Steve/shoguneagle sent his engine x-country and it ended up in my garage. It’s in running condition so no big changes right now. Just clean it up a bit and install Ben’s heat exchangers. Later on, I plan to rebuild it into a 3.4 with hot cams, high compression pistons, a modern MAF system, custom chip and some other goodies but for now, I’m going to leave a running engine, running.
I have a set of fuel lines since they often need replacement after 35 years and I’ll fix the crack in the fan shroud. Heat will get backdated - no engine mounted blower fan.
