I'm trying to replace the air filter element in my 1973 914 1.7L. Fram CA-383 was the prior replacement.
I got one from my local parts store, but it didn't fit properly. Subsequently I ordered one from one of the big Porsche outfits online. It was the same as the one from the local store!
The 'recommended' replacement has a larger inside diameter, causing it to miss the sealing ring in the lower part of the housing. It will leak outside air directly into the engine.
Internet search has not turned up anything on this issue. Any ideas?
There are a number of threads on this. Turns out the correct air filter is no longer available, despite what the online stores say.
There are, however, filters you can make work. http://www.914world.com/bbs2/index.php?showtopic=305094 where I made an adapter to use a NAPA Gold 2011 filter. The adapters are pretty simple to make, or I can make one for you ($20 plus shipping).
The https://www.napaonline.com/en/search?q=Nty%3D1%26Ntk%3DKeyword%26N%3D1000015200%26Ntt%3D2011&text=2011&isProduct=true shows the filter is currently about $7.50 each.
If you bought your filter from AutoAtlanta, it's probably the NAPA 2011. At least, that's what they sent me when I ordered a "correct replacement filter" from them 2 years ago.
Thanks. I'll try your idea.
Too bad I couldn't dream up the right search keywords...
There is a FLAPS replacement that is really close. I had to order it and I thought I posted it a while back. Not at home this weekend but if you can.t find it PM me after this weekend.
I posted this a while back.
Dimensions:
Mann C2180 (OEM, NLA)
124mm ID
207mm OD
82mm tall
Here's what I'm running now.
Wix 42110
125mm ID
163mm OD
76mm tall
It's 6mm too short, so I cut a piece of cork gasket material the same size as the filter to fill the extra gap. I found 1/4" to be too much, so I think I've got a couple of pieces in there now that are just under 1/4" total.
Gary
