Welcome to my scattered 1974 1.8 Chrome Yellow project thread.
I purchased the car back in '05'sh. One of the POs had converted it to a well sorted 2.0 D-Jet autocross/street car. It was complete but a bit ratty with a tired motor. Great Koni Sport suspension with a fat solid sway bar and adjustable drop links. Otherwise bone stock.
Built a fresh 2.0 with a 9550 Raby Cam and kept it D-Jet. Ran a DE Event at Thunderhill, a few auto-x's at the Sonoma County airport and otherwise used the car as my DD. During this time, around 2007, early 2008 I picked up a very clean Marathon Blue '74 2.0 from Doug Wright. I ended up putting the new motor from the yellow 914 in the Blue car in 2008 and it's sat in my garage since.
Here it was as of a few weekends ago:
So what's happening?
My friend and machinist is currently building a 1911 from the ground up. Opened up 1.8 heads, rebuilt dual 40 IDFs (thanks George, @http://www.914world.com/bbs2/index.php?showuser=13527 here on the World), Elgin cam, etc. I'll post motor specs in a different post.
Purchased Chris's SS tunnel fuel line replacement kit w/ pump. Need install that in the next few weeks.
Sourced a rear bumper from GMS and am currently repairing some issues it has and then move onto the front bumper and rocker panels.
I need to go through the brakes.
Should probably check the tank closely for rust issues.
Need to replace the heater pull cables.
Need Mark D's modified speedo drive with the extra o-ring, or source a nosecone that doesn't have a worn out drive hole.
Already purchased rain caps for the carb's as I also purchased Sergio's GT lid clone. Need to strip and paint the Mahles unless I source different wheels.
I have a mostly complete 5-lug setup (including rear hubs and s-calipers), but I'm saving that project for later.
Still reading? I'm sorry.
Anyways, plenty of photos coming and I'll keep this thread updated as I make progress.
Cheers,
Parts including the tank, HE's, Triad Exhaust, 901, etc etc.
Already have the clip's from Mark @ 914 rubber to fix that sorry looking side marker light. :-)
Looks like a good plan.......
Here's the interior. I have a nearly perfect seat that I'll put in place of the driver's seat. I'll swap rails and move the driver's set to the passenger side.
Carpet will be replaced with German weave from Mark @ 914 rubber. Already have his newly rebuilt visors from the group buy.
Question: What color carpet would look good? I never did care for black. Gray perhaps? I'm interested in your feedback. I'm colorblind and have a hard time making these types of choices.
1911 as of a few days ago. My machinist got bronchitis so the motor project stalled for a few weeks.
280D/332L/180deg Elgin Cam:
so it has sat for 8 years?
I dont feel as bad now....I think you take the lead.
rich
Rear bumper sourced from IL and it must have come from a rust bucket as two of the rear bolts were snapped in place and poorly drilled out. Thankfully they coaxed out and tapping proved to do the trick.
I am driving a 911 cab...that is what makes me do something else.
HoneyDoo list...
Boat....
lay on the couch...
Rich
One annoyance... I can't find the f'ing ignition key so the wheel is locked. The wheels are turned so I can push/pull the car in/out of the garage, but that's not going to work for long. I have what I need to replace the ign switch and key, but I really would prefer to just find the key. I feel like I've looked everywhere, but it didn't just walk off.
My friend and machinist is back from the dead after getting bronchitis and is back to work on the motor. Cam's in:
One more:
there is a guy who shows up at Hershey and makes keys for Porsches.
He has all th eight blanks.
I bet he knows how to make you a key that will work based upon some number, possibly the vin, or something else.
Hopefully one of the guys who remembers his name will chime in, and you can give him a call.
Did you look under the seat, glove box, trunk, under center console?
After my last fiasco of loosing a key, which I did eventually find, I went out and had spares of everything made, and I put ALL of them in a special place....and use the daily keys...
Now I know I have q backup.
If you have a dent puller you can insert a deep threaded sheet metal screw into the lack cylinder and rip it out.....not pretty but it does work.
Obviously you will need to redo everything once that is completed.
Look into a mobile locksmith. They use softer metal blank, wiggle it in the ignition which leaves indentations that allow the correct key to be cut. Then you can at least unlock the wheel. I had to have this done when my car was boosted from the garage and recovered with no key. Expect the process to run a C-note.
Hi Randy, great to see you working on the 914 again, hopefully this summer we can both be driving 914s again for a Roadglue meet!
Listed two cams for sale in the classifieds this morning as I was dicking around with other ideas before I settled on the current Elgin cam. Hurry and get yours before they're sold out!
So happy for you Randy! This car is gonna be a ton of fun when you're done.
Thanks George! Can't wait. It's been much too long.
Spent a portion of Easter Sunday in the garage cleaning the fuel tank area and installing CFR's SS fuel line.
Dirty!
Suck![]()
Clean
Kit:
Progress:
Not pleased with the amount of rust I've found in the center tunnel. Is there anyway I can treat this now so that it doesn't worsen without having to pull the wiring harness?
Keep water out. Without moisture, the rust will stay just like that.
go to Eastwood and get the rust conversion stuff, with the spray wand (long one)
Then you can spray in the converter, let that sit for a while.
Once that is done, I would personally spray in a top coat of whatever you want...
Rich
This looks like it might work for the center tunnel:
http://www.eastwood.com/internal-frame-coating-w-spray-nozzle.html
Use a similar spray want to blow paint in there.
I hav never seen a tunnel that was not rusted.
It's here, and it's beautiful.
Question:
What's a good inline fuel pressure gauge that I can mount in the engine compartment? 0-10 lbs range or thereabouts for a dual 40 IDF system.
