Posted by: PCH Dec 23 2019, 02:27 PM
When placing a new throttle body to plenum gasket, do you put some sort of sealer (like Formagasket) on the gasket?
The previous gasket had a sealer on it.
Thank you for your help.
Peter
Posted by: rjames Dec 23 2019, 04:29 PM
QUOTE(PCH @ Dec 23 2019, 12:27 PM)
When placing a new throttle body to plenum gasket, due you put some sort of sealer (like Formagasket) on the gasket?
Peter
You shouldn’t need it if the surfaces of the TB and plenum are super clean. Torque down the bolts each a little at a time.
Posted by: DRPHIL914 Dec 23 2019, 09:37 PM
Common spot for vac leak, there is a gasket that should be placed between there at least I have always had one on my 2.0 D-jet
Posted by: cuddy_k Dec 23 2019, 10:34 PM
A thin smear (thin!) of The Right Stuff can’t hurt.
Posted by: rjames Dec 23 2019, 11:16 PM
QUOTE(DRPHIL914 @ Dec 23 2019, 07:37 PM)
Gasket yes. Goop isn’t needed if surfaces are properly prepped.
Posted by: DRPHIL914 Dec 24 2019, 08:26 AM
QUOTE(rjames @ Dec 24 2019, 12:16 AM)
Sorry, it was late and I was not reading clearly the OP, lol but I agree o goop needed just gasket-
Posted by: PCH Dec 24 2019, 01:43 PM
Thanks everyone for your help!
