See the "Real LE" thread below for the history.
Car was in a flash flood in Pennsylvania late last summer. It was in a shop nearing completion of a six conversion. Owner had blown up two big fours before deciding to try a six. Engine was from Motormeister. Car was under water up to the dash for about 30 minutes. Nationwide settled with the car owner and it went to auction. Bought by fellow in Ventura, CA last Oct. and he stored it until last month when he decided time did not allow for a project. It went to Ebay and I bought it with an offer before the auction ended.
JP Stein joined me for the beginning of the autopsy. We opened the sump drain plug and here is what we found. Not much oil, 2+ quarts of water.
After removing the screen JP fished out this pile of shrapnel.
Don't think water did this!
Engine out, using JP's very slick jack and boxes. My four post allowed lifting the car instead of dropping the engine.
Ouch....floods AND Motor Meister....ya need a shaman, five virgins, a gross of chickens and a bottle of tekilya to negate THAT mad MOJO.....woof...
You ain't seen nothin' yet Z
Pennsylvania silt.
And more silt
Plugs
Clutch disc dissolved. Hope the rusty p. plate and flywheel can be saved.
Found an unusual starter.
Here is proof that MM seated at least one intake valve properly.
Held a port full for a year!
Think there might be water in the fuel?
I have now completely disassembled the engine and split the case. Haven't taken any pics of the results but will do so soon. Stay tuned to see a Motormeister engine that has never been driven. (I am not yet sure if the shop ran it on the bench before install. I intend to find out).
Seen worse, looks like it was gotten to early and quite saveable....don't toss out the virgins and the Tekillya too soon though....
Goat boy should be chiming in soon....
Porschequarium
M
porschubmarine
Das Boot
Hummm.....What's the shittage in that intake port? Also,
that is not a stock 2.7L intake port..appears to be a small port carb head.
MM did sumthin' there....it appears to be a half assed porting job.
Still waiting for a video of you sliding around, JP.
M
Ok, here's the the rocker side of one bank. Cam not rusty, just a little light rust on the rockers.
Here's the hot side. Must have been run by someone on the bench but pretty fresh looking.
Now for the gore.......... #4 guess we know where the shrapnel came from. Pretty strong flood currents in Pennsylvania!
Alusil cylinders by the way. Here is #1. Lots nicer than 4.
#5 got hit by hard water too.
Case looks good to my eye.
JP, can small bore heads be installed on 90mm cylinders?
Hummm....the rings appear to be intact.....cept maybe the oil ring. That could be a chicken/egg deal. My WAG, galling....
non ferocoated piston on a Alusil cylinder.....Musta made *some* noise
How did the rod look?
Bring them suckers to the AX tomorrow for "show & tell".
We can set it on the registration desk.
Gotta get JP over here with his measuring sticks to see what we have for a crank.
Shop owner told me the car had never been on the road as a six. Pretty obvious that is true since it has a new Velios tank which has never been plumbed. He said the motor was "fresh" from Motormeister. I intend to call him to make sure and to ask if he ran it before it was installed. Meantime, I don't think I'll be asking MM to build the replacement. I might suggest he order his next one from somewhere else.
I'll post some pics of the interior in a few days. You would never know it was submerged, unless you noticed the high water lines inside the gauge lenses!!!
QUOTE (Porsche Rescue @ Jul 2 2005, 07:31 PM) |
Now for the gore.......... #4 guess we know where the shrapnel came from. Pretty strong flood currents in Pennsylvania! |
QUOTE (Porsche Rescue @ Jul 2 2005, 07:36 PM) |
Case looks good to my eye. JP, can small bore heads be installed on 90mm cylinders? |
For the record, my husband will lose sleep over this...he is currently in the pooper and wishes to remain undisturbed! He is moaning and groaning over flood damage!
Luck
Thanks for the visual.....
QUOTE (Porsche Rescue @ Jul 2 2005, 07:43 PM) |
Gotta get JP over here with his measuring sticks to see what we have for a crank. Shop owner told me the car had never been on the road as a six. Pretty obvious that is true since it has a new Velios tank which has never been plumbed. He said the motor was "fresh" from Motormeister. I intend to call him to make sure and to ask if he ran it before it was installed. Meantime, I don't think I'll be asking MM to build the replacement. I might suggest he order his next one from somewhere else. I'll post some pics of the interior in a few days. You would never know it was submerged, unless you noticed the high water lines inside the gauge lenses!!! |
No thought of trying to get satisfaction from MM. I bought the car assuming engine was a boat anchor (but hoping to get lucky). I just want to get the facts straight, and if appropriate, advise the shop in PA to do business elsewhere next time.
I have arranged to have a 2.7 built to install in the car this summer. If case (7R)and crank are good I will sell them. Head assemblies might be usable, depending on whether or not I can determine what they are!
i bought flood car years ago jim. tap on the longs. do they sound "not hollow"? i cut one open and the silt was 3/4 of the way to the top.
k
Wonder if anyone collected insurance money on that "flood" damage? If they did bet that car was being towed all over town in search of a low spot in the road
Looks like you'll be busy spending money on that six. Time to sell me 2233
I made a submarine a few years ago. S15 on a boat ramp. E brake failed. Boat floated up and jamed against the dock. Saved the truck from going straight down.
