dizzy says it needs a 3ohm resistance coil......
aircooled.net says that the bosch blue coil isnt adequate for anything above 3k......
so...watcha runnin?
after i put the unilite in..... gonna wire up the hyfire box.......
Jake says Blue and I didn't argue.
Makes big power with it too past 7000 rpm.
you must have some long wires to run from the cab to the rear trunk....
speaking of.... how long is your coil wire(s) you have one of those cool thru the sheetmetal things
QUOTE (Aaron Cox @ Mar 7 2005, 06:15 PM) |
you must have some long wires to run from the cab to the rear trunk.... speaking of.... how long is your coil wire(s) you have one of those cool thru the sheetmetal things |
thanks david....
what is anyone else running?
Point of reference: MSD approves of Bosch Blue coil as acceptable, too.
I'm running it.
KT
QUOTE (trekkor @ Mar 7 2005, 05:06 PM) |
Point of reference: MSD approves of Bosch Blue coil as acceptable, too. I'm running it. KT |
Exactly 1.21 Gigawatts
