Are these those rollers in the guide? Found one in the bottom of the door split in two. Appears there is a roller already in there, or is there more than one in each door?
There are 4 per car 2 on each window. Part of the scissor assembly not sold alone. That's why we made them
https://900designs-container.zoeysite.com/window-regulator-delrin-roller-kit-repair-kit-0afor-1973-1976-914-late-style-scissors-type-window-regulator-0ahow-many-do-you-get-and-need-enought-for-1-or-two-regulator
I didn't readily see where the other one is located at then?
How do you replace them ? I bought a pair for my '75 and Drew a blank when I opened the door....
Actually not too bad. The nylon old ones tend to come off in pieces, but if they don't they can be popped off with a pliers. You can use a pliers to press the new ones on. They will not break, but it takes less pressure if you drop them in hot water for about a minute.
