Looking to buy some Euromeisters and all I see is 7's and 9's in 17" rims. Do the 17x9's fit in the rear with AA steel flares? If not, do they need major work (grafting in metal) or just some tugging.
Are you sure you want big heavy wheels that don't look right on a 914?
I have the same rims, except they are 16x9. And they do not fit, as I have 275 Hoosier's on them. Well, they fit but 2mm clearance is not enough for me.
If you use smaller tires they might fit.
I'm running Fixse 17x9. I have no problems fitting 245x40x17 street tires on the rear
255 will also fit if they don't have the curb rash rib on them.
17x9s Rota Fox Fuchs reps with 245/40 in the rear on mine.
The RS has 17x9 Cup IIs with 255 rubber.
We rolled the lips, but they would have fit without doing so.
John, I have a 10mm spacer on the rear to clear the inside and a 1/4" round stock rod bonded to the inside of my glas flares as a stiffener. I believe the 16 x 9 and the 17 x 9 euro have the same off set
Spacered to fit. QRS fiberglass fenders. 17X9.
Rear offset is 16mm. I believe that is stock 911 rear offset.
John - I'd take the subjective opinion that 17's "don't look right" with a grain of salt. To some this may be the case; to others maybe not. Nobody mentioned how the wheels "didn't look right" at the track recently and certainly didn't stop them from taking pictures of the car ALL weekend long. Performance wise, the 17"s are better choice for several reasons - no need to beat that to death. Regarding the fitment, I have AA steel flares and run the 7/9 combo. I have plenty of room but also have the flared rears. I run 245 Front & 275 Rear - no issue. Tons of room up front and I run a .5" rear spacer. All the best!
PS: The weight difference is negligible - I went fairly quick.
Tony
Tony, are those the RSR finish Rota Foxes? If so did you have any balance or vibration problems? If not I think I'm sold on them. They look awesome.
I agree the 17's are just too big for the 914. I don't like the 17's on early 911's either. Guess I am getting too old and set in my ways !
I know they are probably superior in performance and tire section has to be good.
I have 16 X 7 and 16 X 8 RSR finish Fuchs on my Six.
I also have a set of 15 x 7 and 15 X 8 RSR finish Fuchs, but tires are getting scarce.
I love the look of both the 15's and 16's on the 914 with M471 fenders.
They may be the same but mine are called Linea Corse. However, I can "only" tell you they are rock solid up to 158 mph. LOL!
The look obviously has a more modern flare to it but I'm always into performance before aesthetics. I try to blend the two when I can...
T
Cracker,
Your flares look different than mine, looks like the lip has been pushed out. I have stock (un-modified) GT flares and the 275 just will not fit. I would be interested in hearing what is different about yours. I need to get the tires to fit.
ya 17's suck, bahahaha!!
last pic 15vs17
Brett - Yes. Mine are modified/custom. Also, the Hoosier R7 have squared sidewalls that cause some folks issues (as opposed to the R6). Just another thing to consider if you're cutting it close.
T
i do luv my 15 x8 x9
that is 245/50 x 15 re71's
They do look good but tire selection in the 15 and 16 is horrible. I'd rather run a 17 with a wide selection of high performance street tires than have 15's or 16's and be stuck with competition only tires. Look where I live. All competition tires and most ultra performance street tires can't even be stored in a freezing environment. That leaves my garage out.
In my mind, the tire is what's important. The rim is just a means to an end. It's a bonus if I like the look. Thankfully, I just so happen to really like the RSR finish Fuchs.
with 9 in wide rims I believe the offset should be right around a et15.. and will fit with 255/40's.. inner lip might need some adjustment at worst..
Rota fox -euromiesters same thing right?
http://www.automotion.com/euromeister-alloy-replica-wheel-9x17-et-15-for-porsche.html
I bought mine from Wheeldude.com - I might of over paid but my RSR finish wheels were $350 each...7 & 9 with 911 offsets. Reciept says Fox...
Tony
Euromeister 16x9 15mm ET, AA steel flares. 245-50x16 had to trim the lip on the flare for clearance.
