Printable Version of Topic
914World.com _ 914World Garage _ Interior vinyl pieces
Posted by: Olympic 914 Aug 11 2017, 05:50 AM
Installing my interior and saved all the old pieces for patterns. But I don't know where these two pieces go. The markings on the old ones are really no help.
car did not have a console or deposit box.
Posted by: mepstein Aug 11 2017, 06:06 AM
I'm pretty sure it's the front of the crossmember under the seats. Just to cover the paint/transition at the end of the carpet.
Posted by: sb914 Aug 11 2017, 06:10 AM
Posted by: bbrock Aug 11 2017, 07:36 AM
Posted by: rgalla9146 Aug 11 2017, 08:14 AM
Don't they glue to the top edge of the back wall at the outside shoulders of driver and passenger ?
Posted by: mepstein Aug 11 2017, 08:22 AM
QUOTE(rgalla9146 @ Aug 11 2017, 10:14 AM)
That would be the longer strips above the red circled ones. Mine actually wrap around the seam and are secured by glue and the door seal.
Posted by: Tom_T Aug 11 2017, 10:17 AM
Mark has them both right.
Test fit those short pieces & they should wrap perfectly on the front of seat cross member, just between the raised areas on the side, then mark & mask the floor so you can spray that surface neatly without too much overspray clean-up afterwards (assuming you're using one of the 2 surface spray adhesives like 3M 77, 90, etc.).
Do the same test fit, mark & mask for the rest too, but only spray a couple of small or 1 large piece at a time (spraying both floor area & leather backside) to give you enough out-time/dry time to get it positioned & on comfortably. Use a couple-a-3-4 long wooden dowels from Home Despot/Lowes to lay under the leatherette to prevent contact with the sprayed floor surface while you position & smooth-out & roll it on, moving them out of the way while working from one end to the other.
If you've ever done Formica/etc. with 2-surfact application contact cement - it's a similar process. A small rubber roller helps with the final step of pushing the vinyl into the floor/cement, but a sturdy new/unused small paint roller can work, but requires more going back-n-forth since you can't push it as hard into the vinyl/floor.
Good Luck!
Tom
Posted by: Costa05 Aug 11 2017, 10:37 AM
QUOTE(Olympic 914 @ Aug 11 2017, 06:50 AM)
I would be interested in purchasing your old pieces you saved for patterns to do the same thing you are doing. Or if someone has similar templates in electronic form they would share.
Posted by: rgalla9146 Aug 11 2017, 10:39 AM
QUOTE(mepstein @ Aug 11 2017, 10:22 AM)
Mark is right about the ones above the circled pieces, they mount vertically and wrap around the door pinch weld.
The ones that cover the crossmember have notches for the seat recliner tooth piece. They are the upper left pieces
Attached is a picture of my old rotten 1970 interior showing the last visible vestige of the rectangular piece in question.
Dimensions may help.
Posted by: Mikey914 Aug 11 2017, 10:46 AM
QUOTE(Costa05 @ Aug 11 2017, 09:37 AM)
We actually have the patterns and sell these as a kit. Yes the smaller rectangle pieces go at the seat belt area. We are now including in our kits even though the site has not updated it.
http://shop.914rubber.com/6-piece-floor-vinyl-kit-NEW-914FV6.htm?categoryId=-1
Posted by: Mikey914 Aug 11 2017, 10:48 AM
These go like this
Matt may have a better picture of the seat belt area.
These come up more often with the carpet replacement as most are gone or in poor condition. A detail that really finishes out the interior
Posted by: mepstein Aug 11 2017, 10:58 AM
I was just guessing - incorrectly but now I'm sure Rory is correct.
Posted by: Mikey914 Aug 11 2017, 11:53 AM
Matt has some pictures I'll have him post up of how it goes.
Mark
Posted by: Mikey914 Aug 11 2017, 04:04 PM
Also if interested I could do a GB for $24 shipped (domestic)
Posted by: Matty900 Aug 11 2017, 09:57 PM
They go in the area below the rear window that you can see behind the back pad.
Posted by: Matty900 Aug 11 2017, 09:58 PM
Here's another one
Posted by: Matty900 Aug 11 2017, 10:00 PM
A customer sent me this photo. It was the 1st time he has seen it and had done 7 cars
Posted by: arne Aug 11 2017, 10:25 PM
Those pieces were still in my '73 when I stripped the interior. I hope my vinyl kit has them in it!
Posted by: Olympic 914 Aug 12 2017, 06:50 AM
QUOTE(Matty900 @ Aug 12 2017, 12:00 AM)
That is the picture I needed. Looks like this is where they go.
Thanks much...
