These lights are the second to highest in their product line. Chose them because they are preassembled into an H4 lens and do not use a fan.
This started as a 1 hour project that as usual turned into a 4 hour thing. After fighting nearly 50 year old screws the biggest issue became where to mount the circuit board box that is part of the assembly. First impression is it should be easy, but there is really not that much room in the headlight bucket as the assembly rotates up and down and the placement is not inconsequential.
Not inconsequential because one placement caught my plastic trim bucket and caused a stress crack. Bummer as these are original white ones on my '70 car.
At any rate, I ended up wrap tying onto the bracket that holds the spring. This position is a good fit. and remains out of the way as the assembly moves through its motion. Pix below.
Maybe this will save someone else some time (and a cracked plastic trim bucket).
Warning: Many wrap ties died in the completion of this project.
Oh yea, great product, low beams project a very diffuse pattern that lights a big area in front of the car. High beams are very effective. Makes night driving a whole new and safer experience. NICE!!
I just received a set of these lights. I will tackle this project soon and take some pictures as well. I suspect finding a suitable location to secure the power module will be the biggest issue. Stay tuned and a special thanks to @http://www.914world.com/bbs2/index.php?showuser=15674 for taking the time to post about this exact issue and take and post pictures.
Cheers,
Michael
Any issues with your hi/lo beam selector relay after the install?
Hi Jeff,
I actually plugged mine in just to test that exact issue and they seemed to work with no issues at all. On/off, hi/low, etc.
Michael
OK, so I tacked this today after reviewing @http://www.914world.com/bbs2/index.php?showuser=15674 pictures and posting. Very simple after that. Love that these lights look perfectly correct for the car.
Now I need to get a hold of Kent and see if he can re-adjust the eyebrows, etc. so the shut lines are prefect. Kent had to mess with the eyebrows and headlight doors when the other set of LED headlights were in the car as the stuck out about 3/8" beyond the bezel.
Oh, you can make fun of my driving lights. Mine are at Jerry's (Spokes) getting his new circular LEDs installed. I can't wait to get them back. I covered the buckets with tin foil 'cause I am weird like that.
Anyway here are some pictures:
Nice!
I've been looking for a good 5.75 option for the other hobby-car.
@http://www.914world.com/bbs2/index.php?showuser=2058 Thanks for the compliments. I may get up early and take it for a spin in the dark to see how the lights perform. I will let you know.
To get the GE Nighthawks to fit the eyebrows had to be adjusted as did the headlight doors. Now with the H4 Hella lights fitting as they should, I need to get Kent to adjust the eye brows, etc so the headlight assemblies match the shut lines of everything else. I do love the car and it is running great. The more I drive it the more I realize what an absolutely stunning job Kent, Jim, Andy and Bob did.
Looking good mike. Glad to hear that the location of the circuit box worked out for you also. Sorta confirms that it is a good place.
I did have to make the wire grounding mod to the light relay to restore normal function to my fog lights. No big deal, just find the thread and do it.
Glad to have contributed to your stunning car in a very small way.
You will love the performance of these lights and retention of the classic H4 look.
Drive safe
@http://www.914world.com/bbs2/index.php?showuser=2058 So I got a chance to drive with these at 0500 today. They throw some great light. I would say they are at least as bright as the GE Nighthawks and may even be brighter. I did note they were a bit high so I will adjust them down. I do not want to offend on-coming drivers.
@http://www.914world.com/bbs2/index.php?showuser=15674 Thanks so much for the help with this project. These lights look perfect in the car. I had them in my last 6, 30 years ago, but that was when you still had to run the 80/100 bulbs and a relay. Even then, they did not light like these.
The jury may be out for quite some time on that issue as I rarely drive the car at night. I am going to try to get down to LA soon, so that would be the first real test.
Thanks for sharing this info.
I'm curious ... if I already have H4 globes ... could I simply drop in these bulbs from the same company?
https://vintagecarleds.com/shop/bulbs-only/vcm3-bulbs-only/
@DC_nuen_vierzehn I am not sure but the H4 headlights look to be no different than any other H4 I have seen.
I suspect they drop in to “standard” H4’s. Do not think Vintagecarleds has special H4’s made just for them, but...
Just ask them, they are domestic and responsive
Not sure about the oncoming driver issue, I can only tell you that the low beam cutoff is very distinct and when projected on a wall is very low and very distinct.
