What is the best way to clean carbon from the valves and heads of a 911 engine?
Thanks,
Bob
B12 carb clean and a light wire brush, or abrasive (bead) blasting(what the shops use)...
QUOTE (tat2dphreak @ Jun 16 2005, 10:59 AM) |
B12 carb clean and a light wire brush, or abrasive (bead) blasting(what the shops use)... |
take it out and run it hard...w/ some emissions cleaner in there, works every time..oh off the car. Soak it in cider.
QUOTE (Bob Wolcott @ Jun 16 2005, 09:56 AM) |
What is the best way to clean carbon from the valves and heads of a 911 engine? Thanks, Bob |
I dunno bout air coolers... but we used to dump a gallon of hot soapy water down the hole on V8s with the pedal down pretty far...
POW! POW!~ exhaust sized chunks.
M
QUOTE (redshift @ Jun 16 2005, 11:29 AM) |
I dunno bout air coolers... but we used to dump a gallon of hot soapy water down the hole on V8s with the pedal down pretty far... POW! POW!~ exhaust sized chunks. M |
I use these pads made by 3M they have them in green and white. They are 2 in dia. and clean carbon and gaskets like crazy.
Before and after I have cleaned up 1 head in this shot
