So, I was given a lathe that had electrical problems.
I sorted those problems, and I am now looking for some simple projects so I can learn the machine.
My first thought is to turn some clutch pulleys out of brass. Do you have other suggestions?
Bronze suspension bushings.
Make a mount for a 911 head to spin the head on the main body of the lathe and then you can resurface heads.....probably not a beginner thing to do, but if you have some junk heads it might be good to learn how to make a decent jig.
Pedal cluster bushings.
Practice projects to get a feel for it.
Learn how to be precise and how much you can cut.
It's easy to start with store bought bushings from the hardware store and cut them from there, for instance the side shifter rear bushing...that is store bought, then turned to fit the exact need.
It wastes less material also.
Look for tephlon impregnated bronze, not brass.
Grainier has them....just find one that needs material removed, not added.
That's a pretty big lathe for making fairly small bushings. Drill bits and reamers aren't cheap either. That sucker looks like it was made to cut 3 feet of threads. Nice score.
Nice unit, we have the same one in our shop at work. Pretty easy to run, I use it from time to time on stuff...Enjoy !
Find an old retired machinist to teach you how to first-
1. grind cutter edges
2. set up a cutter in the toolpost at correct height and angles. . that's a 4 way toolpost and requires shimming cutters to correct height
3. show you the correct chuck rpm speed and correct cutter feed speed. The tendency is to turn too fast.
4. after all those, start on PVC or wood. . .
5 remember no matter how fast you think your reactions, hands and fingers are,
the chuck is always faster and a lot stronger.
It's not rocket science but it's easy to hurt yourself badly. . You might want to start
by positioning the machine and leveling the bed. Then make sure the headstock is parallel and perpendicular to the bed and center of tailstock. Determine the off center runout of the chuck. .Those Chinese chucks are usually spec'ed at .003 off center as the normal limit when new . If not set up properly, no matter what you do, your finished project will have taper and be out of square and off center.
I practice on the lathe at work and did some door stop rollers out of aluminum. Yes they are available but I figured the machine is there why not try it. Simple part.
I agree with all of the above, start small projects that at not important till you get the feel for it. Lots of on-line resources, it's a bigger learning curve than you think.
Don't forget the damn key in the chuck
I agree with all of the above: especially those about safety. Make sure that you wear proper clothing when operating this machine. Loose clothing can be deadly (around your neck) when picked up by the machine. Same goes for long hair, a necklace etc.
A good medium to start with is Teflon/Teflon. Get yourself a few chunks of that stuff and start with that. Teflon is quite soft so it will not affect your cutters too much.
One of the first things I did on a lathe was a knob for my Triumph's gear lever. First a specimen made from teflon, the second one from a alloy billet.
Menno
Get some Delrin or brass and make some of the rear trunk rollers for the torsion bars.
And watch those carbide bits. When they shatter they are like shrapnel- Safety glasses at all times!
Hey Joe! How bout a present or Christmas ornament for the new beh-beh? Congrats BTW Dad!
Nice .............. Beautiful Machine
I bought a 1930's belt driven version to check for out of round and cleaning up burrs. Not a clue on how to use it.
Chrome bezel gauge rings would be cool.
Wow!
Thanks for all the responses.
I'll try to post updates as I figure this thing out.
Make something square....
A test trinket,tolerances of +/-.003" ,in various alloys.
The nicest one I've seen was on the desk of the pres's office in chromolly,heatreated and ground,+/-0.0005".
Another was in hardened 52100,32 rms,CBN tooling,beautiful homogeneous finish.
http://www.cnczone.com/forums/general-metalwork-discussion/52757-making-large-quot-turners-cubes-quot-engine.html
http://www.cnccookbook.com/CCTurnersCube.html
Let's start with the basics.
What's the turning speed for various metals and other media?
How do I set the correct tool height?
Get a copy of Machinery's Handbook. It's the standard text for speeds and feeds and looks impressive on your bookshelf. If you have a half-price bookstore nearby, they often have a copy.
Thanks, Chris and Mike.
You can make anything you put your mind to. . .
My Chevy V8, most from scratch.
Crank took 2 weeks, cam 1 week. . both from solid round stock . the
roller rockers were the hardest because I needed 16 identical. .
You are in the fla machine belt,supporting nasa and have experts all around you.
Take advantage and prepare yourself accordingly,this is not an overnite,instant gratification endeavor.
I have seen and heard of too many horrible industrial accidents and have become skeptical of selfproclaimed 'gurus'.
Grenade training in the military is defined by strict protocols,so too should be the instruction and manual study of your new lathe.
Bone up on the tech,it's a tool of great versatility with which you can test yourself to get good at.
Getting great at it requires decades of practice and application.
The machine you have for cheap must be supported by the acquiring of tools of telemetry,500$ basically to start.
Electric drills and saws may be your experience to date,and if so,a period of training is needed,because it's the right thing to do.
Broaching allen sockets in titanium bolts on a manual lathe,circa 1981,<10pcs.
(edit)
Come to think of it,an ad for a part time machinist of skill may be an alternative way to part cost in labor and time.
Hire a machinist to make your swingarm bearing barrel or front upright to carry a driven axle!
I think I'll be getting this set:
http://littlemachineshop.com/products/product_focus.php?Focus=Cutting%20Tools%20Lathe
http://www.yellowpages.com/orlando-fl/machine-shop-tool-supply
These are some basic tools to get started,do try to be a csob as a money pit is right in front of you.
Planning is everything,make your plan,work your plan,plan to make a profit.
A wee Scotsman told us that in '68,the instructor of the course,of WW2 machining experience.
Know what you are doing before you start making chips,or you'll make chips of gold.
Much to learn of turning,there is.
https://www.youtube.com/watch?v=Za0t2Rfjewg
I'm guessing the lathe has no toolpost holders,which is why you're looking to purchase a set.
You won't need a large capacity,3/4" will suffice.
(edit)I see in the photo up top,the post you have will do fine for your application.
The quickchange holders are for production speed and repeatability,can be useful for toolroom applications,setup speed.
btw,
If your sump smells like shit,it is because there is shit in it.
You'll want to keep it as clean as a toilet bowl,at minimum.
An extreme biohazard,keep it off your skin,eyes,mouth.
Steph and staph out of the sump.
https://en.wikipedia.org/wiki/Necrotizing_fasciitis
http://fluids.doallsawing.org/products_detail.aspx?idcategory=cutting%20fluids&idsubcategory=cleaners%20%7C%20additives&idproduct=DOALL014
http://www.zepcommercial.com/product/Heavy-Duty-Citrus-Degreaser
I used to operate Lathes and Mills when I was a kid. My dad owned a machine shop so I learned from one of the best machinists. Of course I chose not to follow in his footsteps and haven't operated any machines since I was 18.
My suggestion is that you take some classes at a local vo-tech just to get a better understanding of the basics, which includes all the safety lessons.
https://www.google.ca/search?q=miniature+v8+engine&espv=2&biw=1280&bih=641&source=lnms&tbm=isch&sa=X&ved=0ahUKEwi81_6akZHKAhXIlx4KHUUWCqwQ_AUIBygC#imgrc=dLyA95qXWQQ22M%3A
Ya gotta appreciate the massive workload to achieve these works of machining art.
(edit:01/06/16)
http://www.craftsmanshipmuseum.com/dahlberg.htm
Mindboggling,dedication,talent,perseverance,skill...
I happen to have made a plastic model of this car along with a Stutz Bearcat in the early '60s.
Why I like it,the time and talent as applied to machine sculpture,as you would a fine Swiss watch.
https://www.youtube.com/watch?v=aoDFV_-FPrc
https://www.youtube.com/watch?v=08Rfvu7k2nI
https://www.youtube.com/watch?v=4L4Hj85Kb5o
You may find this illuminating.
" Here we show that a dense uniform dispersion of silicon carbide nanoparticles (14 per cent by volume) in magnesium can be
achieved through a nanoparticle self-stabilization mechanism in molten metal. An enhancement of strength, stiffness, plasticity and high-temperature stability is simultaneously achieved, delivering a higher specific yield strength and higher specific modulus than almost all structural metals."....wow!
I've worked with some amazing hitemp alloys,if they are referring to the top 3%,we have a new paradigm of power to weight across all applications.
