Printable Version of Topic
914World.com _ 914World Garage _ BUILD-OFF CHALLENGE: Madmax914
Posted by: madmax914 Oct 1 2015, 11:43 AM
This is the motor, 2004 2.0L WRX turbo motor with 55,000 original miles. I picked up this motor from Jrust, Thank you Jamie!
Posted by: Andyrew Oct 1 2015, 07:07 PM
Should be fun to watch this one!
Posted by: JRust Oct 1 2015, 07:14 PM
QUOTE(madmax914 @ Oct 1 2015, 10:43 AM)
I only regret it every other week
Posted by: 914forme Oct 1 2015, 08:06 PM
Oh wow this will be a fun one to watch, another sub conversion. With a different mount.
Posted by: Mueller Oct 2 2015, 11:10 AM
A conversion?...not fair, they get more points...hahaha
Looks like that is going to be a fun car when done....good luck and have blast!
Posted by: Nutter965 Oct 2 2015, 01:32 PM
Mmm this is going to be sweet, nice looking shell to work with
Posted by: madmax914 Oct 2 2015, 06:55 PM
Here is my Outfront coated header and the stock turbo that Outfront polished for me.
Posted by: dangerranger01 Oct 4 2015, 08:06 PM
Right on! Another oregon build....i'm excited to see this subie conversion finished....i just might want to do that on mine....
Posted by: madmax914 Oct 4 2015, 08:31 PM
QUOTE(dangerranger01 @ Oct 4 2015, 07:06 PM)
Let me get it in and see if it'll work. On paper it should. If you decide to let me know I'll walk you through it.
Posted by: 914forme Oct 5 2015, 07:16 AM
Nice looking engine mount. Should work fine, lots of 914-6 running around with similar mounts from Patrick Motorsports.
Maybe I should change my mount.
Posted by: Chris H. Oct 5 2015, 01:42 PM
I'm thinking the same thing... I like that idea.
Posted by: madmax914 Oct 6 2015, 07:15 PM
Taking the night off from working on the car, local Tap House has Widmer Brothers Brewing there giving away goodies. I'm a sucker for beer goodies!
Posted by: Andyrew Oct 6 2015, 09:35 PM
Widmer's got some good stuff!
Posted by: Garland Oct 9 2015, 06:13 PM
QUOTE(madmax914 @ Oct 9 2015, 05:13 PM)
I'm sure this has been discussed several times on this forum but I'm just not finding it in a search. I would like to know how much wider are the GT fenders front and rear than stock fenders? I know they allow you to put a 7" wheel/tire combo in the front and 8" in the rear but I'm looking for an actual measument. If I hold a new GT fender up to a stock fender what is the measurement from lip to lip?
Any help would be very much appreciated.
Thanks!
Michigan Build here,
I'm hanging Fenders in my build, measures at outer lip, to outer lip is 2" front and rear.
Garland
Posted by: JRust Oct 10 2015, 12:28 PM
Hey Brett are you using the stock oil pan? I'm going to be changing mine. Outfront basically cuts the stock one down & welds on a new bottom. A little more to it but it get's closer to like 4 1/4" as opposed to the 6 1/2" or so stock. Only thing I don't like is losing some oil capacity with it. Small car has a nice aluminum one which I think I prefer. Keeps the stock oil capacity. Which has to mean its a litter bigger around. So just not sure if it will fit with my cradle. I think I have a little space to work with there. Anyway feel free to buy the small car mount for yours. Then I can borrow it to see if it will fit mine
Posted by: madmax914 Oct 10 2015, 12:56 PM
QUOTE(JRust @ Oct 10 2015, 11:28 AM)
The Outfront oil pan and header was the first thing I bought when you sold me the motor. Already mounted and on the motor. Thanks for thinking of me.
Posted by: JRust Oct 10 2015, 02:10 PM
QUOTE(madmax914 @ Oct 10 2015, 11:56 AM)
With the header mounted. How much does the header drop below the oil pan?
Posted by: madmax914 Oct 10 2015, 02:23 PM
It doesn't the pans about 1-1/2" below the headers.
Posted by: Andyrew Oct 13 2015, 10:27 PM
Pretty nice fitment! What are you going to do about heat from the turbo?
Posted by: madmax914 Oct 13 2015, 10:37 PM
QUOTE(Andyrew @ Oct 13 2015, 09:27 PM)
Probably a turbo blanket, the exhaust out the turbo will be ceramic coated. I'm going to try Lizard Skin spray on heat shield on the firewall.
Open to suggestion
Posted by: 914GTSTI Oct 13 2015, 10:49 PM
What is your idea for the motor cradle ?
Randy
Posted by: madmax914 Oct 13 2015, 10:59 PM
QUOTE(914GTSTI @ Oct 13 2015, 09:49 PM)
Randy
I'm not using a cradle, I will be doing a bulkhead mount very similar to the Patrick Motorsport 914-6 bulkhead mount. You can see the bulkhead cross bar that will mount to the motor.
Stay tuned for more to come. I should have more to show you this weekend.
Posted by: flmont Oct 14 2015, 10:26 PM
whats the cost,..and pwr of a motor like that !!! (ball park..) Thnxs
Posted by: madmax914 Oct 15 2015, 08:51 AM
QUOTE(flmont @ Oct 14 2015, 09:26 PM)
I purchased this motor from a member here on World, it had been in a 914 and was removed to do a V-8 conversion.
You can pick up these JDM engines on Ebay or CL, they range from $1,600-$1,900. A STi motor will be in the $3,500-$5,500 range depending on year and mileage.
Posted by: Chris H. Oct 15 2015, 10:38 AM
I'm sure you're going to show is, but what will you attach the mount to on the engine side? A smallcar mount?
