Opened the tranny to finally install the LSD. Uh, that doesn't look right.....
Fortunately, I have extra bearings lying around...
and an extra pair of 5th gear...
ahhh those light weight low drag bearings.
uber trick.
James;
Personally I think the quarter was part of the problem. Next time I would leave that part out. Don't think it was standard issue.
QUOTE (hmeeder @ Jun 5 2005, 02:41 PM) |
James; Personally I think the quarter was part of the problem. Next time I would leave that part out. Don't think it was standard issue. |
Well James, that's what happens with those big HP RSR motors like you're running!!!
QUOTE (hmeeder @ Jun 5 2005, 05:41 PM) |
I'm on it.
Remove every other bearing from the race.
Damn why didn't I think of that....
Great tip, thanks.
Maybe you'd like the super light weight, ball-less, bearings...
And John, I wouldn't be surprised that the engine had something to do with this....
Margarita says: "What do you expect from a 35 year old car."
Thanks.
the quarter is the new hot ticket for buget bimetal thrust washers.
cheap.... only cost a quarter, but don't let A/A hear about it they'll try to corner the market and raise the price to $5.00.
I see that you managed to spend some quality time with your car finally. If you leave the tranny all torn apart on the bench, she will beg you to go work on it some more (it may sound like, "you need to clean up that mess", but we hear what we hear.)
I will be picking up the sound paint tomarrow hopefully.....
QUOTE (Dr Evil @ Jun 5 2005, 09:06 PM) |
I see that you managed to spend some quality time with your car finally. If you leave the tranny all torn apart on the bench, she will beg you to go work on it some more (it may sound like, "you need to clean up that mess", but we hear what we hear.) I will be picking up the sound paint tomarrow hopefully..... |
Unfortunately, the tranny gets to sit next to the car for 2 weeks now...Mexico city this coming weekend. And I still need to pull the carbs to reseal the accellerator pump diaphragms. And occasionally, mow the lawn. OH, and locate the oil leak on top of the engine....
