Hello folks. I’m a new member here. I am having a shop perform a PPI on a 1975 2.0 that I am looking to purchase. They can’t find the engine serial number. Isn’t it located on top of the engine, in front of the oil filler neck? Thanks.
Thanks for the Pic! On this car, that metal area is smooth - no numbers stamped. From what I have read, it may be a replacement block that doesn’t have a number.
if not a replacement case a transplant from 912e ?
is it F.I. or carb? can u share pic of ur engine?
The first 2 pics are from the dealer selling the 914. The 3rd pic is from the mechanic performing the PPI. That area where the number should be is smooth.
If a 912E engine, the serial is located on the fan shroud. If a normal fan shroud is placed on a 912E case, then there would be no engine serial to be found.
Mystery solved. I was able to track down the original owner, and he said he threw a rod in 1979, and had to get a replacement block. Thanks for everyone’s responses.
