I know this comes up every few years, but LED lights are one of those things where the tech is moving really fast, and what was true 2 years ago is old tech today.
Whats the word on LED headlights? Right now I'm using 55watt H4s, which were the bomb 15 years ago when I started restoring the car the first time. These days they seem dim, and especially after the episode last Sunday, I want to do anything I can to reduce the electrical load on the car. I don't think my car needs a 160 amp alternator, and I want to be sure I'm making the best use of my 55amps on tap.
I also want to make sure the LEDs are focused properly in the reflector so I'm not blinding on-coming traffic. I know that has been a concern with LEDs even last year.
Zach
Look up reviews for Jeep Wrangler led lights. They are what I bought a couple years ago for my 914 and they are awesome. 5 minute install. I gave a spare set to my father last week for his wrangler. He loves them. I know it sounds strange to shop for Jeep lights but it’s the same 7” bulb and there are so many jeeps so lots of choices and reviews.
The 914rubber kit. We watched Mark change them over in about 15 minutes while in Newberg last June.
I put a set of the LED headlights in Betty's car. There was a night and day difference (rimshot). Direct drop in for the H4 lenses. Takes a little longer to pull the wires from the buckets, and reinstall the wires from the transformer. The difference in brightness is a quantum jump from the halogen bulbs, which were a quantum jump from the sealed beams that came with the car. And it lowered the amp load on the alternator too.
I am definitely putting them on Igor when he is back on the road. And I am fairly sure Betty will agree to put them on Elwood too.
They are the biggest bang for the buck I have ever put on a 914.
One issue with putting LEDs in standard H4 enclosures is that the reflectors don't always work well with the LED beam pattern. Usually it is a must to change the standard H4 reflectors when going to the LEDs for the best results but some do work.
Also Check out https://vintagecarleds.com/ as they have 4000 and 5500 L versions along with quality Hella H4 reflectors.
Zach,
I'm surprised that you're still using the 55W H4's, & never upgraded to 80/100W over 15 years.
While not LED, the High Powered H4 80/100W kits with relays works really well, projects the light out well at full luminescence, & isn't in the blue range which can fade in certain conditions & it used to be LEDs were weaker than halogen (H4) at the long range high beam projection (I don't know if that's still the case).
I've had the 80/100W kit in our 88 Westy for about 15 years now, & the difference was marked. If not available from 914 vendors, GoWesty has the 80/100W Kits for the early Splitty (H4 converted) & Bay Window Buses & Westfalias - which are using essentially the same 7" diameter headlights as our 914s, & the wiring harnesses are about the same.
Two other issues of which to be aware on any vehicle upgrade, is that the reflectors in the newer cars equipped with LED headlights are designed with the LED's lighting & heat characteristics in mind, in order to maximize & properly "throw" the light, as well as to dissipate the high heat generated by the transformer (?) mechanisms at their bases.
There have been a couple of cases that I know of, where LED lights have been retrofitted into older cars & the heat wasn't properly vented so the wiring &/or plastic parts were melted, & where it caused a larger car fire (both headlights & other exterior & interior lights). While the heat build-up problem is supposedly mostly with lower cost & cheaply made LEDs - there is still significant heat in LEDs.
If you have any LED retrofit bulbs in any lamps at home, try touching the base after the light has been on for awhile to see what I'm talking about, & most of those are similar 60-100W equivalent lights.
It sounds like a lot of people like the 914Rubber LED conversion kits, but I can't speak to it because I'm not using LED headlights in any of our cars, but our Westy does have the other LED exterior & some interior LED lights upgraded with no problems so far.
Cheers!
Tom
Carmagic.us
Engelbert is a 914 driver and light fanatic.
This is what I chose.. From a kenworth dealer these are just h4. And I will use the 914 rubber LED bulbs
This is the 914Rubber kit. It’s important to me that the car not look “out of place” ie: people don’t point and say ‘hey! That’s not stock.’
As you can see in the side by side, the LED light blows away the H4. Imagine if I was to compare to a regular sealed beam!
