i put another set of new wires on the motor today. Double checked everything. Stuck another battery in there w/ alittle more life in it. I thought maybe the direction of the rotor was effecting fitment of the wires, so i pressed the pin out of the bottom of the distributor, turned the lower plate, and put it back together. The rotor faces 180 from before, but still the wires didnt fit right. Has anyone else had this problem w/ wires not fitting. #2 is like three inches too short! In every set ive tried!
Anyway, engine still just cranks. Im getting some spark, but seems like no gas. I bought a noid light and all injectors are getting pulse. Pulled the injectors and had them spray into a glass bottle while cranking. # 1,2,4 were all perfect, but #3 does nothing. Checked pulse again , perfect. Checked and pressure is fine. Stuck one of my spare injectors in, still nothing. then another and another. Checked the #4 injector w/ the signal from #3, perfect. Tomorrow im going to try to switch injectors and see, but is there some reason the first injector on the system would not get gas besides a bad injector like not enough pressure or something????????
Interesting enough, while cranking the motor w/ #3,4 injectors completely out, the motor almost tried to fire up! As soon as this injector problem is solved, im thinking she will be running, hopefully tomorrow morning!!! For now all i have is a pic of the one seat i put in last nite w// the custom fabbed brakets.
You go dude....kick that thing in the ass and get er runnin!
QUOTE (xsboost90 @ May 21 2005, 12:48 AM) |
i pressed the pin out of the bottom of the distributor, turned the lower plate, and put it back together. ...Has anyone else had this problem w/ wires not fitting. #2 is like three inches too short! In every set ive tried! ...is there some reason the first injector on the system would not get gas besides a bad injector like not enough pressure or something???????? |
i set the engine to tdc when i reset the distributor. Now tdc points to the timing hole like someone said it was supposed to. I have a blue #1 wire due to parting a whole set together from two, and clockwise its 1432 like it says right on the tins. The cylinders are also labeled on the tins. Ill figure it out, eventually.
