Printable Version of Topic
914World.com _ 914World Garage _ Injector Upgrade
Posted by: pete000 Apr 12 2018, 11:46 AM
Nice work ! OEM Bosch injectors are getting hard to come by. Your set up would work for the VW Vanagon too !
Posted by: saigon71 Apr 12 2018, 12:16 PM
Looks great Mark!
Please continue to keep us posted. Will the upgraded AAR be available as a group buy at some point?
Posted by: Mueller Apr 12 2018, 12:26 PM
Looks good. Are those injectors reasonably priced?
I like that design better, easier to make compared to the other one.
Posted by: Philip W. Apr 12 2018, 12:31 PM
QUOTE(saigon71 @ Apr 12 2018, 02:16 PM)
Looks great Mark!
yes keep us posted on that development! also , are the connectors plug and play or is modification of the stock FI connector from the harness required?
Posted by: rdauenhauer Apr 12 2018, 01:30 PM
I like it!
Posted by: Jeff Bowlsby Apr 15 2018, 03:33 PM
Nice to have an option. I see this new bracket is not indexed to the tine on the manifold. What keeps the injector bracket from rotating around its bolt and moving from side to side?
Posted by: rick 918-S Apr 15 2018, 03:38 PM
Want
Posted by: Dave_Darling Apr 15 2018, 09:37 PM
Is there any reasonable way to have the electrical connector point the same way as the stock injectors?
--DD
Posted by: barefoot Apr 16 2018, 05:07 AM
Nicely done, for your future runs, please add some big fillets between the "sheet metal" part and the cylindrical part, also at the nipple to larger diameter corner, since these are direct metal moulded parts
Posted by: brownaar Apr 16 2018, 08:03 AM
Very nice. My only concern is have you added another potential leak point in the system where the injector mates with the bracket?
Aaron
Posted by: McMark Apr 16 2018, 09:30 AM
Yup. As soon as I make sure it works. I'm also pondering some possibilities that would allow my AAR to be installed as a standalone part -- making it applicable to D-Jet and L-Jet cars.
QUOTE(Mueller @ Apr 12 2018, 02:26 PM)
I buy mine from DeatshWerks at $260 for 4. But these injectors are on TONS of new cars. So the pick-n-pull available should be HUGE.
QUOTE(Philip W. @ Apr 12 2018, 02:31 PM)
Adapter plugs could be made available pretty easily.
QUOTE(Jeff Bowlsby @ Apr 15 2018, 05:33 PM)
Nothing, I suppose. I'm not sure why they would be moving around. These will use the stock fuel rails as well, so that should provide some additional rigidity to guard against that concern. If I do another run I'll look into adding these tabs. I didn't add them initially because I was concerned about machining costs.
QUOTE(Dave_Darling @ Apr 15 2018, 11:37 PM)
Nope.
It does rotate freely, so you can put them left/right/down or anywhere in between.
QUOTE(barefoot @ Apr 16 2018, 07:07 AM)
I'd love to hear more about what you mean. These are CNC machined from aluminum, but you said "direct metal moulded parts" so I thought maybe you meant DLMS/3D-metal-printing. I understand that adding fillets would add strength, but it doesn't seem relevant to this part (no strength necessary). If you're seeing something I'm not, let me know.
QUOTE(brownaar @ Apr 16 2018, 10:03 AM)
Sure. It's an additional potential leak point, but there's not much to be done about this. New injectors are ALL rail mount, so in order to upgrade I had to accept this fact. But it's a potential leak that present in every car that uses a rail-mount injector, which is pretty much every car produced in the last 10+ years. So I'm not doing anything unusual here. Those cars don't have leak problems, so as long as my parts are machined right they shouldn't have a lea problem either.
Posted by: Jeff Bowlsby Apr 16 2018, 10:25 AM
It looks like if the bracket rotates, the injector could come loose so its seals could become loose. The bracket will rotate if its nut becomes loose or otherwise fails to prevent rotation. The OEM fuel rails when installed will not prevent this rotation.
Install an injector as in your photo and loosen the nut. Does the injector tilt when the bracket rotates? If so, the gaskets may not seal against the pressurized fuel.
Believe me, your idea is interesting...if it works. The harness connections actually align better when they lay off to the side like yours do. What are those - Delphi or Weatherpak connectors that would be needed? They could be mounted to an existing harness, not sure about an adapter to a D-Jet/L-Jet harness - seems not to be the best solution.
On the injectors, what are their flow ratings and how well do they substitute for stock injectors?
Posted by: McMark Apr 16 2018, 11:43 AM
QUOTE(Jeff Bowlsby @ Apr 16 2018, 12:25 PM)
I know what you mean about tilt. I thought about that and I'll be doing some 'forceful' testing of their resistance to leaking. That's paramount. But again, this is how most injectors are installed these days -- and the upper o-ring system is a tight fit. Lots of compression to ensure a tight fit. And Bosch provides machining specifications which were all used in the making of this part. So this isn't a part I completely made up -- it's built to the factory design specs for these injectors.