Magnesium-SiliconCarbide Composite(MgSiC) conrods,pistons,valvegear,chassis.
Big changes coming.Wow.
http://gizmodo.com/new-magnesium-composite-has-record-breaking-strength-to-1749578336
http://www.nature.com/nature/journal/v528/n7583/full/nature16445.html
(edit:2/22/16)
Think of an engine block with cylinder bores of < 3mm wall thickness,an engine of half the weight.
Pistons weights allowing high rpm use,the temp stability to allow much higher velocities.
Who will be the first to offer a superleggara boxer engine for a ridiculously exorbitant price?
A 40 Kg advantage will eventually find it's way to a 914 engine bay.
12X36 and 13x40 import {China or Taiwan] lathes almost always come with a 6 inch camlock chuck with a D1-4 spindle mount. . Going up to an 8 inch chuck is double the rotating weight, A 6 in chuck is around 20 pounds, 8 in is about 35+ pounds,
You lathe looks to be a 12x36 with probably a 1 1/2 motor at best. A 6 inch chuck is what it is best suited to turn.
Consider what the HP is on the motor on yours. . .and the weight of the piece you are turning when considering a larger chuck. . Wanting to hold larger objects is why the chuck jaws are reversible and have 3 steps, once you exceed the limit of the chuck you should consider a bigger lathe to match a larger chuck. . .
A drill chuck is what is used in the tailstock, just like on a drillpress but with a Morse taper mount.
Once again, just my 2 cents, but think safety here. . flying metal is hard to stop.
grab a chunk of broom stick. make a contoured handle. pencil out a simple handle with some steps and dia changes. them try to make the wood look like your picture. my son just gave me a lathe. my first real project was to turn down the ID of a steering hub adapter. im having fun with it. this thread is awesome. thanks for the guidance
The horror technique was used on us in our teen years and effectively shocked us into a safety mode around machine tools.
The instructor was a WW2 vet of military discipline,the values imparted by strict rules of operation.
It is true some people have no business messing with them,at all.Case in point,a new guy tried to off himself twice in a few days.
Untrained,unwary and ignorant of the first premises of self preservation,he was dismissed with a recommendation to a trade school.
A shop coat caught in the lead screw of the lathe,panicked,screamed and was saved by me when I shut the spindle off.
Next day,'forgot'to clamp the barfeeder and had the turret lathe hopping off the floor,he froze.
Herbert No9,made in England,30-60's.https://en.wikipedia.org/wiki/Alfred_Herbert_(company)
Machine shop guys always have impressive stories. And there's 101 ways to get zinged. Was in a shop with an impressively large shaper, bed over 30ft. long. Me and a new guy were watching that head slide towards us, curling off .1 thk steel corkscrew. It hit the ground right at our feet and sounded as big as a garage door spring. He bent down to pick it up and I hip-checked him. He was affronted for a moment, but then we watched it slowly turn that same blue as a motorcycle exhaust pipe.
So, I had to replace the front wheel bearings on the right side of my Vanagon today.
The rotor looked pretty crappy, so I took the opportunity to put it in the lathe.
Success! It was the first time I used the power feed and it came out pretty well.
I'm going to want a nicer finish in the future, but definitely good enough for a brake rotor.
My oldest boy (14) seemed unimpressed as I was smiling with the lathe running. I told him he didn't understand the significance of what he was seeing.
Btw,
I was joking about making something square.
Love this place.
Now you too can make your own stroker crankshaft!
Go ahead,make your hay.
Note how spic n span his shop is.
A cap for the lathe top should have railings,to keep tee wrenches there.
Long stringy chips are bad,dangerous,and a sign of wrong.
Never mess with those chips while rotating!
Never.
I'll be turning that rotor again......
Lighten a flywheel
Lol, bet it was fun though.
Turning a brake rotor on an engine lathe is difficult at best in keeping both sides parallel. The problem is rotors are too damn big to get your cutter to both sides without unmounting the rotor and reversing it. Holding it on a regular chuck for both sides hasn't worked for me without a lot of set-up time with a dial indicator.
Best way is to use a 'faceplate', not a chuck to start.
Bolt the rotor to the faceplate using the flat surface where the car rim mounts. that way you are turning the back of the rotor parallel to the axis the rim spins on. .
Then reverse the rotor, mount the rotor surface you just cut to the faceplate. now turn the opposite side of the rotor. .
Theoretically both sides will be parallel and consistent with the axis of the wheel.
I kinda just skimmed through this post but with that said, I would also suggest investing in quality measurement tools. 1" micrometers and nice 6" calipers from mitituyo or starret can be had for reasonable prices. and like others have said checking the runout of the spindle and chuck assembly is important if you plan on your parts being true. A dial indicator with a magnetic mount should get you running true in no time. And as many others have said safety is most important.
Several factors in the machining of shafts.
1)The spindle rotates about it's center within 0.00005"/0.00008",under load.(the bearings are good)
2)The spindle is parallel to the bed in both axis.
3)The carriage moves true to the bed.
4)The cross feed saddle is square to the spindle.
5)The clearance gibs are adjusted to minimums.
A tuned instrument is needed to make a correct shaft,adjust the machine to do so.
Speeds and feeds for horsepower are the required knowledge.
Keep a table poster above the lathe for reference,noting the cutting(sfm) (Surface Feet per Minute)speeds.
A turned part in hardened metal can be finished to fine tolerances with these versatile attachments.
http://www.micro-machine-shop.com/tool_post_grinder.htm
http://www.cnccookbook.com/CCLatheTPGrinder.htm
https://www.google.ca/#q=porsche+904+main+shaft
https://www.google.ca/search?q=spherical+turning+attachment&espv=2&biw=1280&bih=641&source=lnms&tbm=isch&sa=X&ved=0ahUKEwiOgK_A1qXKAhVG6RQKHRFdCJEQ_AUIBigB
Learn something new every day,continuous learning.
Turning costs money,never turn for free.
(edit:01/14/16)
Quote:post#9
toolguy
....If not set up properly, no matter what you do, your finished project will have taper and be out of square and off center.
Correctomundo.
Pretty basic geometry,the setting up and fettling of the machinetool defines the results possible.
Direct measurement and trial cuts are required,then your efforts will satisfy you and 'customers'.
Nowadays,the price of indexable carbide tooling makes their use standard,tungsten and cobalt hss is perfect for delrin and bronze.
The manual and drawings that came with the machine makes the repair and maintenance of it painless.
The design of the headstock bearing may allow refurbishment,grinding a tighter clearance on a spacer ring.
Make,year,model,ser# and the fx# of the manufacturer is handy.
Never do repair work on the machine while under power,lockout rules apply.
You might want to consider building a jig or faceplate that has lots of threaded holes in it to accomidate all the cars you work on, then you can reuse the jig for a few years
I wouldn't worry too much - the projects have a way of finding you. One of the most useful tools in the shop. For example, I used mine to copy some of your ideas.
I have a few Popular Mechanics year book of projects dated from around 1940. I found them when my Dad passed away last year. They kind of just assume that any guy is gonna have a metal lathe. One article is how to build a complete gasoline engine from scratch - a small motor for a model something.
They also assume that you have a plentiful supply of Model Ts, from which they make an astonishing number of things.
My Dad saved his allowance and bought a Craftsman wood lathe in the 1930s. It is a good as the day it was bought. Plan on a lot of projects
Useful attachment to mill splines on axleshafts.
A multipurpose mill/turn machine.
https://www.google.ca/search?q=lathe+milling+head+attachment&espv=2&biw=1280&bih=641&source=lnms&tbm=isch&sa=X&ved=0ahUKEwjbi62ru6nKAhXMSSYKHbK6DMcQ_AUIBigB#imgrc=OEAJfnkmXvAX6M%3A
This is NOT a beginner project and I'm not recommending to anyone, but I found it very educational in terms of what good custom lathe work looks like.
http://www.the-long-family.com/making_a_muzzle_brake.htm
https://forum.linuxcnc.org/forum/index/
Proprietary boards and motors have their place in manufacturing,and there are a number of heavy machine companies doing business.
http://www.dipaolocnc.com/
https://www.youtube.com/watch?v=9IAHUy9A4U4
Very expensive though,you would have to have the work to pay for it.
The beauty of the Emc2,now LinuxCNC is that the development costs were borne by http://www.nist.gov/
to circumvent the bottleneck of the manufacturer's constraints.