In other news, spent many hours degressing engine tin, cooling shroud, body work on bumpers, killing rust, painting engine bits.
Stuff's coming together. Feels great!
If you use Mar-Hyde to convert, no top coat required or needed.
Selling my Triad exhaust or looking for a trade (plus maybe a few bucks) for a used Bursch 2.0 exhaust. I'd like to chop the stock Bursch muffler and have an exhaust shop attach something a bit rasper.
Ad is here:
http://www.914world.com/bbs2/index.php?act=ST&f=18&t=281711&st=0#entry2326385
Just a quick update.
Lots of blasting yesterday (not everything is pictured).
Still working on the bumpers, but they're further along than what's pictured now. ;-)![]()
Have zinc phosphate primer w/ silver wheel paint for the cooling shroud. Should be a-okay. All the sheet metal will be headed out for PC soon.
Cleaned up and refinished the 4-Lug Mahles this weekend. I need to take a better final shot. Turned out pretty good though I didn't take care of any of the scratches. They'll look great from a few feet back, which is all I'm going for.
I need to take a conical wire brush on a drill and strip the paint carefully away from the lug holes. I blanked on taping them.
Bless you Randy for stripping those wheels. I HATE using aircraft stripper, especially on the nooks and crannies of wheels.
Looking good dood!
How does your back feel?
Lots of stripping, nice job.
Looking good!
Shout out to Mark Whitesell (914rubber.com) for making parts so many of us need.
To Garold Shaffer too for being my go-to guy for used parts that I'm missing.
What a great community. You guys make me sappy.
I'm going to have the taste of ground up rust in my mouth through the majority of this project.
Just a little clean up project last night. Used Metal Prep before sleeping and then primed and put a top coat on before work this AM.
I'll probably used white lithium grease on the swivel and then a little anti seize in the tube portion as I left that mostly bare metal.
Just a bit more painting last night.
Had blasted the cooling shroud last week. Used a VHT zinc primer and wheel paint to make it shiny. Hope it holds up long term.
Primed and painted both sides.
Starting this project back up again.
Test fitted the engine tin the other night. Dropped that off along with a bunch of other misc parts for powder coating yesterday.
Inching closer.
Finally found the ignition key hanging on my garage peg board behind some other tools (seriously, don't ask). It's been missing for years. Just happy that I can turn the steering wheel again.
I should mount the fuel pump up front this weekend. Really haven't seen any clear photos of exactly where it should go in relation to the steering rack, but I'm sure I can make that work.
Looking good Randy! Glad to see you back at it.
Good luck brother! Let me know if I could help. I may also have a part or two laying around.
Just sorting parts. Still waiting for my sheet metal to arrive back from the powder coater. Planning on installing the motor next weekend as long as I get my tin back this week. Looking positive. ![]()
Get that car finished so you can drive it down to Monterey and meet us in September!
I am hoping to bring two IMSA 914s, going to be a busy winter!
Really happy for you Randy! You've been at it for some time, and the reward will be awesome.
Did we ever determine is this is the correct return spring for the CSP linkage?
https://www.csp-shop.com/en/engine/return-spring-for-csp-bellcrank-linkages-129-881-100-20650a.html
I looked through a ton of CSP related threads but didn't see anything confirming that this is the part to get.
Thanks!
I would try McMaster 9271K131 and see if that might be made to work.
Ordered the pack of springs from McMaster-Carr. I'll let you know if they can be made to work.
Mark, I'll have some extras too if you'd like me to mail you four of them. LMK.
How'd you get a pack of 5?
This wording is weird, eh? I had planned on keeping two for myself.
Check your part number, yo.
I immediately wrote McMaster-Carr after seeing your post Mark and here's what they replied with -
"Hi Randy,
We've already shipped this out, but we'll credit it back to you. You don't need to return it.
Mike"
Talk about awesome customer service!
I ordered the correct spring as well and will advise as soon as I'm at that point.
More progress. Should have the motor back in the car this Sunday.
I would have had some of the parts shown plated vs. powder coated if I had planned this project out better, but I'm happy how everything turned out.
914rubber.com's pulley wheel (er, back focused):
Wiring up the alternator with a new Bowlsby harness:
IIRC, the factory put thin foam gaskets between the overlapping areas on the tin. Do people bother replacing it?
Those powder coated parts came out great.
Maybe I misunderstood the post, did you plate some of the powder coated parts 1st?
Also looking at getting a wide band O2 AF gauge and sensor kit. A friend recommended SpeedHut, but I'm not sure this is the best bang for the buck.
https://www.speedhut.com/gauge/GR-AFWB-09/1/Standalone-Air-Fuel-Wideband-O2-gauge-8-5-18-(w--warning)
I'm more than happy to buy the O2 sensor and cable separately too for the right gauge. I'd prefer a black bezel too, but that's secondary to a reliable, consistent gauge.
Would really appreciate recommendations.
I've been very impressed with everything I've gotten from 14Point7. At $175 it's not significantly less than the SpeedHut set, but it's still a decent savings.
Gauge: https://www.14point7.com/products/solid-afr-gauge
O2 Sensor + Controller: https://www.14point7.com/products/spartan-lambda-controller-2
Innovate is also pretty popular, though I've never been very impressed with the quality of their controllers. They seem to have weird faulting problems and aren't very tolerant of poor grounding. Just some more options.
http://www.innovatemotorsports.com/xcart/product.php?productid=16235&cat=262&page=1
That looks great
This is looking fantastic!
Exactly the way my engine looks.... in my dreams!
