The headlight relay on my car is sticking. I need to tap it to get it to work. The part number on my relay is 111 941 583A. This is a 4 pin relay.
When I look up replacements, I find the same part number without the A at the end. And it is 5 prongs. Do I just not use one of the prongs or do I need to find the exact same relay?
My existing relay:
This is a pic of the replacement:
http://www.jbugs.com/product/111941583.html
The pic of your existing relay didn't come through. can you edit and repost?
I did find a schematic for my existing relay online:
http://www.thesamba.com/vw/classifieds/detail.php?id=1937002
Found this thread on The Samba: http://www.thesamba.com/vw/forum/viewtopic.php?t=507400
This is the wiring for the new, 5 pin relay:
It shows that 30 and 56 get jumpered.
However, further down in the thread, it is recommended to not jumper them, but instead run a constant power supply to 30.
You can always upgrade to an electronic version on the cheap...
http://www.914world.com/bbs2/index.php?showtopic=103905&hl=saab++headlight++relay
I already had the 5 pin relay so I went ahead and wired it in. I ran location 30 to a always hot source on the fuse block.
Edit: Do not run the pin 30 to constant hot. It did not work. Install a jumper between 30 and 56 and it works fine.
oops