A fella in Wichita converted a heavy 1960's 20hp Cincinnati 5X Mill to do aerospace,cheaply with great success,cheeply.
Some sweat equity is also a prerequisite,the geometry of the machine defining the expenditures.Big=$.
https://www.google.ca/webhp?sourceid=chrome-instant&ion=1&espv=2&ie=UTF-8#q=machinetools+used+usa
The prices are dropping rapidly for burnt board machines.
Converting a manual machine to cnc poses additional,large hardware costs.
(edit)
https://www.youtube.com/watch?v=Nn1bJ3YAQdI
https://www.youtube.com/watch?v=mxxdq6y8z8M
https://www.youtube.com/watch?v=35tHYaDUmZQ
This is it,in action.
You should make a clock out of the rotor and hang it over the lathe......just cause
I have my first revenue project.
I'll be modifying 914 axles for 944 CVs.
That should be a good one, because .001 precision isn't critical.
Updates will follow.
Oh no....
Broaching or shaping,rolling or milling?
https://www.google.ca/search?q=spline+shaping+on+lathe&biw=960&bih=480&source=lnms&tbm=isch&sa=X&ved=0ahUKEwjequLGmY3LAhXorYMKHc27AjEQ_AUIBygC
https://www.google.ca/search?q=rope+thread+rolling+lathe&espv=2&biw=960&bih=480&source=lnms&tbm=isch&sa=X&ved=0ahUKEwiUi4z0lY3LAhWkg4MKHc-nATAQ_AUIBigB#tbm=isch&q=thread+rolling+process
https://www.google.ca/search?q=spline+milling+on+lathe&biw=960&bih=480&source=lnms&tbm=isch&sa=X&ved=0ahUKEwiHyNuCmo3LAhUjuIMKHS8QBjEQ_AUICCgC#imgrc=NZ_IjncQ_R52HM%3A
Or you could trade your lathe for 250 beanie babies...
https://nh.craigslist.org/bar/5416282872.html
Observations from the mind of a beginner on the lathe:
Not having quick-change tools with adjustable height is complete bullshit. That will be corrected shortly.
The "simple" task of chucking a lug nut is not simple at all. It's almost impossible to get them to spin true. I have discovered this is because the bolt head and the threaded shaft are not necessarily manufactured on the same axis. This makes the "easy" task of turning a flat shoulder out of the conical seat very difficult if you want it to be perpendicular to the axis of the threading.
With the (?) tooling I found with the lathe, I can face steel at about 1mm per pass at 260 rpm. If you get greedy or impatient and go for 1.5mm per pass, you will be looking for another tool.
I ruined a parting tool, so I need more information on its correct use. Once I ruin the tip on a parting blade, how do I fix/sharpen it again? Can I?
On a positive note, I was able to put that brake rotor I ruined back on the machine. I got the wheel face turning within .001" and was then able to make the braking surfaces do the same. On my previous effort, I had managed to turn the outer face to a runout of .006" and the inner face to .01". Ouch.
Nice clock
I don't want to pay the price, but it looks like I'll be buying an Aloris BXA tool post and holders. I found a set for around $650, but I'm still shopping for used.
Chinese sets can be had for less than half that, but I think I'll eventually replace my Chinese lathe with a good one, so I might as well start assembling good tooling.
Look at KDK style first. . much better and a lot easier to use. . there use to
be a seller that had Tiawan copies which are just as good. . holders are about $20 each. . It's the toolpost that is expensive. . Get the 100 size
This is an excellent deal. . full set with 8 holders $350 buy it now
http://www.ebay.com/itm/Lathe-KDK-100-Quick-Change-Tool-Post-System-PLUS-8-KDK-holders-/191755917200?hash=item2ca58b1790:g:kVUAAOSwHQ9WZ2KZ
I use Aloris BX series. They have sales on a regular basis.
I use their .087 wide carbide parting tool inserts (with someone else's holder I think).
Where is the height adjustment on those?
There are allen set screw in the top and bottom. . these can be turned over so 2 cutters can be set up in 1 holder. .each side with different heights
Yes, these are primarily a West Coast thing. . all the areospace industries of the 90's used them. . can't understand why they never caught on in the East. .
I like to use what's called a "dial test indicator" for setting up stuff on a lathe.... different than a "dial indicator". The feeler nub has less range of motion but it springs back to position on its own.
About the issue with the lugs having multiple axis for the heads/threads, you can use a 4 jaw independent chuck, vs the universal 3 jaw. They take longer to set up but more accurate. The test indicator becomes very handy with an independent chuck.
How can you inform your neighbors that it's noon each day, and practice on the lathe....and impress all your friends.
https://m.youtube.com/watch?v=YH4ereLJWtY
https://www.google.ca/search?q=lathe+tool+height+setter&espv=2&biw=1280&bih=641&source=lnms&tbm=isch&sa=X&ved=0ahUKEwi_5sXnsunKAhWIrYMKHYCVBUsQ_AUIBigB#imgrc=bNIb7EMPqcWc9M%3A
Quick height setting.
BTW,buy a few sets of feeler gauges as shimpacks,under the tool,handy,< 20$.
(edit:2/09/16)
A boxfull of shims,cut from shipping strappings,burr-less and flat.<5$
How we set our tool IC,circa 1971,1967-VDF Boehringer.Optical Microscope.
https://www.google.ca/webhp?sourceid=chrome-instant&ion=1&espv=2&ie=UTF-8#q=VDF+Boehringer
Most of all these are all solved techniques,doing it for like,forever.
https://www.google.ca/search?q=wartime+women+machinists&espv=2&biw=1280&bih=641&source=lnms&tbm=isch&sa=X&ved=0ahUKEwiMyrXyt-nKAhWDsYMKHSkcAlgQ_AUIBigB#imgrc=JNOF9vsdonD5SM%3A
(edit:2/23/16)
https://www.google.ca/search?q=carbide+insert+ic&espv=2&biw=960&bih=480&source=lnms&tbm=isch&sa=X&ved=0ahUKEwi6_pSLm43LAhXjn4MKHQMgDzQQ_AUIBigB#imgrc=rCNqs2bbXrH_-M%3A
The nose radius of the tool in the picture is not the IC of the tool.
The nose radius is a variable to which compensation is applied on manual,nc and cnc machines,when radii or slopes are machined.
In general,a nose radius imparts it's form to shoulder intersections when using manual machines.
For a larger shoulder radii with a smaller nosed tool,'stair-step' the large rad using trigonometry calculations of gradually finer resolutions.
Making your own bushings is a handy skill.
Turning(cryogenically) dry-ice or nitrogen frozen rubbers and plastics calls for hss tool grinding and diamond honing.
Form tool geometry for those materials and some light metals requires high positive rake.
A carbide ball tool in a die grinder can create a groove in the top surface of the hss shank,a kind of 'moat'.
The relief flank is then ground to give a .005/.007" wide top face and positive chip rake.
With some practice and a toolmaker's microscope,a <16rms finish can be achieved.
https://www.google.ca/search?q=shadowgraph+inspection&espv=2&biw=1280&bih=641&source=lnms&tbm=isch&sa=X&ved=0ahUKEwjhupPbr-zKAhWlk4MKHRz1AvcQ_AUIBigB
http://www.graphalloy.com/html/type_317.html
(edit:2/23/16)
Generally,the use of old tech is cheap in terms of tooling costs,high in labour for the grinding of tungsten and cobalt HSS,or B-CARs.
The first error with either tool type will destroy the tool and or part,forcing a restart from the beginning.
A brand new indexable insert tool holder will allow some leeway for miscalculated feeds and speeds.
