There will be a lack of progress on my car until I get this members 914 running with my v8 setup. The only requirement is that the engine will start, run, and move the car.
Below is my list of work to do.
Pull Fuel Tank
Replace stock fuel lines
Plumb fuel pump
Replace firewall shift bushing
Cut holes for radiator lines in front trunk
Mount radiator lines
Cut notch for HEI Dizzy
Clearance valve cover
Bolt up engine/trans
Bolt up cv joints
Install shoft linkage and adjust
Install distributor and carb
Install clutch, throttle and speedo cables
Wire starter, dizzy, alternator
Test fire
Flush coolant
Bleed brakes
Drive
Total hours involved is anticipated at 26 by myself. I origially agreed that the owner would have the car 100% ready for the swap and I would only have to do the v8 portion, (which I have a anticipated at 20.5hrs) however the fuel line issue, firewall shift bushing, and bleeding the brakes are all going to be done on a T&M basis.
Overall its a good looking body with a few dents and paint that shows its age. There is a bit of rust in the firewall and battery tray and some in the pass front door jamb, but the rear suspension console looks great. I think its a great candidate for a conversion.
That yellow will be a sleeper for sure.
Progress from last night.
Ready for installing the new prebent lines. Going to remove the shifter and rod and the fuel line grommet up front to hopefully make the install easier. I dont anticipate it to be fun...
Off topic: But what's with the oil coolers on the orange car... hmmmm
Were the OE plastic lines still good? Mine were. WD40 that front grommet and they will slip right thru w/o effort. Are you using Robert's or Chris' lines. Robert has a "how to" video for his lines. Probably the same for Chris'. 26 hr's huh? That's old age for ya. I take that long to decide if I want to, anymore.
Plastic lines looked good. Fabric lines were ready to explode.
To many 914 fires for me to let a 914 go through my garage without new fuel lines...
Slightly disappointed in thread title
I was hoping for "mini-V8" install, you know something in the 2 or 3liter department
Too much work for me....but you are young and driven.
Is the soon to be V8 car local?
San Jose local, yes. Member also has a 6 conversion.
I chose the thread title as my goal for this thread is 2-3 pages of how to and what all is required in a v8 build, showing how easy it can be.
Also an easy reference to the owner to see progress and how it all goes together.
Not sure how fast you work or your personal level of thoroughness, but FWIW, I'd multiply your estimated time for completion by at least 3 to be more realistic. Sometimes even the most mundane procedures eats up time.
MHO,
Sherwood
he is one lucky guy
and will be one happy guy very soon
but he will never be satisfied, ever
You crazy!
Progress from tonight,
Fuel lines in
Just kidding
Still have about 45mins to install the rubber lines tank side and put in the tank, then I can cross that out. Right on schedule
on my V8 car i cut that hole below the fuel lines much bigger so i can access the fuel lines easier and get clamps on easier.
I will likely take the typical route of making the hoses ~ 2.5' long and coil it up under the tank, this way I can remove the tank and set it on top with the hoses connected.
Firewall rust
The owner and I are discussing the possibility of me doing the rust repair.
A bit more digging of the rust. As I anticipated it was a bit more than what you could originally see. I see the longs are going to need some work as well. The firewall near the drivers side is pretty bad.
Drivers side below the battery tray
Yikes. The owner might want to delay engine install.
The owner has agreed to have me repair the rust. I'm going to stop at 20 hours worth of rust repair. It MIGHT be enough to do all the repair shown, we will see.
Got the easy ones out of the way this evening....
4.5 hours down, 15.5 hours of rust repair left in the books.
Going to cut open the firewall drivers side tomorrow morning. Then I'll see what else needs to be done in that area.
FYI Replacement metal is 16ga, a bit thick for the 18ga metal in there currently but eh, it works.
After all the firewall is fixed I'll seal it up and hit it with more galvanized primer for the owner to paint.
Pics
Nice work. Full service.
Progress from yesterday morning. Had a concert to go to so progress was stalled... 3 hrs down here.
I really debated even replacing this steel as its not part of the suspension console. But I didnt want to leave it alone. I did a quick and easy patch job on it and will seal it up today after I repair the firewall. Luckily the suspension console seems solid.
