Posted by: thelogo Aug 11 2017, 10:10 PM
Its get wet around the
Gold tee and surrounding 3 closest clamps
And will drip a nice puddle but as soon as the car is running driving
Drip go's away , even after turning off the car and restarting
Never comes back until the next sunday drive .
But then there it is again
Bolt clamps are swiveled around
So i cant really reach them
Posted by: thelogo Aug 11 2017, 10:21 PM
It get soaked in gas dripps a little then seals up
But not good for me
Like sr71 fuel line ,
Posted by: JawjaPorsche Aug 12 2017, 05:13 AM
Replace those clamps with fuel injection clamps. Your clamps can cause leaks.
Posted by: mepstein Aug 12 2017, 05:26 AM
Need proper clamps and the hose might be too large. Should be a tight fit.
Posted by: thelogo Aug 12 2017, 07:21 AM
QUOTE(JawjaPorsche @ Aug 12 2017, 04:13 AM)
Will i find these at flaps
Or somewhere else?
Posted by: 76-914 Aug 12 2017, 07:27 AM
& Is the Tee a barbed fitting or threaded fitting? Is the rubber stiff? What is that yellow ring? Hint: Take a piece of a paper towel and wrap around each joint. Pressurize and quickly check for wet spots on paper towel. One pin head drop of gas will make a quarter sized splotch on the paper. Makes it quick and easy to locate which one is leaking.
Posted by: mepstein Aug 12 2017, 08:05 AM
QUOTE(thelogo @ Aug 12 2017, 09:21 AM)
Or somewhere else?
Yes.
Posted by: rhodyguy Aug 13 2017, 11:54 AM
What is that white line on the verticle hose in post #2? Mish mash of hose varieties.
Posted by: Elliot Cannon Aug 13 2017, 10:17 PM
Replace them. Replace them all. NOW. New proper fitting hoses, and fuel injection style hose clamps. Or this...
Posted by: thelogo Aug 13 2017, 10:40 PM
QUOTE(Elliot Cannon @ Aug 13 2017, 09:17 PM)
Engine carbs transplant etc was installed about month ago
Im sure after the 1st tune up all these leaks will be resolved
But everything is fresh its not like 20 years old stuff on there
But a leak is a leak and yeh its worry some ,see below
? Question if you had to abandon take off in a concord
At what point does your mind set switch from the climb phase to the landing or crash land and does ones handling of the controls
Immediately deteriate?
Stress , blood pressure etc
Posted by: thelogo Aug 13 2017, 11:00 PM
QUOTE(76-914 @ Aug 12 2017, 06:27 AM)
When i pressurize i assume you me turn on the car or
Put it to the on postion so fuel pump runs up ???
Because if i just run pump before cranking key
No leak
Posted by: Elliot Cannon Aug 13 2017, 11:09 PM
The decision to continue take off or abort the takeoff should be made at a determined airspeed commonly referred to as V1. If a problem occurs after that speed, you will NOT have enough room to safely stop on the runway and at that point you are committed to fly and take care of the problem in the air. These poor guys never had a chance.
You have at least two different types of hose that I can see and the WRONG hose clamps. Replace them. SOON.
Posted by: Elliot Cannon Aug 13 2017, 11:11 PM
QUOTE(thelogo @ Aug 13 2017, 10:00 PM)
No leak
What kind of fuel pump are you using and what is the output pressure. It shouldn't be more than about 3 1/2 PSI with carbs.
Posted by: thelogo Aug 13 2017, 11:22 PM
QUOTE(Elliot Cannon @ Aug 13 2017, 10:11 PM)
No leak
Useing a rotary fuel pump , supposed to be 3 to 5 psi .
Lets assume for a minute that they were passed v1
And handle the problem in the air and
Are able to get engine shut down and fire doesn't cause the plane to explode .
Could the concord fly with a engine out and circle around back to land or plane was so far gone that no matter what level of pilot skill could overcome the
Crash