Know what you are doing before the tool touches the part.
https://www.google.ca/search?q=hand+grinding+hss+lathe+tools&espv=2&biw=960&bih=480&source=lnms&tbm=isch&sa=X&ved=0ahUKEwjV8ZKlrY3LAhUCmoMKHbYTBjIQ_AUIBigB#imgrc=yeBxuxkzkYIx6M%3A
Seriously
Thread rolling for fun.
https://www.google.ca/search?q=thread+rolling+head&espv=2&biw=1280&bih=641&source=lnms&tbm=isch&sa=X&ved=0ahUKEwi5u8rTv-zKAhUklYMKHa-zABAQ_AUIBygC#imgrc=G4I0PmuZ6LetkM%3A
Thread turning on a lathe:
https://www.google.ca/webhp?sourceid=chrome-instant&ion=1&espv=2&ie=UTF-8#q=thread+turning+on+lathe
Pitch diameter,metric,thread series,3-wire measurements and calculation of fits.
https://www.google.ca/webhp?sourceid=chrome-instant&ion=1&espv=2&ie=UTF-8#q=buttress+thread+specification
Need to know.
https://www.google.ca/webhp?sourceid=chrome-instant&ion=1&espv=2&ie=UTF-8#q=metric+thread+specification
[quote name='Mueller' post='2285347' date='Jan 5 2016, 09:23 AM']
[quote name='Series9' post='2285343' date='Jan 4 2016, 12:14 PM']
[quote name='veekry9' post='2285327' date='Jan 4 2016, 02:19 PM']
[/quote]
So funny but not ,the same thing happened in our machine shop the apprentice started the lathe with 3 jaw chuck key in and the guy next door wore it in the nose,blood everywhere...he had a few days off to recover.
Seen some nasty accidents with hot swarf (turnings) sticking to faces or people clearing swarf and receiving nasty cuts to the bone,this stuff can be very hot and super sharp.
Enjoy your lathe ,there is so much you can do with them,but safety is foremost
Well,a trick to the key is:
Every time you engage the spindle,
"Say Key Please"
rhymes with "say cheese please".
Getting a chuck key in the eye is a harsh first lesson.
Danger will robinson,Danger.
Try this,turn your crossfeed handle into the tailstock or chuck(off).
Be certain neither of those immovable objects move.
Use medium pressure.
With a felt pen ,mark the dial at 0.
Gently,turn out until you get movement indicated.
Read off the difference,that is your backlash clearance on the crossfeed acme screw.
0.005" is like new,0.030" is buggered,the crossfeed saddle must be linear in movement to .0005".
Don't worry,it,the aluminum-bronze threaded crossfeed nut may be replaced or repaired.
https://en.wikipedia.org/wiki/Trapezoidal_thread_forms
Fun isn't it?
They actually make self-ejecting keys; the machine shops at school have them to keep kids from throwing keys. They are the most frustrating things in the world when you're trying to delicately clamp something though.
http://www.ebay.com/itm/like/181249515436?ul_noapp=true&chn=ps&lpid=82
See?
Someone is always coming up with a better mousetrap.
Not once did the idea come to mind,because we always remove it before turning.
An idiot proof chuck key would be a hot seller.
Kudos.
When I first got my South Bend, it was a whole new experience for me as I'd only used production lathes with carbide insert quick change tooling and cnc controls - it's very different with a home lathe using hss bits that can be sharpened. I often use the 4 way switching tool holder seen below. Sometimes the old school tool holders can be more versatile, but I can only use 1/4" bits that way, where the 4 way can handle 3/8" bits.
The most important aspect to forming bits is the end clearance angle. If there is not enough, the tool will ride on the part, bit gets hot and dulls quick. Too much angle and you also have a bit that will dull prematurely.
It's helpful to get preformed bits if you're just starting out. It gives you something to go by, just grind the same shape further down the bit.
http://www.mcmaster.com/#lathe-bits/=112bdwg
Parting is the hardest operation. The trick is flood coolant.
My 1931 south bend.
Nice condition.
Here it is! My first part to go into service. It's a custom hub spacer for a T34 swing-axle car that has T1 rear brakes.
Yes, it took me 4.5 hours to make.
What did I learn?
Start with a piece of metal that's as close to the finished size as possible.
The 1.75" OD on this started as a "free" 3" solid piece of round stock.
Not bad attempt there Joe,
Watch the outside diameter.
Original bushes are precision ground to a fine micron finish where the lip seal runs.
A turned finish using a HSS tool with coolant will not be good enough.
It'll wear the lip seal within a few miles and your brake hub will be full of oil.
I think the clock is really the first production piece
Well, keeping time is important.
I think it's pretty cool you made a custom part for a client, well done go have a beer
Here are my tail stock parts.
I don't see a way to mount the drill chuck. Is this called a Morse Taper?
What size is it? I need to find the piece to mount the chuck in the tail stock.
You need an arbor that goes from morse taper to jacobs taper probably. Looks like morse taper 3 from here. Here's a link to some dimensions you can check to be sure
http://littlemachineshop.com/reference/tapers.php
Some chucks are threaded, too, though.
here's the page at mcmaster-carr
http://www.mcmaster.com/#drill-chuck-arbors/=116h0wj
threaded chuck?
Rich
It looks like the tail stock is an MT3. The numbers don't match the chart exactly, but pretty close.
The drill chuck, however, doesn't really match any of it. It does appear to have a taper that's about 1" long and about .670" at the big end.
From the pictures it looks like you need a Morse to Jacobs taper spindle as Nathan also thought.
My advice is swap the chuck for one that takes a Jacobs key. The self locking chuck like you have are great in a hand drill, not so good in a lathe. You cant tighten them up very well and then they can "work-lock" and then you cant get the darn things undone.
Sounds to me like mt3 to jt6, which is "2811A37" part number at mcmaster.
Nice, making chips and a part for a project car even better!
my brother just got a little 6" atlas . its smaller than he wanted but it was cheap. he rebuilt it and is starting to make stuff now. he's been watching utube videos for years so he knows alot. weve been melting aluminum down and making soup can ingots to turn down into stuff. he already made a 4 slot pulley that the lathe was missing now he is going to attempt to make some gears that its missing. He hasnt tried turning steel yet I think hes a little afraid
Will someone explain the different uses for these different angles?
It’s all to do with available clearance between what your turning and the position of components of the lathe.
Most standard tip tools are design to sit in one position (90 degrees to the lathe centre) in this normal position the angle of the tip is optimised to turn down or face off.
If you have a rotating tool post you can fit several tools and spin it in 90 degree increments to change between say a parting off tool and a facing off tool. The clamp mechanism allows a small say 10 degree misalignment from North, East, South, West positions where you can clamp it correctly. However if you try and set it a 45 degrees (NE) for example, the clamp device doesn’t lock correctly and the tool will be off Height.
It’s always good practice with a tip tool (particularly with radius end tools) to change the angle slightly between jobs so that it’s not cutting on the same point all the time.
Different finishes can be achieved with different tool angles. (These are angles in the horizontal plane and can be described as angle of attack)
Different angles in the vertical plane (called “Rake”) come into play with HSS tools especially with differing materials. On a soft material such as aluminium you need a larger rake angle than for steel.
Large radius ended tools of HSS are commonly used for a fine smooth shiny finish
Tipped ceramic tools tend to be pre manufactured by material type where best speed and material are specified.
This begins to get complicated when you adjust the tool slide to produce tapers or to reach around the job to gain access to turn awkward shapes, turn with the lathe spinning in reverse or Left hand turn. That’s why you can buy tools with various position tips in the holder. It’s to optimise the angle of attack that the tip of the tool makes contact with the job under various positions and types of RH or LH turning where the tool post angle is not at 90 degrees to lathe centre.
That said some angles of attack vary dependent on the material they are designed for in addition to having differing rakes.
All of this means nothing if you don’t have the correct speed and feed for the material.
Looking at the photo from left to right; the 6 tools run RH, LH, LH, Universal, RH
Hope this is of help.
Good information. Thank you.
I think I understand angle of attack, but I need more on rake. While I understand the rake plane, what is an example of zero rake vs high rake?
Does the tool always intersect the piece at the 270 degree point in the rotation? (270 being the point that represents west if you look at the chuck end-on).
Also, when you say Right-hand and Left-hand, is that a reference to the direction the tool is moving against the piece or the direction the piece is spinning in the lathe?
I'm under the assumption that almost everything is turned in a CCW direction at the chuck.
https://www.youtube.com/watch?v=vAo0xmDQ-kI
https://www.google.ca/#q=turning++4130+shaft
https://www.google.ca/search?q=turning+4340+shaft&espv=2&biw=1097&bih=549&source=lnms&tbm=isch&sa=X&ved=0ahUKEwiVwLrjzonLAhXE6x4KHbEaDPIQ_AUIBigB
http://www.weldingtipsandtricks.com/welding-4130.html
Machining Fundamentals
https://www.google.ca/search?q=Machining+Fundamentals&biw=1097&bih=549&espv=2&source=lnms&tbm=isch&sa=X&ved=0ahUKEwjzkdS4vYnLAhVM2R4KHZDzBXwQ_AUIBygC&dpr=1.75#imgrc=PSEM_xr18tvY8M%3A
The design of the lathe makes the CCW rotation load the the toolpost and carriage in compression.(pushing down)
For similar CW loads a secondary toolpost can be installed on the other side of the CL.