It's a Delphi connector and if everything works out I plan on offering uncrimped connectors for converting a harness or an adapter plug that will retain the original connectors. Obviously an adapter is less preferable, because of the corrosion issue.
The smallest available from DeatschWerks is 42lb/hr @ 3bar/43psi. Converting those to 2bar/28psi results in 34lb/hr, which is pretty close to stock 2.0 injectors.
BUT I'm pulling that stock flow rate from your http://www.914world.com/bbs2/index.php?showtopic=78993 which doesn't specify the fuel pressure those flow rates are measured at. So if the listings in your thread are already at 3bar, then that changes things. There are other sizes available, including 31 lb/hr @ 3bar. So sizes shouldn't be a problem.
Posted by: McMark Apr 16 2018, 12:04 PM
I think I need to order some 90-degree elbows...
Posted by: Jeff Bowlsby Apr 16 2018, 12:18 PM
The chart indicates a 300 kPA test pressure for all listed injectors and that = 43 psi, info which came from the reference literature I created the chart from. Based on that the 1.7, 1.8 and 2.0 injectors flow at 18, 26 and 37 lb/hr.
The fuel rails I have seen are stable, brace the injectors to each other and do not allow injector tilt.
Posted by: Dave_Darling Apr 16 2018, 12:23 PM
QUOTE(McMark @ Apr 16 2018, 11:04 AM)
Or perhaps extend the fitting a bit and have it make a ~75 degree bend?
--DD
Posted by: barefoot Apr 16 2018, 01:55 PM
Even though the fuel connection is with a rubber hose, there will be vibration induced to the hose attachment nipple. With a sharp corner where the nipple ends, thats a stress riser with may result in fatigue failure and a big pressurized fuel leak. We always use a large a fillet as possible in aircraft fuel system parts.
I thought you were using direct metal moulding, but CNC machined parts can easily incorporate fillets.
Posted by: McMark Apr 16 2018, 02:19 PM
QUOTE(Dave_Darling @ Apr 16 2018, 02:23 PM)
--DD
The problem there is that the 1.7 an 2.0 runners have the fittings at different angles. So any angle I build in will make two versions necessary.
This was what I settled on as the best solution to that issue.
Posted by: McMark Apr 16 2018, 02:20 PM
QUOTE(barefoot @ Apr 16 2018, 03:55 PM)
I can see where that would be helpful on the nipple.
Posted by: Dave_Darling Apr 16 2018, 07:20 PM
QUOTE(McMark @ Apr 16 2018, 01:19 PM)
Ah, poop. No good compromise angle that will work OK with either, then? That's a bummer.
--DD
Posted by: porsche913b_sp Apr 19 2018, 06:41 PM
Nice
when are you taking orders
Posted by: jcd914 Apr 19 2018, 09:08 PM
Why not build a fuel rail with proper openings for the injectors to fit into and seal as designed?
The rail could have brackets that attach to the studs on the intake runners and hose connections on each end.
It would not look stock but would clean up the engine compartment and eliminate the injector elbow hoses.
That is the plan I have for the megasquirt engine in the garage.
Jim
Posted by: rdauenhauer Apr 19 2018, 09:40 PM
Posted by: jcd914 Apr 19 2018, 09:48 PM
Yes I was thinking of something like that.
But I like the smaller injectors Mark found and I think with them a bit lower profile rail could be mounted.
Jim
Posted by: edwin Apr 23 2018, 08:17 AM
Have you changed the lower orings on the injectors?
They look different to the standard round oring that is normally fitted to these style injectors. I assume you are fitting original style square rings?
Cheers
Posted by: McMark Apr 23 2018, 12:04 PM
QUOTE(jcd914 @ Apr 19 2018, 11:08 PM)
I looked at it, but machining costs were just as high and I don't like the way it looks. These brackets hold the injectors
FIRMLY. I will still be doing pressure testing for possible leaks, but my initial impression of them mounted is that a fuel rail wouldn't add anything for rigidity.
QUOTE(edwin @ Apr 23 2018, 10:17 AM)
Cheers
Yup. I cut off the round oring and the plastic support, then the stock square o-ring fits perfectly. Lucky accident.
Posted by: John Jentz Apr 24 2018, 08:04 AM
QUOTE(rdauenhauer @ Apr 19 2018, 11:40 PM)
Will the engine go back in with those rails? With straight hoses the existing rails hit the engine shelf. These will not bend out of the way.
Posted by: Mikey914 Apr 24 2018, 09:19 AM
I always remove my fuel rails (at least now), as it's easy to damage the hose on the injectors.
Posted by: McMark Apr 24 2018, 09:37 AM
Mike's got it. Pulling the injectors off the intake is the best way to be safe.
But, no, these wouldn't clear the suspension ears.
