Does anyone have any experience with an Alfa Romeo alfasud?
Horizontal 4 banger, water cooled.....looks nice.
The transmission is what interested me.
Built with inboard disk brakes mounted on the transaxle...
It's one of the wheeler dealer shows on tonight.
I really like the brake setup, looks a lot like ours with a mechanical ebrake on the calipers too.
https://www.youtube.com/watch?v=w8HhHd2WkOU
Been a big fan of Ital Design since the '60s.
Put it all together,easier that way.Sure,the engine and TX layout was new for '72.
https://en.wikipedia.org/wiki/Giorgetto_Giugiaro
http://www.italdesign.it/en/areas/automotive/
http://www.alfagtv6.com/callaway.htm
https://www.google.ca/search?q=alfa+romeo+v6&espv=2&biw=1280&bih=641&source=lnms&tbm=isch&sa=X&ved=0ahUKEwj-wt6q7O_KAhUDdR4KHXYlDbEQ_AUIBigB#tbm=isch&q=alfa+romeo+v6+24v
http://www.alfabb.com/bb/forums/gearbox-transaxle-differential-propshaft/
https://www.google.ca/search?q=alfa+romeo+alfetta+gtv+suspension&espv=2&biw=1280&bih=641&source=lnms&tbm=isch&sa=X&ved=0ahUKEwiGt_295e_KAhXMHx4KHcGvACEQ_AUIBigB&dpr=1.5#tbm=isch&q=alfa+romeo+alfetta+gtv+suspension+transaxle
https://www.google.ca/search?q=de+dion+suspension&espv=2&biw=1280&bih=641&source=lnms&tbm=isch&sa=X&ved=0ahUKEwi2taea6O_KAhUI1B4KHboIAtIQ_AUIBigB
https://www.youtube.com/watch?v=MSa9Nwl99k8
2.5Lna vs 5L and VolvoTurbos.
http://www.ooyyo.com/united+states/used-alfa+romeo-gtv-for-sale/c=CDA31D7114D3854F111BF66FBA61355BEFA01D7FA2D489A21608F675BD4535/
Valued by aficionados.
more:
Ingegnere Giuseppe Busso`s V6 60*.
A good look at a build.Like the Renault and diesel engines,wet cylinders.
A flying weight 6 pin crank.
Hemi two or four valve,twincam.
http://www.alfabb.com/bb/forums/engine-repair-diagnostics-rebuilding/47336-rebuilding-3-litre-america-engine-my-84-gtv6-2.html
Did someone watch Wheeler Dealers the other night?
They did an Alfasud.
https://www.youtube.com/watch?v=K7fGjmGYArc
...and they eventually used that base motor to make a 1.7 16v version that made what 130hp? That would have been a blast in a 914.
That is one funky suspension!!
Not a big fan of any DeDion setup, personally. Looks like they could have gone to a nice full-independent setup with just a little more work. Less unsprung weight, better compliance over bumps...
--DD
Yes, not a fan of the suspension.
Wonder what could be done with that tranny?
How much power could it handle?
The whole package may be too long. Rear mounting point is high. Brake pads are a pain to change. My stock Alfetta brakes are great however. Typical 1st and 2nd gear sycros are usually gone.
And this
Alfa Romeo Flat-4,ZF-transaxle-5 spd.
An attribute of the de Dion is the stability of the toe settings and the roll centers.
The design has been around a long time.
Might be the last time a de Dion won LeMan.
https://en.wikipedia.org/wiki/Aston_Martin_DB3
https://en.wikipedia.org/wiki/Aston_Martin_DBR1
W2 chassis,honeycomb,de Dion.1978.
Lotus Eleven
http://jalopnik.com/turn-this-brand-new-vector-w2-chassis-into-the-supercar-1677726756