Have a cold, so I didn't get a ton done this evening. Realized I'd left off the flapper bar, so I had pull off some tin and sort that out. Missing the spring tab. Looks like something I can probably fabricate pretty easily if I can't find one in my stash.
I'm also missing the oil cooler support bracket. Lame. Hopefully my machinist here in town has a spare, or else my plans on installing the motor this weekend will be stalled until I can buy one from Garold (you listening buddy?)
Just an upskirt shot. Maybe I'll invest in a bellows kit. IDK, I've never had one working on any 914 I've owned.
Nice work!!!! Thanks for sharing.
Did you have the push rod tubes powder coated? Or did you purchase them black? Paint? Inquiring minds want to know.
Hope you make the Sunday deadline for motor install. Will car be ‘finished’ with that? Or more still to do?
Also check with Gary at Sonoma Volkswagen (707) 996-1354. He may have the cooler clamp.
Mark, I think the happy medium is somewhere in the middle. The wire gauge is gargantuan!
Good news, my local buddy had the oil support bracket and two pcs of tin I was missing. Sunday is still a go for motor installation.
The new 19mm MC from 914rubber.com arrived today too with the easy install option.
Last night I installed the CSP linkage bracket. Guessing that the six extra washers are to be used as spacers. KINDA janky if you ask me, but washers work.
I'm not sure I'm cool with the through-bolts not eating up more thread than that with the throttle cable support bracket installed. I'll probably need replace those two for piece of mind.
Just ordered a 911 starter, though I'm missing my main power lead for the starter.
Any advice on the wire gauge I should use? Thinking 4 would be fine.
Randy,
I'm not sure how you tightened this band with the screw installed backwards. When turned around it's easier to access from below, especially if you ever need to replace the alternator later with the engine in the car.
I've had to R&R an alternator a couple of times and believe me you don't need any extra drama when changing one out. It's a crappy job already.
Started back on the motor assembly Friday. Installed the oil cooler support and plugged up that the bellows pulley hole (Thanks SirAndy!).
I used some Form-A-Gasket in hopes too keep it from seeping oil.
Looking almost ready for installation at this point.
Installed the old sealed-beam lights. I'll likely pick up the 914rubber LED kit soon.
The old 901 is looking pretty dirty after sitting for so many years. Took it outback and scraped at it for about an hour with amble amounts of Simple Green. Here's the before pic.
Installed new cup bushing, side bushings, throwout bearing.
Cell phone shots are coming in at whatever orientation the phone was in when I took the shot. Hmmm, not worth opening and closing in PhotoShop to fix (yet).
Test fitted the carbs and setup the linkage. Switched the orientation of the fuel inlet nipple on one of the carbs. Oh yeah, also installed longer 40mm intake manifold studs to accommodate the fiber gaskets + thicker cast intake manifolds.
Is there any reason I can't use this part? Think it's off a bus and it doesn't have the PCV valve. I've got a single head vent that's going to be sent to a my catch can. Otherwise I need to hunt down the 914 part.
Is this the Brad Penn oil that's recommended?
"Brad Penn Penn Grade 1 20W50 Partially Synthetic"
https://www.amazon.com/BPEN-20W50-12-Brad-Penn-Partially-Synthetic/dp/B004WKH0VQ
She's only been outside twice in the past eight years. Bath time!
My friend Jon came by for the day. First order of business was to get the motor off the stand and onto a dolly. Torqued the flyweel bolts and put on the last few pieces of tin.
Engine and transaxle together at last, and a 914 in waiting.
A nice gash in the door and pillar from a nasty parking lot accident about ten years ago. Neighbor dragged her SUV alongside my car. I took the insurance money and bought another 914.
I didn't realize until Friday that my Tangerine Racing jack plate wouldn't fit my jack without an adapter, so we made an adapter-matic ®. Chris approved?
Highly recommend his jack plate though. Made balancing the motor a one-handed job.
New speedo drive with the extra o-ring. Oh f&ck though - I'm missing the right-angle bit. I need to purchase one, so I guess I'm hitting the classifieds here later.
911 mounts and I elongated the holes as they're a bit too close together for the 914 mounting bracket.
Success! She's in. Wish my car looked as good as the powertrain.
Starting to fit the carbs.![]()
As she rests tonight. Pointing the right direction and ready to get back on the road again!
Lots to do still, but I'm stoked to have gotten this far this weekend. Small chance we'll be firing it up next weekend. Starter, spark plug wires and the shift linkage bushings are showing up this week. I'll just need a battery, some break-in oil and a bunch of time to wrap up all the other little things. We'll see!
I ended up ordering the Innovative Motor Sports MTX-L PLUS: Digital Wideband Air/Fuel Ratio Gauge Kit (8 Ft.) with an 8' extension. Thanks for the recommendation Dug! I might have gotten by with a 3' extension, but I measured it out to needing 14'. The gauge includes a 2' lead as well, but that still gets me to just 13'. Oh well, I'll know soon.
http://innovatemotorsports.com/products/mtxl_plus.php
It's a got a party trick. You can get solid data logging out of their system when used in conjunction with their MTX-D: Vacuum / Boost & Shift Light gauge (for sending RPM data) and their PL-1: Pocket Logger, Innovate MTS Datalogger.
I'm holding off on the secondary pcs of kit until I make sure I have a running car.
Here's the gauge face.
Doug pointed out that the only $hitty part is that the needle LED is just a single LED and doesn't show a fully lit progression on all the LEDS leading up to the value LED.
I'll report back and write a review when I've had a chance to play with it.
Still trudging forward.
Damn, I love new parts!
