I'm going to need a new front bumper top from 914Rubber, but I'm hoping to save the rear one. It's in really nice shape but it looks dirty, dull/faded (see pic below). What's the best way to bring it back to looking its best?
I have had luck with 150, 400, 600 sand paper then “back to black”.
Wash with dish detergent then Vaseline and leave it in the sun for a bit. Buff with soft cloth.
Those are two interesting, and quite unique, approaches. I’ve previously used back to black and it has worked well initially but not held up very well. But that was on a harder material. Would the Vaseline method last longer?
Rub glycerin into it. It requires reapplication from time to time, but its not petroleum based so it will not deteriorate the rubber.
Hot water and soap. Wipe with acetone. Shoot with penetrating vinyl dye.
You should keep most of the texture. Really a matter of cleaning opening up any pours, and the vinyl dye will make it a satin color.
This is if the rubber is not too far gone. If it’s wavy the internal structure is failing. You can still use it, but it’s a matter of time.
Thanks,
Mark
Great tips guys. Not sure it is needed in this instance, but I did a pretty effective repair using black 3M 5200 adhesive. This stuff would definitely work to secure new anchors too. http://www.914world.com/bbs2/index.php?showtopic=240803&hl=
With some diligence it might be possible to reskin a bumper top with a “ skim” coat of this stuff. Maybe??
Thanks to all for the ideas. I’ll weigh my options. I don’t see the VHT vinyl dye locally but I do see Duplicolor vinyl and fabric paint. Does anyone know if that’s the same as vinyl dye (i.e., is vinyl dye a paint)?
After the sanding, one of the best detailers on the east coast who is a friend says this is the best stuff there is:
https://www.amazon.com/Solution-Finish-Black-Plastic-Restorer/dp/B006NZRAFE/ref=sr_1_1_sspa?hvadid=78271537753711&hvbmt=be&hvdev=c&hvqmt=e&keywords=solution+finish&qid=1566564612&s=gateway&sr=8-1-spons&psc=1& amp;spLa=ZW5jcnlwdGVkUXVhbGlmaWVyPUE1OEE0WEZXMlFHQTcmZW5jcnlwdGVkSWQ9QTAwNjgzNjc
zRUYyR0wxWjJDRkNYJmVuY3J5cHRlZEFkSWQ9QTA2MDU1NjdQSkdMVVNHMjZGNFMmd2lkZ2V0TmFtZT1
zcF9hdGYmYWN0aW9uPWNsaWNrUmVkaXJlY3QmZG9Ob3RMb2dDbGljaz10cnVl
GN
She cleans up nicely. Touch up your valence covers and tires and it will "pop"!
Not sure about skimming but I did that “chunk” repair five years ago and it still looks like the day I did it.
