POR 15 it and forgetaboutit!
Fix it. That's an easy repair. I'd even do that myself (now). I use the stock jack points with a receiver and floor jack.
QUOTE (sean_v8_914 @ Mar 1 2005, 07:36 PM) |
teh car is for sale. I just dont want to screw anyone |
Sean,
What's the car parked in front of the teener?!?
Kelmark GT. Dino 246 replica
looks just like this only cheaper
like this
red
QUOTE (Gint @ Mar 1 2005, 05:18 PM) |
Fix it. That's an easy repair. I'd even do that myself (now). I use the stock jack points with a receiver and floor jack. |