To quote Pirelli loosely great power with out control is useless.
Even with out the correct reflectors the LEDs are an improvement. But the light is not necessarily focused in the correct locations. I broke on of my reflectors and had to put the standard H$ back in for a while. there was a very clear difference in the patterns and while better than stock, it was very clear the standard H4 reflector did not make the most of the light produced.
On a somewhat recent thread on the subject, someone recommended these from TheSamba. I don't have any experience but thought they looked interesting enough to save the link.
https://www.thesamba.com/vw/classifieds/detail.php?id=2174710
Backordered at 914Rubber. Other than the anything but stock look, any thoughts on these? https://www.amazon.com/gp/product/B015SL0MSK
These were mentioned on another recent thread with the same topic:
https://www.amazon.com/dp/B013FX3YWO/?coliid=I15UYRLE1MPV9G&colid=2BAXT6134E2WS&psc=0&ref_=lv_ov_lig_dp_it
I'm still not convinced to go balls in on headlights, every unbiased test I've seen so far says LEDs are brighter short range, but the high beams do not throw the light as far as HQ halogen.
Likely I'll switch to LED for most of my other lights, including fog lights, but for now I'm keeping the halogen for headlights.
I do a lot of high speed driving in rural areas.
I would have to be convinced that the LED pattern doesn't blind oncoming traffic, to me that's just as dangerous.
Also if the replacements are not DOT approved you could run into trouble with the law and/or insurance companies. Police here are starting to crack down on unapproved headlights.
If you were in an accident and the lawyer found out you had unapproved headlights it may turn out bad for you.
[quote name='Mark Henry' date='Aug 14 2018, 01:10 PM' post='2638742']
You would love them. I live rural. I can see the deer and everything else from much further out.
It doesn't. Not on my 914 or my dad's Jeep (higher up)
They just look like modern headlights, they don't look blue and they are only exposed at night.
I feel they help keep me out of accidents since I can see the road and others can see me. It's a huge difference. I'll never go back. When I bought my first set, I paid $180/per light and I still think it was worth every penny. They are supposed to last 50,000 hours so hopefully the last set I buy for each car.
The jeep lights are DOT approved, so you're likely OK.
I was commenting along the line of the bulb LED conversion and/or non-DOT approved lights.
"If you were in an accident and the lawyer found out you had unapproved headlights it may turn out bad for you."
I'm talking about the other guys lawyer, might be grounds for a lawsuit or invalidate your lawsuit. These days if I was a savvy lawyer I might look at this angle as a defense.
With the rctensive research we did we found several issues witg LEDs.
Chip life was one, the other is the lens housing issue
Also DOT approved is not US DOT approved. Its Chinease DOT, they let you make the assumption.
There are bery few US DOT approved and you will pay for it.
We fiund bery high quality chips that wete used in US DOT units, however the company they are having a difficult time getting us this next batch.
I went with Carmagic (Engelbert; rothaus on PelicanParts) LED headlight for my 930. Engelbert was very responsive to questions and everything fit nicely.
The headlight light pattern has that sharp cutoff at the top between light/no light as many vehicles have today.
The headlights also has an extra wire that can be connected to the running lights for DRL. On the 911 this is very convenient as the running light wires run through the headlight bucket and were a breeze to connect.
The high beams are primarily 4 high powered LEDs on each lamp which lights up everything in sight. The primary LEDs do not dim or turn off when the high beams turn on.
If you really want LED then you need to get the whole unit. There are good rated headlights on Amazon down to about $100/pr.
My problem with the LED bulbs (914rubber) is they glare like high beams are on. I know from the last rally it sucks to be the 914 in front. Adjusting the HL down shortens the throw so it's kinda mute.
I put in HID retrofit bulbs. At least the geometry matches the reflector and it shows on the road as the pattern didn't change. Also super bright and lower amps. You need a good quality E-code (European) sharp cut off housing. (Bosch/Hella/Cibie) The Chinese made ebay low buck special won't cut it.
I really need to take a night to do the comparison photo thread now that I have the LED bulbs to include.