What is the gooey stuff on the weld line
Drivers side done
Now onto the pass side The suspension console has a small patch needed, then the engine tin tray could either be cut out or fabricated. Im going to ask the owner which one he wants me to do. So far 7 hrs today.
The answer was leave the hole and rip the battery tray out. Apparently he is going to relocate the battery and forgot to tell me.
SO we are DONE with the rust repair. 3 hours later. We have some time left on the books still but I have a good idea how we can use that
Fought a cold ALL week so I didnt make any progress durring the week.
This morning before Halloween prep I did a little bit of work.
Installed the firewall bushing
Installed the fuel pump and filters onto the new fuel lines
Cutout the holes for the radiator lines in the front trunk.
Installed new water and alternator belts.
Removed the exhaust as I didnt want to bother breaking the stub axles loose. Seemed like an easier option since there was no handbrake or anything and the piping was in the way of the CV joints. Luckily the bolts were not rusted and it only took about 40 minutes to remove the exhaust, Hopefully it goes back on that quickly..
Clearance for the dizzy and removed the hood torsion bars (Brett you'll need to order some trunk shocks or use a hood prop)
Mounted the new rear trani mounts and the trani 100%, and I got the front bolted up but not snugged up. The engine should raise about an inch once its all snugged up.
Had to use my mounts for the front since the car didnt have any on them, and the rear trani mount bolts had no nuts so I had to use mine..(Brett, you'll need to give me these AND the big bolts that go to the crossmember from your car) In doing so I saw that the front brackets from my car one of them was pretty damaged so I welded on a reinforcement to it. No pics of the repair with 1/8" steel.
So engine is in place and the rest of my time is all the little things.
Left on the list are....
Mount rad lines
Snug engine bolts
Install CV's
Install Exhaust
Install Shift rod and adjust
Install carb, dizzy
Install clutch,throttle,speed cables
Wire starter, dizzy, fuel, alt
Test fire
Flush coolant.
Bleed brakes
Drive
I will look for the mounts and I have the rear hood shocks. I was going to remove that torsion spring when I had the chance. So, that is good.
-- brett
Made some progress a bit last week and on Saturday.
The following is completed.
Snug engine bolts
Install CV's
Install carb, dizzy
Wire starter, dizzy, fuel, alt (New ignition switch in engine compartment. Either relay board is bad or the ignition switch is bad.)
Temp mount battery in engine bay
Left to do in order:
Install Exhaust
Test fire
Mount rad lines
Flush coolant. (Built a tube to connect the radiator lines at the front trunk to bypass the radiator. This will let the system flush the lines and prevent gunk clogging up the new radiator)
Bleed brakes
Drive
Everything is in!
As per normal v8 conversions the throttle cable is like pushing a brick, but the engine is really responsive, feels like it tuned it self when it was sitting
Tomorrow morning I am going to flush the water (i have engine flush in there now) and bleed the brakes to get some more pedal.
Biggest issue is the rear needs to be raised about 2" go get some ground clearance, its going to be a bitch to get it on the trailer... it scraped when I took it for a test drive on my very mild driveway.
Nice Andrew! That will be a kick for the owner first drive
Andrew,
Nice looking work...looks like a shop did it, impressive. Too bad you didn't have the matching paint, could have painted before the new v8 went in.
Nice looking welds, I have a gas set up for my lincoln, need to hook it up one of these days. How is your car doing, the audi engine in yet?
Dave
Jamie, I agree. This engine runs heaaaalthy... got it up to temp and reved it a little... I am sure gonna miss that.
Dave,
I could have got a pint of paint and sprayed it. I even considered doing it as a gift for the owner, but it would have taken many, many hours to clean up the firewall in such a way that the paint would have stuck well.
Audi conversion has been on pause for the last 4 weeks. All progress has been made on my thread
Im going to take the yellow car for a quick drive in about 15 minutes. Just finished doing my best with the brakes (something is broke.. likely rear calipers or proportioning valve as I nor the owner could get any pressure in the brakes. And I finished flushing the fluid.
Quick test fire
https://www.youtube.com/watch?v=wjAddAmtpRc
IT'S ALIVE!!!
Andrew,
You are a master metal man, what you spent 20 hours on would take me 20 months and not be near as clean.
Dave
Thats why I charge the big bucks
Thanks Andrew and great work!
Nice Work!
