I got one of the normal aftermarket replacement lights for my car's back pad (no silver rim, black switch), and like others, I'm not impressed.
Picture...
interesting option, and for sure more classic looking than that new-beetle option (which is a nice option in case you do not mind it is not original/classic enough).
Did you already try to install this?
911 switch is nothing more than a VW Type 3 dome light.
Not new beetle switches. T-1. Like the Euro max $12.25 or Empi $10.25 Pelican offers. The $11 door lamp switch gasket seems kind of goofy.
Ahhh! I hadn't seen that. About the same price that I paid from Stoddard, with shipping factored in. If this works well, it'll be good to have multiple sources.
E, I think this is what I will put in my HotRod 6
Bob B
Not in #11
Arne, the problem you'll have with this light in the back pad is, it grounds to metal on the sides. The back pad is foam all around but, this is why they have the ground wire up there so, I'm sure you can figure something out...
Yup, it arrived today, and i have already tested and figure out which wires go where to make it work. No problems there. Will attempt to open up the hole in the back pad either tomorrow or Friday.
Eric's photo shows the light mounted into the firewall. With appropriate grounding, can it be incorporated into the stock backpad or is the 911 light too deep to Fit?
The pad hole for the stock light has to be altered.
Yes, the hole in the backpad must be enlarged a bit. But the depth of the light is similar to the stock light, so I don't expect any problem on that score.
I found this replacement LED bulb to replace the original bulb. It's much brighter than the factory one, but unfortunately still runs hot. I was hoping that the LED would be cooler than the original to help preserve the original fixture as heat is the main culprit in making them more fragile. If anyone knows of a cooler running USB, please share the info.
The new Type 3/356/911 light is installed, and works perfectly.
The opening in the back pad needs to be enlarged on all 4 sides. I made a cardboard template to get the rough size transferred to the back pad. Overall opening size is 95mm x 38mm with rounded corners similar to the stock opening. If your back pad still has the metal tabs for the light to clip to, both tabs will need to be trimmed by 3-4mm each side. (I used a Dremel with carbide cutoff wheel.)
The new light has three terminals to connect, so all three stock wires are used.
Looks muy excellent. Nice job.
I bought an aftermarket replacement for mine and had the typical fitment problem. 1 minute with Mr Dremel took care of it, but your solution looks sooo much better.
That turned out nice. Good work!