Posted by: madmax914 Oct 15 2015, 11:10 AM
QUOTE(Chris H. @ Oct 15 2015, 09:38 AM)
Yes, a Smallcar mount, rectangular steel tubing will connect the two Smallcar brackets and two arms will go forward and attach to the round stock on the fire wall.
Keep your fingers crossed that this will all work out. Its worked on many a Porsche six.
Posted by: Chris H. Oct 15 2015, 11:37 AM
Yeah I can picture that. Then the whole underside is clear for the exhaust. No mount bar at all. Like it.
Posted by: madmax914 Oct 15 2015, 11:55 AM
That is the beauty of it all, nothing to interfere with exhaust or axles. I installed the cut down oil pan from Outfront now the lowers point of the car is the bottom of the car!
Posted by: 914forme Oct 15 2015, 12:00 PM
Yes that is what I am liking about this design. And the fact that I can play around again a nd redo something I have done 3X times
Posted by: madmax914 Oct 15 2015, 12:12 PM
QUOTE(914forme @ Oct 15 2015, 11:00 AM)
Before I started this, I over analyzed it quite a bit, measured, re-measured talked to other members and felt like it should work. So depending on how it all goes I have Jamie(Jrust) to credit or blame.
Posted by: JRust Oct 15 2015, 12:22 PM
QUOTE(madmax914 @ Oct 15 2015, 11:12 AM)
Yes my genius is commonly misunderstood as idiocy
. How are you going to do exhaust from your Turbo?
Posted by: madmax914 Oct 15 2015, 02:04 PM
QUOTE(JRust @ Oct 15 2015, 11:22 AM)
When I bought the OF header I also bought an exhaust flange so I'll run 2-1/2" exhaust in to a single-inlet/single-outlet MagnaFlow muffler and out the rear of the car. I'm not sure what I'll do for tips. So the exhaust I got with the motor will go unused. If you have a need for it or know someone let me know. Besides it won't fit between the rear of the Subaru Transmission and the rear valance.
Posted by: JRust Oct 15 2015, 04:43 PM
QUOTE(madmax914 @ Oct 15 2015, 01:04 PM)
I'm just curious how you'll loop it back from on high. I'll come up to see when you get there. Am considering just adding a Turbo to my NA 2.5 so I'd end up doing something similar exhaust wise
Posted by: madmax914 Oct 25 2015, 07:19 PM
Finished the front bulkhead motor mount.
Posted by: madmax914 Oct 25 2015, 07:23 PM
If you look close you can see the Small Car motor mount brackets that I attached the motormount to. They sold me just the brackets that bolt to the Subaru block.
Posted by: madmax914 Oct 25 2015, 07:33 PM
It's difficult to see but the oil pan is just about level with the bottom of the tub.
Posted by: Mueller Oct 25 2015, 07:51 PM
Nice looking mount!
Posted by: madmax914 Oct 25 2015, 08:35 PM
QUOTE(Mueller @ Oct 25 2015, 06:51 PM)
Nice looking mount!
Thank you, it is working out better than I expected.
Posted by: Andyrew Oct 25 2015, 09:54 PM
Good job on the mount!
Posted by: mgp4591 Oct 25 2015, 10:41 PM
The mount looks pretty slick! What did OF charge you for the brackets only if you don't mind?
Posted by: madmax914 Oct 25 2015, 10:54 PM
QUOTE(mgp4591 @ Oct 25 2015, 09:41 PM)
$195+ shipping
Posted by: porsaru Nov 13 2015, 11:46 AM
QUOTE(madmax914 @ Oct 13 2015, 08:56 PM)
I have the motor and transmission in place so I can finish the motor mounts. The good news is the header and turbo fits nice between the motor and the firewall. There's about an inch between the turbo and firewall.
Are you considering flipping the intake manifold to shorten your charge pipe? Or possibly adding a water to air intercooler because the airflow for the air to air intercooler is not that great. I would recommend this addition while your at it.
Posted by: madmax914 Nov 13 2015, 01:58 PM
QUOTE(porsaru @ Nov 13 2015, 09:46 AM)
I have an air to air innercooler and tubing that came with the motor that I may work for me. This motor was previously in a 914 and he didn't have the intake flipped, I'll have to wait when at that point to see what I'll need to do. The passenger side of the motor will have the pipe coming off the turbo so there will be an issue with heat on that side so that leaves me with mounting one above the motor on the left side or even the rear trunk area. I'm very fortunate about an hour north of me is Extreme Turbo Systems, they can build custom innercoolers and the plumbing to maximize the effectiveness of the turbo. Stay tuned this just staring to get interesting.
Posted by: madmax914 Jan 11 2016, 04:15 PM
I'm a little disappointed to announce that since my progress report in October no major work has been completed on my car. I've purchased some parts for the final assembly but the last three months have been pretty difficult around our home with illnesses and surgeries. I'm looking to jump back on it later this month and get some good updated pictures and descriptions of progress.
Posted by: Gmanscott55 Feb 26 2016, 08:01 AM
QUOTE(madmax914 @ Jan 11 2016, 02:15 PM)
I recently purchased a subie Turbo conversion from a member in Scottsdale . Lot's of pics and info . Just pm me. Hope you are feeling better .
Posted by: madmax914 Feb 26 2016, 11:29 AM
I'm 100% and back at it, Just bought a FG body kit and looking to fit it to the car.
Gmanscott, did you buy Suby conversion built by Kent at Percision Chassis. That is an over the top awesome build.
Posted by: 914forme Mar 20 2016, 06:51 PM
Hope all is going better such nice workmanship on that mount, I can't wait to see the rest of the car!!!
Posted by: JRust Aug 18 2016, 11:57 AM
Whats going on? Haven't seen any progress buddy
