I got oil pressure and oil temp gauges. The instructions are generic and I'd like some specifics about how to install them on my 1.7L '72. Sorry if these seem obvious; I've never done this before.
1. Standard ground or floating ground? I'm leaning toward floating because it looks obvious how to attach the ground. On the standard ground, how do I attach the gnd wires?
2. What do I attach the wire from the gauge light socket to the light switch to? The headlight switch? Which connector?
3. Which fuse do I use for power? #9?
4. I figure I will just attach grounds to a screw on the body, either an existing one or a new one.
5. What is the "switched +12v" light shown in the instructions? The dummy light?
6. Does the oil pressure sensor get installed where the current oil pressure switch is by the distributor? Doesn't appear to be any room, but I'll need to move some hoses, etc out of the way.
7. Where does the oil temp sensor go? The instructions state that it can replace the drain plug. Is this correct?
8. Where is the best route for the wires? I was thinking thru the middle along where the other wiring harness is located. What should I do with them in the engine compartment: zip tie them to other wires, or let them hang free, or what?
If anyone has done this and has pictures or a more detailed description, I'd appreciate it.
where are you mounting the gauges?
if your mounting them in a center console there is already wires for power, ground, switched power, oil temp, and the blk/blu wire for gauge illumination.
for the oil pressure sender, the sender will not fit in the existing hole you have to remove the oil pressure switch next to the dizzy and use hose to mount the sender on the fan housing or wherever you decide.
I'm mounting the gauges under the dash with a 2 gauge bracket. There is no center console. Looks like I'll be adding wiring, but someone confirm this.
What do you mean by "next to the dizzy"?
What kind of hose should I use?
Thanks for the pictures.
I'll try to get to this the next few days and see if I can answer my own questions.
Is there no thread on this already? I tried to search but wasn't able to find anything. Or is this so easy no one ever has to ask?
Unless you use the ashtray, this makes a convenient mount using the VDO rubber bracket. Just cut off the angled top and then use the ashtray mounting holes to attach the bracket.
Here's what I think I will do:
WIRING
1. 3 connections for gauge: wire from gauge to #8 or #9 fuse, wire from gauge to ground, wire from gauge to sender. Seems like this will work.
2. Sender grounded to either the engine block or a wire to the metal somewhere.
3. For illumination, I will tap into the existing illumination wires and connect them to the gauge. I will look on the fuse box to see where these connect and maybe connect them there instead.
I was going to attach them to the light switch, but I'm not sure where; the Haynes wiring diagram was hard to figure out.
PRESSURE GAUGE
4. I need an extension for the pressure gauge. I went to get one like the one shown in one of the images in this thread (metal coated rubber hose with threaded fittings on either end). The thread on the sender appears to be a M10 x 1.0. but it is tapered. The FLAPS had fittings that were close, but not quite. Apparently there is a non-metric pipe size that fits, but I was not comfortable with this; I don't want to strip the threads or screw (pun intended) them up.
[color=#FF0000]
Where can I get metric fittings for this?[/color]
You can get the hose from Auto Atlanta and the wiring ( on the sender WK goes to factory light, G goes to your gauge) if you use a rubber extension you will need to ground the sensor if you use the steel braided hose it will ground through the hose to the engine.
As for the wiring fuse 9 is your switched power, the illumination wires go from the light switch to the gauges (no fuse) it is a black wire with a blue stripe you can ether tap on at the switch or at the gauge.
Jeff, I have a extra brake hose you can use. I know it fits the sender, but you'll need to find a male to male fitting for the case to hose. Maybe Metric Specialties?
Following along quietly....
I have a vacuum guage as well that will be added but great help so far.
I threaded an 1/8 NPT fitting down in to my block. The adapter had -4AN fitting on the other end. Then I used a female/female -4AN 12 inch hose. Then I used a second -4AN to 1/8 NPT adapter (male/Male) to a 1/8 NPT (female female) then the VDO sender.
David
I bought this kit. Has everything you need, including the right fittings, and is beautifully machined.
http://www.42draftdesigns.com/vw-audi-oil-pressure-relocation-kit/
As for the wiring, you can also try running your wires down under the carpet to the factory console harness (if your car is so equipped).
So I got the gauges installed. I think the oil temp one works; I haven't got the car hot enough to register. The gauge starts at 120F and I only drove around the block, let the car cool, then fixed a connection. When I started the car a little while later (about 15 minutes) the gauge twitched a bit.
The oil pressure gauge maxes out immediately. I'm thinking this is an electrical grounding issue? I've got it grounded to the fan housing in the engine compartment.
Also, the gauge lights don't come on when I turn on the headlights. I tapped into 2 (one wire per gauge) of the black and purple wires that are for the gauge lights. Went from there to the gauge light. From the gauge light to ground on metal by knee board.
How do I remove the lights from the sockets? I pulled and they don't come out. They don't seem to twist either. I have VDO gauges.