As an example,during the '70s while using VDF engine lathes,a shaft similar to the one in the ytub above was ruf turned in conventional
ccw rotation using all 6 corners of the indexing toolpost,heavy production turning.
http://www.carboloy.com/company.html
Subsequently,the final finishing passes were turned with a cw rot and the hydraulic tracing attachment installation,whereby the carriage radius was servo controlled.
A 1:1 scale template was held in sync with the actual shaft and guided the rear crosslide with several paths to the correct dimensions.
The point of all this is that every year since,there has been progress in materials and methods and a steep learning curve is needed to 'bone up'.
Basic,elementary concepts are easily available freely,worthwhile study for the proper use of the machinery.
A horror story:
In 1979 a recently purchased cnc mill was programmed to zig instead of zag by an error of polarity,negative,not positive.
The 7/8" drill in the spindle,about a foot long,snapped off at the shank and struck the operator,the shop owner,between the eyes at the bridge of his nose.
He fell to one knee,hand over his face then staggered to his feet,a golf ball sized lump swelling on his face.
I got him an emergency ice pack from the freezer,and he left for a few days off.
What I mean is,is that even expert machinists make mistakes,had the broken drill penetrated his eye,it would have been fatal.
The energy needed to break the drill and travel the 20-30 feet after striking him,was from the rapid travel rate of the mill and the M42 steel strength of the drill.
Prepare yourself for the proper use of machine tools,period.
Exercise caution and due diligence and read the manuals,warnings and safety notices.
Never run the machine without safety glasses or masks.
Never.
ref.
http://www.ebay.com/itm/20-x-157-VDF-S500-ENGINE-LATHE-W-TRACER-ATTACHMENT-27503-/371318352994?hash=item56744c6c62:g:~wAAAOSwstxVQ8sM
20__x_157__VDF__S500__Engine_Lathe_w_Tracer_Attachment_27503___eBay.html ( 248.74k )
https://www.google.ca/webhp?sourceid=chrome-instant&ion=1&espv=2&ie=UTF-8#q=dana+summit+bandit+II+cnc+mill
https://www.google.ca/search?q=lathe+tool+geometry&espv=2&biw=1097&bih=549&source=lnms&tbm=isch&sa=X&ved=0ahUKEwjqn4qUgIjLAhWFWh4KHc3HAskQ_AUIBigB#imgrc=gb-lXnx3BrxfKM%3A
http://www.metalsdepot.com/catalog_cart_view.php?msg=
http://www.ingersoll-imc.com/en/index.htm
https://www.google.ca/search?q=carbide+insert+tooling&biw=1097&bih=549&espv=2&source=lnms&tbm=isch&sa=X&ved=0ahUKEwiOqt6ruonLAhVBFh4KHdPPBKAQ_AUIBigB&dpr=1.75
The industry is so vast that learning the right question is in order.
The grinding of HSS and brazed carbide tools is a whole subject in itself,safety paramount.
Learning to sharpen drill bits to a tested standard is a part of a machine trade training course.
Turning a simple shaft to +/-0.0003 was demonstrated,the experience evident.
Simple errors would get it wrong and useless,making scrap for double or triple loss.
Safety errors cost more than money.
https://www.youtube.com/watch?v=otifkak5RMA
Good stories of success by innovation and effort.
Just when you think you learned something new,something new must be learned.
The RH,LH refers to the offset of the tool's shank,ie:a left moving tool has a RH offset shank.
http://www.cmsna.com/blog/2013/01/history-of-cnc-machining-how-the-cnc-concept-was-born/
http://www.practicalmachinist.com/vb/cnc-machining/nc-punch-code-paper-tape-174794/
https://www.cncci.com/resources/tips.htm
http://www.fadalvmcparts.com/history.html
http://www.haascnc.com/home.asp#gsc.tab=0
http://www.heidenhain.com/en_US/products-and-applications/cnc-controls/
http://www.fanucamerica.com/
http://w3.siemens.com/mcms/mc-systems/en/automation-systems/cnc-sinumerik/sinumerik-controls/pages/sinumerik-controls.aspx
http://www.toshiba-machine.com/departmentlanding.aspx?dept=2
http://www.fidia.it/en/prodotti_en.htm
http://www.selca.it/index.php?id=selca
http://www.gruppoparpas.com/products.aspx
http://www.fptindustrie.com/en/products/boring_machines/3/
https://cache.industry.siemens.com/dl/files/554/74475554/att_56792/v1/PGsl_0313_en_en-US.pdf
https://cache.industry.siemens.com/dl/files/795/21904795/att_62564/v1/229_800_WS800A_Cycle_Language_CL800_Plannig_Guide.pdf
Information Overload.
There is so much data to absorb,a small step approach can be effective.Training is crucial,if only for the safety lessons.
Buy a programmable calculator to do the formulas for feeds/speeds/hp/ruf-rms/,just to be in the ballpark,on the same page.
https://www.google.ca/search?q=programmable+calculator&espv=2&biw=960&bih=480&site=webhp&tbm=isch&imgil=6ASUw0c1UIRqdM%253A%253BuY7w0wSpcS092M%253Bhttp%25253A%25252F%25252Fwww.vrcworks.net%25252Fblog%25252Fhow-to-identify-calculator-is-programmable-or-non-programmable-calculator%25252F&source=iu&pf=m&fir=6ASUw0c1UIRqdM%253A%252CuY7w0wSpcS092M%252C_&usg=__mxgLgHYx1JHgyjlCEt36eqW_2hM%3D&ved=0ahUKEwiTvLGZoo3LAhVnuYMKHeqPCTMQyjcIMA&ei=Y_3LVtP-MefyjgTqn6aYAw#imgrc=6ASUw0c1UIRqdM%3A
An actual 'real' tool grinder is needed to prepare hss or brazed carbide tools for turning,with the correct abrasive wheels.
Learning of the proper terminology and functions of the lathe controls and components is step #1.
Cutting rates are the next subject,tool geometry the next after that and so on.
http://www.cnccookbook.com/MTCNCDictDeflecttoFollow.htm
A good single source of info,handy helpful references for machining.
LH & RH tools and examples of where they are used.
http://s265.photobucket.com/user/DarrenLCollins/media/3-5_zpstjrvdild.jpg.html
Rake angles (side and back rake)
http://s265.photobucket.com/user/DarrenLCollins/media/GrindingLathe07_zpsdhqhhm2e.gif.html
More questions:
How do you run a finishing pass with this tool if you need to complete the pass at a 90* angle on the right side of the pass?
A good example of the need to do this would exist on crankshaft main journals.
The direction of travel on this makes no sense to me.
Do you have to set it up so the cutting surface is precisely parallel to the intended finish?
How do you begin the cut? Do you move the tool in to full depth and then move it to the face to start cutting? That scenario would require a lot of tool surface cutting all at once.
It seems like you would move the tool from the outside toward the center.
Scope,
the overall scope of the task at hand is knowing the the machine will hurt you if not operated correctly,as I've pointed out.
Evidently,a new career in shafting is not in the plan,but obviously if the standards of reference are unknown to you,the links have all the info available.
And yes,everyone who has taken the curriculum has asked the why of the LH/RH question,it's good that you asked.
I believe it came about a few hundred years ago at the very beginning of the 'industrial revolution',while turning bronze cannons,by hand.
The tools were used in a way similar to wood spindle makers,the tool levered to the right hand to turn left,the iron tool shank offset right.
The right hand thread derived it's name from the same roots,the lathe CCW rotating.
Take note that some of the drawings,from 1914 as above,are greatly exaggerated for visual clarity.
The difference between the lh and rh is annoted,for those falling off the turnip wagon.