Painting a shift rod -
Here's how I cut the tubing for the wire clamps -![]()
That looks better! I was missing all of them in the engine compartment.
Installed the relay board and started laying out the engine harness.
Should be getting a new batch of goodies in the mail today. Might have time to wrap up the shift linkage this evening too. Just LOATHING the thought of attaching the linkage boot at the firewall. What a pain in the ass.
It is really happening!
text me if you still need the angle drive
Haven't updated the post in a few days, but I've been working my butt off getting the car ready the past week.
Wrapped up the shift linkage. Adjusted it today too. Think it feels right, but we'll find out for sure when she's running.
This Triad muffler is kinda jacked. Sits way too close to the body on the driver's side and is firmly planted on the passenger side. The center glass pack was opened up at some point too and gutted. The O2 bung is also in a really lousy spot. IIRC, this was a bit loud for my tastes when I ran it on my other car.
That being said I've had a lead on another muffler which with a little luck will be here later this week.
Didn't get any photos of a lot of work I did on Saturday, but had a buddy come over and we ran the fuel pump wiring from the frunk to the stock FI pump location in the engine bay. Also rerouted the CHT gauge and oil temp gauge wiring. Lastly, got my O2 harness in place, but I'm wiring for a 3' extension before I can wrap that up.
Also finished plumbing the fuel hoses at the tank. Replaced the carpet (sponges) that the tank sits on with high density closed cell foam that won't hold water. ![]()
Looks like I didn't clean that yet...
She's not much to look at, but I'm chipping away at the cosmetic issues.
New heater pull cable and nipples. That cable has been hanging in my garage for at least a decade. Glad to put it to use. ![]()
Wiring and interior fun. Installed new seat adjustment handles too.
Also ordered Gray German Loop carpet today. The Black Friday sale at 914world has made this an expensive weekend. Please don't tell my better half, k? ![]()
Cleaned off the dust, glued the dash fave vinyl around the stereo. Replaced one of the seat cushions.
The German Loop carpet can't get here soon enough!
Oh, also installed a new reproduction center tray from Stoddard. It required a lot of trimming and in the end still didn't fit great. Can't say I recommend it.
Catch can installed, but waiting for my oil filler tower before I vent the case to the can.
On to rebuilding the targa top. Spraying the front and rear bumpers, rocker panels and top this week. Seals and perlon have been ordered. ![]()
Go Randy go! Looks great!
After this weekend, you're going to be set for parts! Great Work Randy!
While I know the body needs work (and it does!), I still thought I'd go ahead and paint the black bits as I had to repaint the rear bumper as it came in needing a bunch of work.
I always hold my breath when pulling rocker panels, but thankfully they look the same as they did when I had them off ten or so years ago. ![]()
As you can see, I have my entire garage and gravity on a rotisserie.
Spent a number at my pop's place the other night starting the body work.
I'll be back out there this afternoon and hopefully we'll be able to shoot everything either today or tomorrow.
Found a high quality 4 gauge battery cable that's the right length -
Re-manufactured 911 in. Appears to be both a new solenoid and motor. Was prepared to keep sending them back until I got a good one, but this looks like it's going to be fine.
Pulled off the ill-fitting Triad (or Triad-clone?) and compared it to the size of the Bursch. The Bursch must be half the weight. I'm not a big fan of the sound, so I plan on swapping the muffler part out with a Magnaflow and slightly larger out pipe, you know, for street cred!
Found my rear valance in my rafters too last night. Now that I've ditched the Triad I can actually use it, so I'll be taking that to my pop's for paint today as well.
Everything lined up perfectly, which is waaaay better than what was going on with the Triad. I was worried my HE's might be bent, but no issues here now. I just need some more 8mm washers before I can wrap up the install.
Garold came through with my right-angle drive. Thanks buddy!
Left work early on Friday and continued on with paint prep. Was able to get the bumpers, rockers, rear valance and other misc bits sprayed.
Used Eastwood's epoxy primer and their single stage urethane topcoat in satin black. My dad's garage is a dirty, dusty mess, but I'm happy with how everything turned out. Not show quality, but it's a huge bump up from where the parts were at. My rockers were pretty bent, so when I paint the car I may opt to get a new set from RD.
I really don't see myself having the patience to do the bodywork on my whole car. Just doesn't seem like something I'd enjoy. Prefer working with the mechanical bits.
Spent the entire day Sunday wrenching on the car in hopes of firing her up in the afternoon. My trusty friend Jon came back and helped me knock down my checklist.
However when it came time to fire her up I ended up fighting with my ignition switch. Only getting intermittent signal to the starter solenoid and it appears the switch has gone bad again. Replaced it about ten years ago after Glenn Stazak (GMS) and I had it fail on us while bopping around Mendocino.
New switch ordered along with a new Pertronix III as I let the smoke out of mine in a big way. My old ignition harness from Bowlsby unfortunately has had the stripes wear off enough to where I mixed them up and appear to have nuked my old sensor.
Sigh.
Also noticed that my p-side 40 IDF didn't seem to be spitting nearly as much fuel down the barrels as my d-side carb. Need to investigate that as well.
Waiting on an ignition switch and a few other bits before I can get back to the meaty stuff. So last night I had a few glasses of wine and reassembled the targa top, sans the perlon which should be here from 914rubber soon. Might have to give them a call today.
Glad I found an old forum post detailing how to install the top window seals. Tried sliding them into the rails for a while and that was a big no-go. Have to slide the other channel into the groove and then work the inner part in carefully with a screw driver. The rear seal was a total breeze. Once the seals were fitting, I roughly trimmed off the excess material from the top side windows seals and then trimmed to fit with the top nearly in place.
