Posted by: jmill Nov 25 2016, 08:26 AM
Just like the title says. Will they fit in front without spacers? About to buy some Euromeisters. I can get 25% of today. Use code Krmr at Automotion for 25% off $350 or over.
Does the extra scrub radius suck when parked so I should stick with 7's?
I have steel AA flares.
Posted by: rick 918-S Nov 25 2016, 09:05 AM
QUOTE(jmill @ Nov 25 2016, 08:26 AM)
John, I don't know about the 17's but I'm running their 16x8's on the front with a 25mm spacer. I have 16x9's on the rear with a 10mm spacer. My flares are glass. Don't know of that helps.
Posted by: jmill Nov 25 2016, 09:20 AM
That does help Rick. Thanks. Did you add the spacer for looks or because they rubbed on the inside?
Posted by: Steve Nov 25 2016, 10:36 AM
This is what I'm running with AA flairs
Fikse FM10's no spacers
8x17 5-130mm (19mm) 225x45x17. 235 also fit
9x17 5-30mm (6mm) 245x40x17. 255 rubbed when hanging corners
Posted by: Mike Bellis Nov 25 2016, 11:58 AM
extra scrub radius does suck when parking and low speed maneuvers. Tiny steering wheels make it worse. It will also effect your overall handling. All depends on your setup.
Posted by: jmill Nov 25 2016, 12:28 PM
QUOTE(Steve @ Nov 25 2016, 10:36 AM)
8x17 5-130mm (19mm) $700.00 Each
9x17 5-30mm (6mm) $725.00 Each
Is it a PITA to turn the wheel when stopped?
Posted by: Steve Nov 25 2016, 03:23 PM
QUOTE(jmill @ Nov 25 2016, 10:28 AM)
225's aren't bad. 235's were worse.
Posted by: rick 918-S Nov 25 2016, 09:41 PM
With 225x50's they rubbed on the strut
Posted by: jmill Nov 25 2016, 10:27 PM
Thanks for the info guys. I bought them. Now I need to sell the pair of 16x7 Fuchs I have no need for.
Posted by: mgp4591 Nov 26 2016, 04:49 AM
QUOTE(rick 918-S @ Nov 25 2016, 08:41 PM)
Rick, what size tire are you running on the rear and did they rub on the trailing arm without the spacer?
Posted by: wndsrfr Nov 26 2016, 08:25 AM
QUOTE(jmill @ Nov 25 2016, 06:26 AM)
I'd ask them for the 100 percent discount they indicated...
Posted by: jmill Nov 26 2016, 09:04 AM
QUOTE(wndsrfr @ Nov 26 2016, 08:25 AM)
I wish I had more coupons to approach 100%. I felt pretty good getting close to 50% off. I'd be lucky to get one 9" Fuchs at what I paid for an entire set of Euromeisters with lugs shipped to the house. After I sell the 16x7's I can get some tires.
I wanted to keep the 16's but there was only 3 tires to choose from in a staggered set. With the 17's I have close to 40.