I tapped into the same fuse (#9) as the radio for power to the gauges. Used a piggy back connector and put 2 wires on one spade, then into the fuse connection.
I'll try and post pictures later.
I'll also post what I found to use for a hose for the oil pressure sender.
Just finished the wiring harness for the appearance group gauge cluster (like OEM) for those that are interested they will be available for $58 each, and will plug into the factory wiring harness as shown. Doing these to promote the consuls, so if you are looking to add these in soon it will be a plug and play.
It seems the oil temp gauge works. I drove the car for 20 minutes and it went to almost 180. The sensor is under the car and not covered, so the air probably cooled it. I'm just going to assume the oil is hotter than that. Probably should get a temp gauge and try to measure it somehow. Any thoughts on how to do this?
The oil pressure still pegs to the right. I'm pretty sure I hooked it up right, but clearly something is wrong. Any ideas?
The lights on the gauges don't work either. I tapped into the lighting wires for the other instruments. Does it matter which wire or wires I use?
Here are some pics:
One other question: how do I pull out the bulbs on these gauges?
Looks like the black part should pull out the back of the gauge housing; the bulb will be held in that.
Check to make sure that you have +12V on your lighting circuit when the headlights are on. Do the other instruments light up? The instrument light wires are mostly black with a blue stripe, except in 74+ cars (maybe also the earlier ones, not sure!) a gray wire connects in basically at the center console location.
Where is the oil pressure gauge signal wire hooked to? If you hooked it up to the stock sender, you'll get either full-deflection right or full-deflection left, I forget which. The stock sender is just an on/off switch for the light; you need the correct sender for the gauge.
--DD
I'll add to Dave that if you are using the correct dual terminal sender, then you obviously have it remotely mounted and you must be sure it is getting a good ground to the sending unit housing or it will do what you are seeing.
I got the gauges to work!
I'm getting readings of about 220 F on the temp (running at 3-4K RPM on mixed roads-up, down, straight, etc) and about 50 psi on the pressure (at 3-4K RPM). It goes down a bit when the temp is higher and at idle.
The instructions that came with them are not entirely correct. Here's my wiring diagram:
I'm starting my own gauge journey today.
https://www.amazon.com/gp/product/B096VLD2QF/ref=ppx_yo_dt_b_asin_title_o01_s00?ie=UTF8&psc=1
The fittings I picked up local at ChicagoConnection.
So far, have it everything snugged in there and will be starting the wiring, installing the temp sensor, etc.
(BTW--Those bulbs do just pull out...just need to apply a little leverage when your pulling).
Just be careful you don't end up with GAS. Gauge accumulation syndrome..
HA! I'm trying to keep it classy!
Tackling the oil temp sensor. 1971 with a 1975 2.0L
I am replacing the Taco Plate with 914Werks' billet cover, aftermarket VDO sender.
The factory wire on there currently is black. and the bracket is attached to the taco plate (the tab / guard / crimped tail)...hoping that comes down easy.
In the meantime, I pulled the carpet on the tunnel and there isn't any connectors under there for a center console...so now what?
Just when I think I'm getting momentum...
I have everything operating..except the pressure gauge pegs to the right every time. I've tried several grounds:
1-gauge grounded under the dash (to the bolt holding the climate control unit).
2-I've tried several scenerios to ground the sender:
it's mounted to the location on the fan housing using a metal capacitor bracket....that should do it!
I've tried running a wire to the primary ground next to the battery to the sender housing (and tried the oil line bolt.
The other night on one of my shake down laps, when the car was warmed up, when I would come to a stop-the OIL light came on. As soon as I started rolling, it went off. Was slightly dimmed at one point.
Checked the oil...she's full.
I didn't need to run a ground wire from the sender to the gauge, did I?
Stumped!
Are you using the factory oil pressure sender?
No. I'm using a VDO dual pole sending unit...it's in a post just before my last one.
The dual pole senders trip the oil light “early” at a higher point than the oem sender so the fact you see the light coming on isn’t unexpected.
Good to know on tripping the light early.
...now to get this gauge from Pinning immediately when I turn the key.
On the oil pressure gauge pinning issue, suggest the following:
1) disconnect the sender at the GAUGE end. Does the gauge still go to full scale?
- if YES, then somethings wrong with the gauge or your connections to it; make sure the gauge case is connected to chassis
- if NO, then go ahead and connect the sender wire again
next:
2) Gauge should still be indicating full scale (incorrectly). Disconnect the sender at the SENDER end. Does the gauge still go to full scale?
- If YES, then you have a wiring issue, possibly sender wire is short to chassis
- if NO, then you have a dodgy sender OR wrong sensor / gauge combo
You might want to double check the connections at the sender end; swapping the switch and sender connections won't harm things but will exhibit funky behavior..
Hope this helps / makes sense
- Tony