You can really see how screwed up the side sail panel vinyl looks now. Think I might paint/dye it to hold it over until I paint the car. I plan on deleting the sail panel vinyl at that time, so really don't want to go through the hassle![]()
New Meistersatz ignition switch came in this afternoon, so I tore into my steering column to find out if the old switch was cracked. Sure acted like it when we tried to start the car on Sunday.
Wow, taking off the knee pad first, per PP's guides, was worlds better than trying to get to the harness connectors with the pad in place. I didn't realize how easy it came out and feel like a dufus for struggling so badly the last time. ![]()
Ah ha, it's cracked (by my thumb in the photo) ... again! I had one fail only a year or so before I stopped driving the car and I don't remember the new switch giving me problems when I parked it in 2012'sh. Thinking it was the lousy brand and it just got brittle with age.
The dash went back together quickly so I decided to fix a nasty wire before my fingers froze. It's getting down into the 30s and my garage is in the 50s at night, maybe lower. ![]()
Ah yeah, so what da fuch is this? The wire is super short and hacked together. Hmm, wonder if I did that when I was in my late 20s. I sure hope not.
So I pulled off the wheel again and removed the copper contact ring by bending tabs on that attached it to the horn ring. The stress relief crimp section was cracked so I decide to solder the new wire into the contact ring to keep it from pulling out easily.![]()
Much better!
What paint did you use for the valance, rockers, etc.? It looks great.
Konrad
nice work.
funny, I have the exact same paint in my garage, just waiting for me to finally prep the same parts and paint them.
Been a week or so since I last posted an update.
Tried starting the car last weekend. However my new battery acted like it was dead, though it tested fine. Almost my new ign. switch stopped working after a few tries. WTF? Turns out I hadn't tightened the ground strap to the gearbox. From what I can tell I only fried the start position on the ign switch and cooked my CHT gauge. Thankfully I have another NIB gauge and my replacement switch just arrived today.
Used a momentary switch to make a starter-switch in the engine bay just for getting her going. Once the grounding issues was resolved I found that I was only getting back fires when trying to start it up. Checked and double-checked that the rotor was pointing where it needed to be at TDC, wire order, etc. Eventually had to call it quits until Tuesday. Had my friend and the person who built the motor come by to check my work and found that he had installed the distributor drive gear 180 deg out.
Once that was sorted she fired right up, but I had some terrible exhaust leaks so we shut her down.
Pro Tip - Always fit the exhaust on the stand. I didn't because I didn't see an easy way to get the motor off the stand with it upside down or sideways.
I paid the price for that. While tightening the exhaust I pulled a stud and broke another. I take full responsibility for the snapped stud, but the once that pulled never got close to being torqued.
Long story short, I was able to to get the stud out using a Snap On CJ700-1 stud extractor. Really dodged a bullet there. Just barely had enough thread left and clearance to make that work.
Fixing the pulled stud with a helicoil this week and hopefully we'll be in better shape to actually drive the car by next weekend.
New Ignighter III
Propane heaters work well. I had one at my dads place and it was nice. I'm looking into the small Reznor hanging shop heaters for my garage at home. They're available used all the time for ~$100.
That oil-filled radiator style heater worked great in the garage. Took the edge off and if I was close to it I'd find myself pushing it out of the way.
Fixed both exhaust studs on Thurs evening and then drove around the neighborhood for the first time in seven or so years Saturday. Happy Christmas to me!
Still have an exhaust leak I haven't been able to totally adjust out. This set of HE's I have might not me totally true/straight. IDK... Think I'll heat cycle it a few more times and carefully try to add a bit more torque. If that doesn't work I'll pull them and put a straight edge on it and see how it looks. Might need a new set though. These are pretty ratty anyways.
Also installed another ign switch. Think I can swap it out and put it all back together in about 25 min now, while sleeping. Anyways, didn't fix the START position problem. Pulled the fuse block, fixed a few little issues, cleaned up the main ground lug. Still no dice.
Pulled the passenger seat. Put the switch into START and wiggled the sea tbelt interlock wires and BOOM, it wanted to turn over. Didn't have chance to investigate further, but at least I know where the issue is.
Tonight I'm having my neighbor come over to TIG weld the engine lid hinge mounts. I installed Sergio's GT lid and the springs appear to have a lot more tension. Both hinge mounts ripped on the first close. DOH.
Also mounted the front LE Dam and bumper, rear valance and bumper and the two rocker panels.
In other news, my buddy Dug snagged a set of 15 x 7 ATS 4-lug wheels that were listed on the classifieds here for me this past week - Probably won't have them here in Santa Rosa for at least a few weeks, but I'm so stocked. Always loved the ATS wheels.
Question -
My car was originally a '74 1.8 and I wonder if the relay board cover was different for L-Jet cars as I can't for the life of me get my relay board cover to fit.
Anyone care to chime in?
Looking good Randy! I am so glad you got those wheels!
So last weekend she officially roared to life, sans exhaust leaks. The HE I picked up from a fellow member years ago, for whatever reason, wouldn't quiet down. Pulled it again, put a straight edge across both surfaces and couldn't see any problems. I had one spare in my stash, but it's a SS and has a slightly larger ID. I either need to pick a new HE that matches one or the other.
Really wasn't happy with Mark's throttle cable support being on the passenger side of the case (sorry Mark!) as it meant that the linkage rods weren't parallel to one another. After some heavy tweaking in the vise I got it to fit on the other side of the case -
Nice work!
Still fiddling with gauges. Fuel gauge isn't working, though the reserve light does operate. Hmmm.
