Printable Version of Topic
914World.com _ 914World Garage _ head light switch
Posted by: imapayne Sep 20 2018, 11:04 AM
My 75 1.8 914 is finally coming together but headlight switch is killing me. on the back pins are marked but not sure which wire goes where. I have the nice plastic wire sche and Haynes manuel but its not much help. Thanks Imapayeb
Posted by: ClayPerrine Sep 20 2018, 01:13 PM
Nice engine, but somehow I don't think it came from a 914.
Posted by: porschetub Sep 20 2018, 01:32 PM
QUOTE(ClayPerrine @ Sep 21 2018, 07:13 AM)
they seem to end up in them however.
Go to Jeff Bowlsby's website heeps of info on there,thanks to Jeff his wiring diagrams have been a huge help to me.
There are 2 types of switches early and late,from memory one has 10pins and the other 11,good luck.
Posted by: JeffBowlsby Sep 20 2018, 02:14 PM
You will need to use the FWSM schematics to get the wiring straight. Each model year is different.
Posted by: imapayne Sep 20 2018, 02:42 PM
Im sorry but what is the FWSM sche. how do i change that pic lol
Posted by: imapayne Sep 20 2018, 03:24 PM
thats better[attachmentid=667947]
Posted by: ClayPerrine Sep 20 2018, 08:43 PM
QUOTE(imapayne @ Sep 20 2018, 04:24 PM)
OOOOOOHHHHHH..... Pretty!!!!!!!!
Posted by: jcd914 Sep 20 2018, 09:31 PM
QUOTE(imapayne @ Sep 20 2018, 01:42 PM)
FWSM - Factory Workshop Service Manual
There used to be the factory diagrams on the Pelican Part website but then the links were broken, not sure if they got fixed. What year is your car?
You can always go back to your original post and edit it, look at the bottom right corner of the post for the "Edit" button.
Jim
Posted by: ClayPerrine Sep 20 2018, 09:33 PM
QUOTE(jcd914 @ Sep 20 2018, 10:31 PM)
Jim
You can still find them in the internet archive... aka the wayback machine.
Posted by: imapayne Sep 22 2018, 05:21 PM
Ive never heard of the way back machine but would love to use. Can someone point me to a work around so i can use it Thanks
Posted by: ClayPerrine Sep 22 2018, 06:12 PM
QUOTE(imapayne @ Sep 22 2018, 06:21 PM)
https://archive.org/web/
Find the dead link on Pelican's site, then open it from a couple of years ago on the Wayback machine.
Posted by: imapayne Sep 28 2018, 02:42 PM
can anyone tell me what pins on the switch are power? and other pins i have the running lights figured out.
DashSwitches.pdf ( 127.27k )
its the first light switch
Posted by: JeffBowlsby Sep 28 2018, 04:54 PM
Here you go. This is only correct for the 1975 cars.
Posted by: porschetub Sep 29 2018, 05:44 PM
Jeff to the rescue,well done ,I bypassed the dimmer control as I have had two fail,it not like you would use it as on maximum it's not great ,if you go to LED lamps you can't use it anyway,LED lamps are a good cheap upgrade and worth doing,cheers.
Posted by: imapayne Oct 1 2018, 03:18 PM
Thanks That did it.
Posted by: imapayne Oct 3 2018, 09:22 PM
Its alive pulled injectors flushed reinstalled pulled dist adjusted points reinstalled fixed vacuum leaks with a cornwell leak detector which smoke leaks. Used on leaking gas on new cars. And it purrs like a kitten. Ill show photos after upholstery install.
