Printable Version of Topic
914World.com _ 914World Garage _ OT- Drill press
Posted by: jeffdon Aug 9 2016, 09:24 AM
I have an old 15" Walked turner drill press that dates back to the 40's. It's a wonderful beast of a cast iron machine, but the pulley that goes on the quill is messed up. The bronze splinned bushing inside was slipping. But I am a smart guy, and taking inspiration from the method we use to put the cam gear on a type 4 crank, I heated it up on a hot plate thinking I could then drive the bushing in tighter.
I ended up melting the largest diameter step off the pulley.
I have not been able to source a replacement. Got to thinking, since I am trying to run at a lower speed, why not just get a motor controller and turn down the speed?
Any one know if this would work, and a good place for a speed control?
Posted by: toolguy Aug 9 2016, 09:38 AM
It's called a VFD. . Variable frequency drive
Posted by: jeffdon Aug 9 2016, 09:52 AM
QUOTE(toolguy @ Aug 9 2016, 08:38 AM)
Thanks. Will this in any way cause damage to my motor if I use it at reduced speed all the time?
Posted by: stugray Aug 9 2016, 09:54 AM
I have a 3-phase 3/4 hp Baldor motor on my fish tank pump using a 1hp single phase VFD.
It converts single phase to 3-phase and you can adjust the speed with a potentiometer.
I got it from a place like automationdirect.com but I would have to look through my notes.
I am taking down the fish tank and cant decide if I want to put the motor on my drill press or my attic fan :-)
Posted by: MrKona Aug 9 2016, 10:16 AM
Have you put a WTB ad on OWWM.com? If you haven't checked out that site yet, you should. It's to old tools, as this site is to 914s..
Posted by: worn Aug 9 2016, 10:18 AM
QUOTE(jeffdon @ Aug 9 2016, 07:24 AM)
I would run the motor as it was designed and fix the problem. Is the part with the splines still OK? If so you can have a machine shop put it into a step pulley. It will not cost a lot and it will save the function and originality of an excellent tool. You could do it yourself...if you had a drill press
If you do go variable speed, try to find a motor designed for it. That would cost though.
Posted by: DavidSweden Aug 9 2016, 10:47 AM
QUOTE(toolguy @ Aug 9 2016, 07:38 AM)
the variable speed drive (VSD) should work fine and they are cheap. A single phase VSD can run a 3 phase motor but you need to be sure what your buying . You will need to set it up but its not brain surgery. you can usually use a variable resistor to control the speed.
I recommend installing an emergency stop button.
Good luck
Posted by: Mark Henry Aug 9 2016, 11:11 AM
I take that it's a cast aluminum pulley?
Can you machine it down and then thread and bolt on a steel weld-on style pulley with no hub?
Tractor supply will likely have one.
Posted by: jeffdon Aug 9 2016, 11:33 AM
QUOTE(Mark Henry @ Aug 9 2016, 10:11 AM)
You know, I was just in tractor supply thinking the same thing. I take it you are thinking to drill 3-4 holes radially?
Posted by: jeffdon Aug 9 2016, 11:34 AM
QUOTE(MrKona @ Aug 9 2016, 09:16 AM)
Awesome, thanks. Will check it out.
Posted by: Mark Henry Aug 9 2016, 11:51 AM
QUOTE(jeffdon @ Aug 9 2016, 01:33 PM)
Need to see it.
Posted by: MrKona Aug 9 2016, 11:52 AM
QUOTE(jeffdon @ Aug 9 2016, 10:34 AM)
Also, check out the classifieds on OWWM.org. (Note the .org versus .com). The two sites are affiliated... how I'm not sure. I think you need to register to access the classified ads. Great sites.
Posted by: jeffdon Aug 9 2016, 12:06 PM
QUOTE(Mark Henry @ Aug 9 2016, 10:51 AM)
Need to see it.
Damaged pulley at the top. New (but wrong size) pulley at bottom. Could one of the proper size be attached in a way that works?
Posted by: Mueller Aug 9 2016, 12:21 PM
Post pictures of damage. Maybe it's something we can fix at my place.
You can also convert to a DC motor with a variable power supply....which I have 2 or 3 setups I've taken off of free/salvaged threadmills. Free for the asking if want to pick one up. I think 1 or 1.5hp motors.
Check out Surplus Center . Com, I bought my pulleys for my Bridgeport mill from there.
Posted by: jeffdon Aug 9 2016, 12:35 PM
QUOTE(Mueller @ Aug 9 2016, 11:21 AM)
You can also convert to a DC motor with a variable power supply....which I have 2 or 3 setups I've taken off of free/salvaged threadmills. Free for the asking if want to pick one up. I want to 1 or 1.5hp motors.
Its pretty bad. Anyone know if the splined bushing inside just presses out?