Really digging the A/F ratio gauge. More on that later though.
Installing and oil pressure gauge this weekend.
Awesome neighbor came by and TIG welded both of the cracking/separating engine lid hinges -
Sergio's GT lid is a thing of beauty. Did require some bending to get it to sit straight.
I had planned on using the AP carb rain hats, but they interfere with the deck lid springs. Wish I had known before purchasing them.
No mention of them having interference issues on 914rubber site -
http://shop.914rubber.com/Rain-Hats-for-carbs-914RH.htm
I'll send Mark a message about that.
Where were we?
Okay, so back in 2018 the old gal was still on the road, but I wasn't getting any satisfaction from driving her. Each outing was a stark reminder of how tired and out of tune so many systems were.
One of the worst issues was consistent hot start issues. Every stop at a gas station was enough to cause anxiety. I'd already moved the fuel pump to underneath the fuel tank, but to no avail.
The steering was starting to suck. While I'd refreshed the rear suspension with stiffer springs and Koni Yellows, I had no idea what was lurking up front. I knew bushings were worn, and it felt like the struts were gone, but I'd never in all my years of 914 ownership actually torn in or rebuilt the front end.
Also, the Yoko S-Drives were shitty tires, too. 195/55/15s IIRC, and they had so much sidewall give, that a little back and forth on the steering wheel would cause the car to wallow back and forth like a boat. Boo.
There was no avoiding it. I needed to put Yellow back on jack stands.
I already had a few parts on the shelf. Maybe just enough to push me off the edge, like a set of 911 Turbo tie rods and some ball joints. I hastily started to order more bits. First, some delrin a-arm bushings, and then some elephant racing a-arm bushings, and then I ultimately settled on Rebel S Racing front a-arm bushings. I must really like spending money on a-arm bushings, but I'm getting ahead of myself.
The quick front end refresh ended up spanning from 2022 until nowish. Yesterday I lowered her back on her front paws after all these years. The registration sticker should be here in a few weeks.
I still have a long list of to-dos, and tuning/problem solving on the rear half of the car, plus a few final details up front to finalize, but there may be light at the end of the tunnel.
I'm going to do my best to slowly start back filling this project thread with what I did to get to this point, but we'll see how much time I can really devote to that until it's back on the road.
Thanks for following along.
Ashamed to show just how neglected old Yellow was while life got in the way, but here's how things looked back in January of 2024 vs. yesterday.
More to come, soon. Cheers! -Randy
You're hereby invited to come along on all longer drives!
We really MacGuyvered that back together ![]()
I continued to have issues and after replacing the switch a few times I realized the seatbelt interlock was the culprit.
I love me some mundane progess...A++
Because 914s are pretty square, they gravitate towards being good storage shelves...
Isn't that the truth. I didn't want to scratch the top, so at least I had the foresight to stash it in the trunk.
keep after it
Continuing the story where I left off in April of 2022
As I mentioned earlier, I'd never fully torn down a 914 front end. For the most part it was straightforward, but the tie-rod ends needed some heat in order to coax them out. ![]()
No rust, but everything was dirty. ![]()
The PO had auto-x'd the car a little, and I was dying with curiosity to know what struts I'd been driving with all those years.
Oooh, what? Hmmm![]()
I had been anticipating doing this deep dive into the underpinnings and had started to collect parts. PMB ran a great "seconds" Black Friday sale, so I grabbed rebuilt calipers and a few other goodies.
Here was my first attempt to take stock of what I'd collected, what I was missing and which bits needed replacing/plating/etc.
The a-arm bushings came right out with a little persuasion.
However, it was around this time that I realized I didn't want to use these a-arms.
I didn't care for the bolt-on drop link receivers and it also felt this would be the right opportunity to jump ship and get 911 a-arms so I could have more torsion bar options down the line.
Tastier than marshmallows
So I got a set of 911 a-arms with 914-6 torsion bars (thanks Doug!) and got back to work removing those rubber bushings again.
After cleaning everything, my powder coat pile was nearly complete.
In hindsight, I'd probably have not powder coated as much as I did as there were a few interference issues later down the line that were a tad annoying. I also ended up not using the dust/rain guards or a lot of the a-arm accessories that were replaced by the parts that come with the Rebel Racing RSR bushings. Anyone need some parts?
Jump ahead to Dec 2022, and the parts came back from powder coating. Removing the heat-safe tape was lame. I must have bought the wrong product.
More shiny parts though, less dirt.
My front inserts came in, too. As much as I'd miss those Interpart shocks, I figured Koni Yellows would be a worthy upgrade, plus they'd match what was already installed in the rear. ![]()
To demonstrate how slow and mundane progress really was, the images in the last post were from Dec of '22.
Here's how much progress was made between then and Aug of '23.
This post covers Sept through Nov of 2023 where I started to finally reassemble the front end. Turbo tie rods for the steering rack, bearing races pressed in, etc.
I should mention that I did inspect the steering rack and tension bit for wear/play. Everything was in perfect condition, though I did add some new grease.
I will say one thing I was really missing during this period was having a pal in the area that would be happy to come by and just hang and work on this stuff together. It took a mind shift for me to just enjoy being out in the garage solo, either bopping along to music or just my own thoughts. Now it's fine, but there was a transitional period there.
Growing up, it was my group of buds that spent time together working on our rides. Later on, I still had a small network of friends that preferred hanging in the garage over piling on the couch to watch a game. People move away, friend groups change, but the car's still out in the garage.
That's okay!
This was a big milestone as it was the first time I was getting to put together all these new or refreshed parts - and I could do so while standing up! What a luxury.