(A stunt was to draw a face on the back of his head,stumping some beginners!)
http://www.nspe.org/
http://www.astm.org/
http://www.sae.org/
https://www.ansi.org/
https://en.wikipedia.org/wiki/BSI_Group
http://www.iso.org/iso/home.html
https://en.wikipedia.org/wiki/Metric_(mathematics)
https://www.google.ca/webhp?sourceid=chrome-instant&ion=1&espv=2&ie=UTF-8#q=metallurgy
https://www.google.ca/search?q=involute+splines&biw=1097&bih=549&source=lnms&tbm=isch&sa=X&ved=0ahUKEwimvJmKiIrLAhWBVh4KHfuID7UQ_AUIBigB
https://www.google.ca/search?q=involute+splines&biw=1097&bih=549&source=lnms&tbm=isch&sa=X&ved=0ahUKEwimvJmKiIrLAhWBVh4KHfuID7UQ_AUIBigB#tbm=isch&q=splines
http://bbs.homeshopmachinist.net/threads/60789-Pin-measurements-for-involute-splines
https://www.google.ca/search?q=thread+turning+on+lathe&espv=2&biw=1097&bih=549&source=lnms&tbm=isch&sa=X&ved=0ahUKEwjVrL-1jorLAhWHJx4KHYbcAeQQ_AUIBigB#imgrc=uC1URScmeD2ycM%3A
https://www.google.ca/search?q=lathe+tool+rake&espv=2&biw=1097&bih=549&source=lnms&tbm=isch&sa=X&ved=0ahUKEwil64XhgIrLAhXC0h4KHRHrC5cQ_AUIBigB#imgrc=cqzPDxLma0rFDM%3A
http://www.amazon.com/Eshbachs-Handbook-Engineering-Fundamentals-Myer/dp/0470085789
http://www.sandvik.coromant.com/en-gb/pages/default.aspx
Here is a demo of the spline or involute gear forms possible on your lathe.
And how he did it,a most useful idea,though an additional heavy disc brake would ensure the stability of the chuck.
https://www.youtube.com/watch?v=lqreWsmXG4k
https://www.youtube.com/watch?v=BgGXQUeYNKw
Yes,I used this technique recently a few years ago on a heavy 12' X 8' 20T platen.Broaching or shaping by cnc,a keyway or spline into a stationary bore.
I also like the RC heavy equipment he built.
https://www.youtube.com/watch?v=rt8VfgfWa54
The answers to the most basic questions are on page 2 of the manual.
https://www.youtube.com/watch?v=Hjsfs49SRbc
Dedicated tooling and machinery,expressly for the manufacture of crankshafts.
A manual lathe can be used,however,it is a long laborious and expensive process of many steps.
The tools are designed for their single purpose,hence the designation of their names.
The toolpost on the lathe must be indicated to index true,the tooltip must be at the vertical centerline of the shaft.
While threading shafts,the compound slide must be set at the correct angle and zeroed.
The stops must be set to avoid crashes,the speeds and feeds calculated beforehand.
The correct operation of the lathe's feedscrew and halfnut phase dial must be known.
The use of the headstock gearbox also must be understood.
Boring tubes and holes is a primary task,broaching or scraping rifling grooves another.
Drilling deep holes,undercutting and relieving bores is more.
Heavy grooving tools are the methods traditionally used to ruf out crank billet bars.
Offset and steadyrest turning and grinding of cranks is a whole science and skillset by itself.
A 4340 forged 16' X 5' stroke marine crank was done a decade ago in the shop,from scratch to ground finish.
Many tons of chips made,without error,a thing of beauty,by one guy,who had survived a bad accident in '04.
https://www.google.ca/webhp?sourceid=chrome-instant&ion=1&espv=2&ie=UTF-8#q=machining+merlin+crankshafts&tbm=vid
https://www.google.ca/webhp?sourceid=chrome-instant&ion=1&espv=2&ie=UTF-8#tbm=vid&q=machining+large+crankshafts
Some useful drops of info,the iso tooling from Walter is just what you might need.
Other vendors sell competing tools too,so buy the lowest price possible.
As mentioned earlier,the hss and brazed carbide tooling is cheap,but requires expert grinding to achieve good results.
These tools,with the quickchange holders,will have you up and running in a jiffy,painlessly.
Jurassic,some retro tools for the small hobbyist user,making the choice easy.
https://www.google.ca/webhp?sourceid=chrome-instant&ion=1&espv=2&ie=UTF-8#q=turning%20feeds%20and%20speeds
http://www.walter-tools.com/en-us/tools/standard_products/turning/overview/iso_turning/pages/default.aspx
http://www.jurassictools.com/store/tools-engineering-etc
Walter:external::screw type:
http://waltertools.blaetterkatalog.de/gc2012/en/#page_A80
https://www.youtube.com/watch?v=7cXBXewS4IM
A trip to the wreckers,an old rusty crank brought to new life by dirty '30s tech.
A little pickle to remove the rust,then a shoestring polish.
All of this came from before,the T Fords and babbit bearings.
This low level flying,or retrotech can be applied to your VW crank if you are looking to stroke for a larger displacement.
A few passes of weld,turning and grinding,and presto,a piece of work.For the all hands on deck type of machiner.
https://www.youtube.com/watch?v=j7DZxqPUQto
http://175.103.60.140/globalindo/carbon-steel-s45cst60aisi-1045/
An entire industry was built out of this,this enterprising approach to the make it better cheaper and faster equation.
http://www.hotvws.com/catalogs-2013/2/
https://www.youtube.com/watch?v=6lfpip4u-pA
http://www.914world.com/bbs2/index.php?showtopic=273101&st=52
The details of the'Hopping Herbert'is entertaining to some degree.
Must have been late'70s,an aquaintance of the shop owner,looking for work,I suppose the music biz not panning out.
A simple collet chuck turret lathe series of operations.
https://en.wikipedia.org/wiki/Oxygen-free_copper
Copper alloy bar 1-1/2"dia X 20'length.
Well,neglecting to clamp the barfeeder clamps,the bar,unencumbered,began flapping around the back end of the heavy lathe.
From the other side of the shop,I saw the heavy'wire'create a giant spiral whipping about at high rpm.
Crossing the plane of the whirling,hopping mass,I stopped the spindle,again.
The unbalance of the unique creation had been lifting the Herbert almost a foot,noisily.
When I released the collet,the Danish bun looking thing came out without breaking,the plasticity of the material saving us.
Had it broken,the spinning wheel would have raced around the shop wreaking havoc at 1200 rpm.
Needless to say,that ginger was frozen in fear,the ashen pale look on his face said incomprehension.
A common household 12ga wire might show the same results if spun up in a hand drill.
Safety:
Brings to mind the'starting plane',that,which is directly in line with the chuck and work.
Always stand clear of the projectile plane,when starting the spindle,ensure no tools can fall off into the spinning chuck or work.
A place for tools is in safe areas only,secured.
Make a box for them as required.
Ok……home from work now.....
Lets get down to basics….
There are 6 important angles to understand on a simple HSS lathe tool. The best illustration I can find is this.
http://s265.photobucket.com/user/DarrenLCollins/media/Toolbit_zpsuhdhtvtm.gif.html
Looking down on the tool you have front and side cutting angle. This relates to cutting in line with the lathe or across it (turning down or facing off).
These angles can be set or fixed by grinding the tool or by clamping the tool post at differing angles.
Back rake and side rake are in the horizontal plane and I think were the ones perplexing you? These refer to the top surface of the tool. It can angle downwards to left or right (side rake) in LH or RH tools and angle back towards the lathe operator (hence back rake angle)
Side relief and front relief are in the vertical plane, and hopefully self explanatory in the picture above.
I have been making lathe tools for over 40 years and I’m a qualified toolmaker for my sins, yet I'm still learning stuff. Here’s a few home made basic samples in “proper” High Speed Tool Steel.
http://s265.photobucket.com/user/DarrenLCollins/media/lathe%20tools1_zpsqekddo0f.jpg.html
This is what good old fashioned HSS lathe tools should be like.
http://s265.photobucket.com/user/DarrenLCollins/media/lathe%20tools%20002_zpskocn10p6.jpg.html
The tool steel is purchased as a bar (far right in photo) and you precision grind it by hand, sometimes to within + or – 1 thousandth of an inch where the rake angles are hand ground to minutes of degrees.
