Figured I would share a few pics of my 5 lug swap on my 75. I used 3.5 spaced 911 struts and Boxster calipers all around using the Rebel Racing kit. Wheels are 16x6 and 16X7 fuchs with 195/55/16s on all 4. I originally had 911 wheels all the way around but the rears had a slight interference with the calipers. Rather than use spacers I switched to 951 rears and the fit is great.
Currently still has the stock master cylinder. pedal definitely has some drop but get firm. I have a 19mm I'm going to swap, but wanna give it a try first.
Looks great. Do you have pictures of the struts with spacers?
Do you have pics of the 911 struts with the wheels off?
I had to stretch the quarters about 3/4" to fit the 7s. not the most conventional method, but it worked. I hammered the lips up and then used soft books on the wheels and jacked the wheel up into the wheelwell. Took several tries adding books and moving them front to back, but I got what I needed without scarring up the quarters.
Nice job, I want to make this conversion myself next winter. Just need to start collecting the parts. Was it a fairly simple swap over with the correct parts?
https://www.harborfreight.com/front-wheel-bearing-adapters-63728.html
Makes the bearings easy
Justin - nice job, the car looks great!
Just FYI: there is a subtle thing with Boxster calipers on 911 or 914-6 struts. Because the 911 strut places the caliper ahead of the wheel (and the Boxster has it behind), you end up fitting the FR caliper to the FL strut and vice versa. This works fine, but it does mean the offset piston sizes in the caliper are now reversed, with respect to rotor direction.
Why the offset piston sizes? Complicated, but the Fred Puhn braking book talks to the issue. There may be better explanations out there.
You can easily fix this by inverting the link pipe and bleeders between the two calipers, then swapping the sides. Which you really don't want to do right now, as you've just bolted them to the car and bled the brakes...!
The big question is: does this really make a difference? I have no real evidence to prove it one way or the other. I can imagine it makes a difference to pad wear long term - but do we care?
Either way, I have the same front strut / caliper set up and my car, and very happy with the results. Again, car looks much better!!
- Tony
Did you have to use spacers so the wheels didn't rub on the caliper? I have the same conversion and the 7" Euromeister wheel rubbed the caliper on the inside.
Tony, I do remember reading that. At one point I intended to swap them over and just never did it. Thanks.
Wow what a difference before and after, nice work!
Now go and buy a Boxster spare tire. The stock 15 inch steel spare won't fit over the Boxster calipers.
Been there, done that.