I opted to use marking paint so I'd remember (years) later what I'd torqued. That proved to be quite helpful. ![]()
And that's where progress stopped once again. 2024 had me working on home projects.
Fast forward all the way to June of 2025. Really, it'd been about a year and half since I'd touched it. I needed to move it into the middle of the garage so I could no longer ignore it. Doing so also pushed my daily driver into the driveway, further motivating me to get some work done.
So I lowered the front end onto a furniture dolly and then shimmied everything over so I could access all sides.
Sad state:
Onto the dolly:
Now on four stands:
The bench was still clogged up with good parts getting dusty:
Disassembling MORE of the car at this point felt counter intuitive, but it had to be done. I stripped the rest of the soft lines, rear calipers and discs. ![]()
Rather annoyed the the firewall shift bushing had already cracked, so I ordered the CFR spherical bushing replacement.
Rounded off brake fittings, fault of my earlier self or a DPO, so I placed an order for a number of hard lines from PMB.
Started getting the rear calipers ready for installation, too.
There's a lot of "while I'm in there" going on with this project, though there are occasions when I opt to put things off that are easily accessible later on. As much as I enjoy making the car nice, it needs to get back on the road so I can remember why I'm doing all this to begin with.
Gotta leave something for my future self to do, right?
However, one of those "while I'm here" tasks was refurbishing the fresh air box by cleaning it up and resealing and replacing some hardware that was missing.
What a pain in the ass. ![]()
Felt great to cross that one off the list.
I spent some time cleaning the under carriage, and I'd say it's just about concourse ready, huh?
Anyway, I installed the 19MM ATE master cylinder only to find that the hardline that connects it to the tunnel fitting had thread that were mangled well beyond repair, so I placed another order through PMB.![]()
Sad face -
While waiting for the new hardline, I installed the rear calipers and started to fit the top strut mounts.
I opted for the Porterfield R4-S pads again. ![]()
Unfortunately, the replacement line from PMB was about a 1/2" too short. There's probably about an 1/8" of give between the fitting on the firewall and the master cylinder. They were awesome and had a newer, longer one at my door within short order. ![]()
But then the project stalled again for quite a while.
So the car become a shelf again, but I did get a new peg board and found some relics with my tool collection. ![]()
Jump ahead to Sept of this year and we're nearly caught up, though there's still a ton of progress to post.
The line that PMB sent did happen to fit this time around. Once installed, I realized there wasn't anything stopping me from throwing in the cross beam with steering rack.
While it would have been nice to have had someone help ease the steering shaft into the receiving end in the cab, I did manage to get it done by myself.
You may notice the fuel filter and pump are in the fuel tank bay, but I later moved those back the engine compartment. More on that in a future post.
Rebel Racing's RSR bushing kit is so awesome. I got the spherical washer kit, too, which was helpful for my chassis. After a little shimming, I was able to get both sides moving without any binding. It's really satisfying when you get it dialed.
I did have to clearance some of the powder coating out the way to get the rear part of the kit to fit in the crossbar. The extra thickness of the powder coating was just enough to be an issue.
Here's a video showing one side moving -
https://photos.app.goo.gl/TjbDn8poLdRFVK8fA
That's probably all the updates for tonight. More to come, soon.
All pretty straightforward here, though trying to lift this in by myself while compressing the strut and attaching the ball joint nut was less than ideal. Now that I think of it, I'm pretty sure my wife lent me a hand.
It was good to get the m/c all buttoned up. I added a new connector and some strain relief shrink tubing to the sensor wire as the original sheathing was cracked and brittle.
Tops in, but the 914 Rubber poly bushings are thicker than the OEM rubber and barely compressed enough to get the KONI top nuts fully seated.
[attachmentid=987359]
I found my 20-year old power bleeder and while it did hold pressure and had a functioning gauge, the lines were unsurprisingly cracked and needed replacing. Amazingly, the manufacturer had everything in stock, so I went ahead and got what I needed to refurb it.
I have two bottles of the ATE DOT 4 brake fluid, but I first flushed everything out with some Lucas DOT 4 fluid as I knew there would be some crud in the system.
All ready to go here.
Still on stands, slightly less junk on it at this point. ![]()
I had a lot of brake fluid, so I tried my best to really flush things out. Pretty nasty.
After many years, I had a functioning brake pedal again. I'll bleed them one more time once I get it back on the road.
With the brakes done'ish, I directed my efforts back at the front end. I lubricated the torsion bars and and popped them into the A-arms.
I probably over-punched the a-arm caps, but I did paint them with enamel as directed by the Haynes manual which prevents them from rusting, and also seals the torsion bars from water, etc.
The book also called for a particular grease on the torsion bar adjusters, so I went ahead and ordered it. Not sure that I have pic of it smeared on the threads and contact point, but you're welcome to use your imagination. The grease seems even stickier than normal bearing grease, but then again I may just be trying to convince myself that it's different than the bearing grease I've been using elsewhere on the car. ![]()
Foam washer, check.![]()
Installed, before I slathered on the grease.
Another side quest was bringing some life back into the old tank. The previous owner, perhaps with this current owner's assistance at the time, opted to fix some light surface rust by applying a healthy coat of POR-15 over the entire tank, fittings and all.
Remember when POR-15 was all the rage? Andy sure does
Anyway, I gave the entire tank a sanding and then really went to down on the few spots where surface rust had started to appear again, mainly where it had been in content with the carpet pads. I've since replaced the pads with closed-cell foam as it won't hold water like the carpet did.
Once primered, I used Rust-Oleum Satin Black with their 5 in 1 spray nozzle. I was skeptical, but that noddle has fan settings and they were so much nicer than the normal cone pattern you normally get.
