My driver's side headlight is not coming on. I checked voltage, and nothing is coming thru, low or high beam. The passenger side works great. Fog lights also work, turning off automatically when high beams are on.
I checked the headlight relay, and it is hooked up correctly. So my question is, does anyone know which terminals on the relay I should check for voltage in order to isolate the problem? Since the passenger headlight works, I'm thinking is a wiring problem leading to the driver's headlight.
Spinning the fuse was all it took. Brilliant response!! Thank you. That's what makes this such an awesome forum.
But new fuses. They are cheap.
And carry spares!
Clean all the terminals on the fuse block
