Does an alternative exist for the 17 mm drain and fill plugs in the transmission? That female 17 mm socket is a pain. Something with a male hex (for a wrench or socket) would be much better.
The 17 mm Allen is a pain? I just use an Allen socket on a ratchet. Never had a problem. I'm not sure that you will find a metric pipe plug, and if you did I'd be afraid of some road debris breaking off the head of that plug and dumping transmission fluid all over the highway.
Sure is, get the drain plugs from an early 901 (911/912) transmission, exactly the same except 17mm male end.
I have them on all my transmissions.
Thanks for being a great host!
I had this motorcycle axle tool on hand- amazon prime, walmart, bike shop etc
Where do I get these? Looked on pelican and couldn't find them.
Dimples in Florida sells a fantastic drain plug with a monster magnet in it.....check it out.
gg
Searches for dimples and dimple were massively unsuccessful. Got a link?