My only critique is that their satin is still too glossy. I'd contemplated hitting it with a matte clear coat, but then decided I should just let it cure and put it back together again. Sometimes the juice ain't worth the squeeze.
Side note:
Photography backdrop stands make for a great parts hanger for spray painting.
I didn't trust that the fittings on the bottom tank would be leak-free if I tried to reinstall them without giving them a little love. After using heat to get them apart, I found they both had felt washers and I think one side may have had an aluminum washer as well. This sent me down a rabbit hole of trying to find the original felt washers.
My initial efforts came back with nada, so I sent ChatGPT on a high-thinking-level search. It led me to some old posts here that referred to a member that had been making them, but all those posts dried up about four years ago and I couldn't find any related member vendor posts.
AA sells a kit with the two tubes, aluminum nuts and copper washers. Copper. PET calls for two felt washers, but the more I dug around, the more I saw that people had been successfully using copper washers instead.
I also caught a thread here where someone suggested annealing the copper to soften it and remove work-hardening before installation. Oh great, another rabbit hole! But he was right. It's easy to do and there's no downside from annealing, so that's what I did.
Once tightened, I poured a half cup of water (I know, I know) into the tank, and it was holding tight. Obviously that's not putting any head pressure on the fittings, but it gave me some hope. I dumped the water, dried out any residual moisture and then installed the sender and filler neck, both with new gaskets. ![]()
I've capped off the return line as I have single stainless line in the center tunnel as that's all I need for carbs. I did look into capping off the inlet fitting, but didn't find any great solutions.
I was discussing the tank with my buddy Doug (hi Doug), and I'd mentioned how I had relocated the low-pressure rotary fuel pump from under the engine bay to under the fuel tank, similar to what the factory had done later on. He brought up a few considerations, which also made me think about how many times over the years I've had no-run scenarios where I'd had to access the fuel pump for diagnostic or replacement purposes.
That led me to imagine sitting on the side of the interstate with a full tank and a broken fuel pump buried underneath.
Screw that.
So the other night I ripped it out and will be relocating both the pump and filter back to the engine bay.
Prior to removal:
We're nearly back to real time. Thanks for hanging on.
I lowered the front end onto ramps for the first time in many years the other night. With the car "on the ground" you're supposed to smack the front RSR bushing carriers back with a mallet to take up any slop, then torque them to spec.
I still need to perform a basic front alignment, but it sure is nice seeing her on partly on the ground. I also needed to get more clearance in the back for the next tasks.
I'll sheepishly admit that I've been running mismatched exhaust heat exchangers since the motor rebuild. Long story short, I intended on running stock HE's as I only have one good stainless unit due to a prior mishap. However, I couldn't get the driver's side HE to seal correctly, so out of desperation I installed the SS HE I had lying around and lived with it.
That never sat right with me, and I have doubts that they flow the same as one another, which could cause some tunability problems.
Hoping to fix the issue, I took a flat file across both mating surfaces on the steel exhaust, and it's now about as good as I can make it short of bringing it to a machinist to have the faces milled.
Since I'd annealed the copper washers on the tank's fuel fittings (see a few posts prior to this one), I dug into whether or not I should also anneal the exhaust sealing rings, being that they're also copper. Once again, I sent ChatGPT out on a research mission. Sure enough, in the instructions on 914rubber.com's installation help guide (https://914rubber.com/exhaust-manifold-gasket), they say to:
"Anneal before use. To do so stick to top of pipe with grease, heat with torch until red hot and then drop in water. This will soften the metal allowing it to seal better."
Now I'm no scientist, but I don't see why you should have to stick them to the top of a pipe with grease. So I brought out my trusty fireblock and heated them with my propane torch until they glowed red hot. You also don't have to drop them into water, though unlike steel, dropping copper into water won't harden them, so that's okay too. You can also let them air cool.
I read elsewhere that you can tell if copper has been annealed by dropping the item lightly onto a hard surface and listening to the sound it makes. If it "pings," then it's work hardened (from the original stamping/machining process), and if it makes more of a dull "pong" sound, it's annealed. I tested them before and after, and sure enough, that was the case.
This guide gets into the weeds about Type 4 exhaust sealing if you're interested:
https://www.richardatwell.com/technical/Exhaust.html
I torqued everything to spec, plus a little more, and thankfully all the exhaust studs held this time. I expect to have to come back and retorque after a few outings. Hopefully it won't leak.
Mismatched heat exhangers -![]()
Annealing -
Stock heat exchanger hopefully ready to go in and not leak this time -
Installed, nothing broke, yay -
While I'm under here, I need to mount the fuel pump and filter, redo some of the fuel line routing, adjust the valves, and install the CF Performance Spherical shift linkage bushing to fix the firewall bushing issue.
Once the car is down on all four wheels, I can start to dive into the 44 IDFs again, fix some funky linkage issues, and install the 123 Ignition distributor.
Then back up with the front end, get the steering toe and center figured out, check all the bolts again for tightness, and then I guess it's onto test driving.
The tires have tread, but they're aged out and I wasn't a fan anyway. I also need a new tire for the spare.
More updates once I get some more work done. Thanks for following along!
No issue just thought it was worth a mention when I read 44's ,your motor looks great by the way ,keep up the good work,cheers .
75-76 fuel pump mount... that type of pump pushes better than pulls..
That said , ive done em both ways...
http://w.914world.com/bbs2/index.php?showtopic=374782
Been a little under the weather the past week and a half, but progress has been made.
Hooray Randy! Looks good! Glad to see you getting her all back together.