Today however these skills are lost and most lathe users are NOT tool makers, just tool sharpeners and the majority are blissfully unaware of what a true tool maker can do. Most HSS lathe tools today are like this….
http://s265.photobucket.com/user/DarrenLCollins/media/lathe%20tools%20003_zpsyd5zccqo.jpg.html
Only a small amount of quality HSS is brazed or welded into a poor quality steel holder. The tip is only HSS. These come in all shapes and sizes. But fundamentally they’re pre made so you don’t need to grind any angles or profiles, just dress them on a stone to keep them sharp.
I’m not sure what you have with your lathe, but this is just a real basic guide/help for you to understand simple tool shape. The possibilities of shape and angles are limitless. Understanding what the correct angle on all 6 planes takes years to master and is variable on material, speed and feed.
Hopefully that’s helpful to you for now.
Ceramic or tipped tools are another thing altogether with usually zero apparent back and side rake. Here’s one I set in my lathe tonight to show zero rake.
http://s265.photobucket.com/user/DarrenLCollins/media/lathe%20tools%20004_zpskgsrmwlj.jpg.html
My advice is start with some basic HSS tools, learn and understand how they work before going on to tipped tools. Plus get yourself on a basic lathe class!
That is incredibly helpful.
The amount of time you spent on that for me is greatly appreciated.
Thank you.
I purchased this today.
This is the tooling that came with the lathe.
I've been operating on the assumption that you "get what you pay for" with this stuff.
I have successfully turned some pieces and I've also destroyed some tools.
I'm not afraid to spend some money on high quality bits. I'm looking at carbide and ceramic.
Ok, you got a fair mix there..
http://s265.photobucket.com/user/DarrenLCollins/media/Numbered%20tools_zpsjdoveqgc.jpg.html
Some are no good, others need work and just a few are useful to you as a beginner. I’ve numbered them so you know which tool I’m referring to.
1. Parting tool HSS and Holder. (very good, keeper. Get it sharp, grind the correct front relief, very tiny side relief and no side rake. A medium back rake will see you through most materials) A very good basic and useful parting tool. As it wears you re-grind and move the HSS steel forwards. ALWAYS set the tip contact with the job at dead centre height or ever so slightly low. NEVER go above centre height.
2. Plain Parting HSS (looks to be too wide for holder 1, you may need another holder for this)
3. Resolution on photo poor, but looks like a badly ground/messed up HSS parting. Cut off re-grind and start again with a suitable holder. (may fit same holder as 2)
4. Including 9, 16 & 30. HSS tool holders for smaller maybe what looks like ¼ or 3/8 HSS. You buy the HSS as in my first photo of the early rake descriptions and grind whatever tool you need. Very good old tool holders worth their weight in gold but too advanced for you for learning without good HSS ground tools to fit them. (keepers. Put them in your tool drawer for the future and get a new locking screw for 30 it looks a little chewed up)
5. Including 6 are RH knife tools profile for bevel turning steel Side & Front cutting angle too steep for straight turning and facing off steel, but ok with brass & aluminium.
7.Including 24 & 20 LH knife tool uses as for 5 & 6 above.
8. Including 10, 14, 22 & 23 Ream tools. I doubt you’ll ever need these.
11. Including 17 from the poor resolution photo look like unground tool steel. (put them in a draw for the future)
12. Including 18, 25 & 26 RH Knife tools. These have better side and front cutting angles for steel but they look well used and poorly re-ground. This is the sort of shape tool you need as a beginner but unfortunately these four look in a poor condition and need grinding work to restore them.
13. Including 27 are LH knife tools but old 13 looks useable as 27 needs a re-grind like your RH knifes.
15. Knurl tool. Good basic tool. Check the wheel spindle pins aren’t worn and the wheels are firm and don’t wobble or side in the shaft as any movement will make for a "double" inprint knurl. Plus also check the knurl profile is sharp. They do get worn down over the years and then they’ll be no good.
19. RH facing tool, looks badly ground on top surface back and side rake. Profile looks ok for facing off, but rakes need re-grind.
21. Including 28 & 29 are HSS thread cutting tools. Again these are not for you at this learning stage, stick them in the drawer for the future.
Overall you have a reasonable selection of tools but none are really up to scratch for using successfully.
Try and find a good machine shop or college nearby, take them in and get someone who knows what they’re doing to re-grind them for you. This shouldn’t cost too much money (may be just a crate of beer) and will be far cheaper than buying carbide/ceramic tipped tools and holders that you’re not ready for just yet.
You only need 1, 18 & 19 to learn with at an early stage.
Good choice on new tool post, very handy for setting tool height easy without shims under tools.
Fantastic information. Some of the tools have a wax-like protective coating on the tips. That's probably what you're seeing as "poor resolution".
This is turning into a pretty cool thread!
(see what I did there?)
I haven't tried using carbide on my lathe so take it for what it's worth, but there are a number of disadvantages to carbide.
I'm not sure how fast your machine will turn or if it's got the horsepower to sustain recommended feed rates at higher speeds, but I can say that mine doesn't come even close.
Carbide doesn't like sudden changes in temperature, which means running full coolant is preferable. If you stall out your spindle which carbide, you are going chip your tool. In my experience running production lathes with indexable carbide tooling, it's just a different word as far as rigidity. HSS is going to be much more forgiving of chatter, any flexation. Also the nature of using turn screws to manually feed vs even a jog wheel much less cnc control makes hss seem more at home on a toolroom style manual lathe.
HSS can be sharpened easily in whatever grinder, carbide is going to be more difficult to sharpen. At lower spindle speeds of a manual lathe, you're going to chip and dull carbide bits a lot more than if you could go 3x faster, which is where carbide shines. There may be a sweet spot for heavy cutting if you are turning large material (high surface feet per minute) where a carbide insert tool would be handy, but it will probably come down to if your lathe has the heft to maintain that. Like I said, stall the spindle and you'd be flipping the insert.
We never ground carbide when I did production. With indexable turret style tooling, you flip the insert when it gets dull. Each insert has like 2 -4 sides, and they are expensive, like $20 for each insert - and you don't buy just 1.
So problems with carbide are need to run flood coolant ideally, not enough spindle speed, not enough spindle power at higher sfm, difficult/not possible to sharpen depending on what style you get, and more expensive.
Like I said, I don't have any carbide tooling for my little lathe. Based on my reading/research, it wouldn't be worth it.
http://blog.cnccookbook.com/2016/02/17/peck-parting-lathes/
More info on parting.
Yes the story is mainly for CNC, but still some good reading. Also check out the comments as there is some good information there as well.
Here's a close up of some of the tools that were unclear in the larger picture:
The top two have most probably been ground for detail undercutting or for cutting a square thread. I’m drawn more to under cutting due to the side clearance. Both are RH tools which cut using topslide (in and out at 90 degrees to lathe only) An example of undercutting would be where you make a machine thread or basic bolt and a small area under the bolt head is undercut to the thread core diameter for the thread tool to exit into at the end of a cutting stroke. Or basically the area at the end of any machine cut thread (particularly against an obstruction like a bolt head or shoulder) that has no thread.
Basic Bolt threads that are rolled not machine cut, don’t have an undercut.
DONT be tempted to try and part off using these tools, they're not going to be strong enough or have the correct clearance angles and relief.
The bottom larger tool is a LH knife. Looks a nice tool, good for turning steel (has a good side and front angle for steel) ideal for turning and facing off in a LH situation.
CAUTION: THE FOLLOWING CONTENT MAY HAVE ENTERTAINMENT VALUE.
So.....my titanium wedding ring has always had annoying sharp edges at the top.
I know you told me to not put the small chuck in the large chuck, but it helped me solve my problem.
My ring is much better now. Chamfered on both edges, nice and smooth.
Divorce coming soon?
I'd have kept the sharp edges....
In the same way as those dog collars that gives the dog a small electric shock so it knows when its done wrong.... :-)
You just know I wouldn't be able to resist a photo like that... ;-)
Wrong on so many levels....
"Turning" to the dark side you are… (see what I did there) ;-)
Travelling through a hypermill lathe ain't like dusting crops, boy! Without precise calculations we could fly right through a starter tool set or bounce too close to the chuck, and that'd end your trip real quick, wouldn't it?
Much to learn you still have…my old padawan. … This is just the beginning!
Use the Course…............A lathe course.
"Darkside Turning" is now the name of S9's machine shop department.
Who wants a T-shirt?
