Printable Version of Topic
914World.com _ 914World Garage _ Head Bolt Removal and Installation Tips Needed
Posted by: cassmcentee Sep 6 2019, 11:37 AM
Starting the disassembly of my 72 2.0
Some head bolts stayed with the Case
Others came out with the head
How do you guys/gals deal with removal so as not to SCAR the bolts?
Posted by: IronHillRestorations Sep 6 2019, 12:25 PM
If you are pulling all the head studs, first put some Seafoam Deep Creep penetrating oil on them, and if you have time let them sit for a day, and tapping with a brass or plastic hammer will help the oil work. Most of the time you can put two nuts on the top threads, tighten them against each other and use that to back them out. If they are rusty (like yours) this can cause them to break, so I'd carefully add some heat with a MAP or propane torch.
Posted by: cassmcentee Sep 6 2019, 12:50 PM
QUOTE(IronHillRestorations @ Sep 6 2019, 01:25 PM)
Cool, Thank you Perry, I have plenty of time!
What about the ones trapped on the head?
Add two nuts to the bottom threads to counter the top nut???
Posted by: ClayPerrine Sep 6 2019, 01:03 PM
Soak the threads with penetrating oil (I use PB Blaster), double nut the bottom of the studs, and unscrew the nuts.
Personally, those studs are awful rusty. I wouldn't reuse them. If you choose to get new studs, just lock them with vice grips.
Good luck.
Clay
Posted by: cassmcentee Sep 6 2019, 02:23 PM
QUOTE(ClayPerrine @ Sep 6 2019, 02:03 PM)
I agree with you, I'll get new ones.
Thanks Again!
Posted by: Superhawk996 Sep 6 2019, 02:57 PM
Now I know the double nut trick works well most of the time and is basically free, but, I really love these Snap-on collet stud extractors.
Double nuts sometimes slip and/or don't seem to get enough grip on the threads sometimes. I've resorted to triple nutting a time or two.
Overkill for sure, but, I love having the right tool for the job.
Posted by: sixnotfour Sep 6 2019, 03:36 PM
wow thats really compact,,I have the older style long collett one,,,
add to cart...
Posted by: preach Sep 7 2019, 01:03 PM
QUOTE(Superhawk996 @ Sep 6 2019, 04:57 PM)
Those are nice.
A trick tool I learned about at work is vice grips with a nut welded to the jaws then cut in half. Plenty of clamping power without damaging the threads.
Posted by: IronHillRestorations Sep 7 2019, 07:07 PM
QUOTE(Superhawk996 @ Sep 6 2019, 12:57 PM)
Nice! Tool envy. That is in fact the best tool for the job.
Posted by: ClayPerrine Sep 7 2019, 07:14 PM
If you are not going to reuse the stud, then weld a nut to the stud. I do that for pulling studs out of /4 heads.