I remember this time they had me turning these pistons - J&E pistons is right accross te street from HUntington Beach Machining where I worked. The boss man set up the 1st one as we were using the toolroom lathe for whatever reason, had a 3 jaw universal chuck instead of a collet setup. He does the math, and I'm like, "are you sure?" People like to run aluminum really fast and take these big cuts... apparently these were some special alloy. First one I try to run, BAM! tear a jaw right off the chuck, the piston blank hitting the guard, the lathe jumped off the ground. You learn certain things with an experience like that - keep your hand on the emergency shut off, don't mess around with how you chuck stuff up. Chucking the taper of another chuck is retarded
“Darkside Turning” good name!
I’ll have the first T shirt ;-)
Will it have your face on it, like when Vader takes his helmet off to show your lathe scars?
As for British “sense of humor”, I think you’ll find its spelt “Humour”, we invented the language..
That's what you call….”The Empire (British Empire) Strikes Back” :-) :-) :-)
Somehow it looked like the 1st chuck was clamping on a taper and you were using a live center in the tailstock to hold it concentric. -I see now that's not the case. If it was, well yeah that would be really unsafe.
3 and 4 jaw chucks aren't nearly as secure as a true collet system, 3 jaw especially - and to run 2 doubles the risk. I've pulled some plastic parts right out of a 3 jaw, like deforming the part. No gaurds on these old school lathes, one becomes wary. You need to develop a healthy respect for the lathe whatever size. Here's the Bridgeport EZ path I crashed. It was never the same after that. I can say, "picture it leaping off the ground" but there's no substitute for actually crashing a lathe to instill the fear that is required to run one with the proper mindset.
Darkside Turning's first T-shirts will be called the 10-finger edition. I will put an impression of my hands on each sleeve.
Don't be left holding the bag when the 9-finger edition comes out. Get yours now.
If you pre-order your 9-finger shirt, I guarantee the first three will be stained with my actual blood. I'm sure they will sell well in the UK.
You're a ginger too!
What a fluke,no relation to Sith,I'm guessing.
Looks like that fla sun is a little harsh on that northern complexion.
That was too easy,a kind of rip,lacking originality.
How bout Serious9 Turning,a subsidiary of Series9.
That way serious people will flock to your door rather than to the flimflam flybynight con artist shop,down the street.
The moment you learn to speak English/American/Canadian, I would love to hear what you have to say.
Shirts should say "turning stuff into shit"
Or "turning shit into stuff"
From the Latin.
Plagiarism:plagiarism is the "wrongful appropriation" and "stealing and publication" of another author's "language, thoughts,ideas,
or expressions" and the representation of them as one's own original work.https://en.wikipedia.org/wiki/Plagiarism
'It isn't brass you ass',an observation by journeymen of apprentice's errors.
Not knowing the difference is a signal of ignorance and or negligence,a result of lack of knowledge.
Attempting to machine and sell an aircraft part without the oversight and endorsement of an Engineer is a felony,punishable by life imprisonment.
The material selection of vital automotive components likewise,requires an engineer's approval,as a failure of control parts causing harm,may be grounds for prosecution.
Discovering a trig error in a preliminary ruf op,it was determined that the entire 900kg lot of S5000 was scrapped.
The machinist responsible was questioned,he attempted to cover his ass,not wishing to be held accountable,he was.
I learned a few years later from a disgruntled journeyman,a former employee,that they had replaced the material with 4340,the availability of that specified,untimely.
The switch was discovered by the client,a suit was brought,the vendor forced into surrender and loss.Military helicopter flight control components.
http://asm.matweb.com/search/SpecificMaterial.asp?bassnum=M434AE
https://en.wikipedia.org/wiki/Mass_spectrometry
http://www.dtic.mil/dtic/tr/fulltext/u2/a231588.pdf
http://standards.sae.org/amss5000/
Caveat emptor.
http://www.goltens.com/in-situ-machining/fast-rebabbitting-response-keeps-drydocking-on-schedule
https://en.wikipedia.org/wiki/Babbitt_(alloy)
To something like this,actually,exactly like this,steel mill shears to heavy crushers and their power transmission gears,shafts and boxes.
Hydrostatic conversions are economical life extenders,for heavily loaded shafts,on legacy large capital equipment.
Several decades later,I recall,a 44"ID bearing was repaired in record time,prompting the prez to remark to the gm,"Now he's a machinist!".
He made it worth my while,we continued until he retired the chair and passed away shortly afterwards,a decent selfmade man,100M+.
Having had the privilege of working with these men over the course of four decades and more,a common attribute is a low tolerance for bs.
Clearly,some of the 'advice'extended here by charlatans and neophytes is of that nature.
Got the new tool post.
Now I have to take the base to a machine shop with a mill to cut the base of the T nut.
Dammit.
Two questions:
Given a narrow bushing, like a clutch pulley on a 914:
How do you accurately chuck something so thin?
How do you chuck this in a way that you can machine the outer diameter?
I have a feeling that the answer is to make a tool to insert in the chuck and then mount the bushing with a bolt.
Perhaps a better route to this question:
If I were going to make this bushing from brass, I think the steps would be:
1. Chuck up some solid brass stock.
2. Face the end.
3. Bore the inner diameter.
4. Turn the outer diameter.
5. Create the contour on the face (although it's not necessary to the finished piece).
6. Groove the OD for the cable.
7. Part the pulley from the parent stock, leaving a small amount to turn the other face.
8. Then what? How do I put it back in the lathe in a way that I can turn a parallel face on the parted side?
How to hold something on the inside with a small diameter
Use expanding arbor collets, just another in the line of the many tools you'll need. .
How to hold thin wall tube. . . 6 jaw chuck is best, make percision inside bushing so you don't distort the tube.
You have the right idea, we did leave off the grove detail on the delrin ones as it's not necessary, and would require a second operation to add to the back side. We finish off the back side on the part off.
Joe,
You have 2 options here.
Face off the bar stock.
Machine the "hub" profile on front face.
Machine large diameter and cut cable groove.
Here's where you choose option 1 or 2
Option 1
Using parting tool cut reverse of pulley down the the Largest diameter of hub profile.
Second run with parting tool closer to the chuck (and to the overall width of the pulley at the hub and to the smaller size of pulley hub bevel NOT hole size)
Grind a thin tool for hub bevel, fit down double width parting slot and cut Hub profile on reverse of pulley nearest chuck.
Now drill hole through centre (left until near the end to retain strength).
Finally part off to over all width.
Option 2
Buy some reverse jaws for your chuck
http://s265.photobucket.com/user/DarrenLCollins/media/30292_3_jawchuck_6_zpsgbehdii5.jpg.html
Part pulley off fully extra wide, flip and cut hub profile in reverse jaw chuck.
Hope that makes sense?
Hey if you're still looking for projects to make, I have a 4" telescope objective lens with a fine thread. Need to thread a tube for it, or at least a short section I can weld on to the end of a tube. If you're game for something like that, I'll come up with exact measurements.
Lathe update: I still have ten fingers!
I'm still not up to threading, but I do get much more reliable results these days.
Here's a little thing I did today that saved me at least five days of waiting. I'm working on making a fuel injector kit for Vanagons where I'm going to use EV6 injectors and CB fuel rails. Well, good fittings to go in the rails are hard to find here, so I went to Lowe's and got four crappy barb fittings and then "fixed them".
Nice work Joe.
Glad to hear you still have 10 fingers!
Very nice, love it when people come up with a good solution to their problems.
"What you need is a good 4 jaw chuck with conventional jaws and a good 3 jaw with conventional and reverse jaw set and you should be able to turn most things."
I have purchased three of them, as the previous owner of my lathe broke the jaw teeth over tightening them I presume. I would add to the list a 4 jaw self-centered for precision boring, and a 4 jaw independent for off center boring and turning operations.
The Aloris tool post has made a big difference in the quality of stuff I'm able to pull off. It's so much more rigid that it's making me look better than I am.
I missed having a lathe and don't have the space for a new one, so I comprimised and got this, still need to buy a servo motor and drive for it. It mounts on the table of my CNC mill.
It will go up to 3000rpm, will do indexing (bolt pattern or flats for a hex or timing marks in a flywheel with assistance of a disc brake that is built in) , it will also allow me to machine items like small model camshafts and crankshafts.