The rust issues didn't apear until a few years later and strangely enough the rust started right at the dipping line.
Hope the hidden spots didn't fill with water. It looks like a nice car.
Hi all:
I usually am on the Pelican board and saw is post covering Motormeister.
A few years ago I had major issues with them one being the fact that they replaced the 7R case on my 73.5T with a 5R for no apparent reason and without telling me that they did or why (you can read the whole story on the PP board by search Phoenix and Motormeister). My belief is that they took my 7R cas to build a higher performance engine.
Just out of morbid curiousity, does the case you have bear the serial number 6135540?
It's a long shot, but if I manage to find the case, I'll have something solid on them.
My advice with MM is do your homework, read up on case histories thne make your own decision.
... Oliver
The case is at JP Stein's right now. I'll email him and ask that he look at this thread.
6141129, sorry. I hope you turned them into the cops for theft.
The 73 7R case is the most sought after of all the mag cases and thus worth more..
good story....and nice find...
definitely has a story..
QUOTE (grantsfo @ Jul 3 2005, 08:05 AM) |
Wonder if anyone collected insurance money on that "flood" damage? If they did bet that car was being towed all over town in search of a low spot in the road |
Devious minds.....just like mine
*Somebody* started it.....but not in the car...it scattered and it didn't die quietly.
There was no oil in it....but a gallon of water....plus silt.
Jim mentioned that it was the second motor from MM, right?
Supposedly, the car was the owners baby & he had it fixed price insured for 25 K. Since he already had blowed up a couple t-4s, maybe he decided it was jinxed.
My initial detective work says it was a legit. accident. Shop owner told me they first got an engine from MM with poor oil pressure and sent it back. That suggests they bench ran the first one. Would seem to me they would have heard this one self-destruct and sent it back too. However, it was installed but not wired or plumbed.
I found the shop by calling a PCA officer from the Pittsburgh area trying to find the former owner. He told me about the flood and gave me name and number of the shop. He said several cars were lost. Only a couple that were on lifts were saved. Shop owner told me the car was under for about 30 minutes. High water line was mid-glovebox. Water did not reach the gauge console. I left a phone message with former owner but he did not return my call. I will probably try again. Shop owner said losing the car was like losing a child for the guy, so he might not want to talk about it. I was told he had $50K in the car (multiple engines, major repaint, lots of mods (cage, fuel cell, chassis stiffening, bushings, Bilsteins, pair of Koenigs, custom carpet, 7" Revolution wheels, fiberglass rear bumper, front dam, etc.). Apparently it was all done by pros. Owner was not a DIY type. Two different people said the car was "agreed value" insured and he received $25K. Car now has a salvage title.
I have stripped interior and removed floor tar. All is well there. Removed fuel cell and surround and cleaned silt from trunk floor. Drained tranny and found mostly gear oil with maybe 8 ounces of water. Plan to refill and use it until I hear problems. I have a rebuilt 2.7 with Webers on the way. Optimistic goal is to make the start at our local AX on 9/11 (ominous date!).
QUOTE (Porsche Rescue @ Aug 3 2005, 06:22 PM) |
I have stripped interior and removed floor tar. All is well there. |
I've checked all of that as best I can. I guess if it rusts it won't be any different than most 914's.
Jeff Hines (sixnotfour) offered to build a new heart for the submarine. It is a stock 2.7, '77 case with Webers. He delivered a beautiful long block and I am in the process of assembling and installing. Goal is to autocross on 9/11.
Only problem, I don't want to get it dirty!
Ain't it pretty!
beautiful Jim...and Jeff
Looking very sweet there Jim, hey if you need a hand shout.
Would be great to have her at the AX.. Oeerr.
Jim,
you have any interest in selling the wet webbers?
(still looking for some type of carbs for a project)
brant
The wet carbs are Zeniths. Sorry
wanna sell the zenniths?
I don't have any carbs for my project.
brant
After a little time off (wife thinks we should do things other than work on the car!) I got all the stuff attached and put her in today.
With JP's jack and my lift it was a cake walk. Here is the whole enchilada...........
Ready to drop the car on it.........
Going down............
Where'd it go.........
There it is..........
Hope to light the fire Sunday or Monday if I can get JP over here to hold my hand. Next autocross is week from Sunday.
It's gonna live and breathe again.....
Jim that is so pretty I'm beyond jealous . We need to have an oregon get together to oggle cars.
Eric
Your LE is really going to Can-Am! WHOOHOOO!
Cam-An.. Can-Ma.. WHATEVER! RAWK!
M
boner!! Ohh, that was wonderfull.
k
and it runs, too...
Here's proof.........note the car is now pointed in the opposite direction.
JP came over today. First problem: solenoid refused to engage the starter. Certified starter repair technician Stein took it apart and put it together again. We have spin!
It fired almost immediately. After 15-20 minutes and much carb tweaking we were off for a brief drive. Handles well and has lots of power, though 5000 rpm was max.
Brakes aren't right (right rear wheel was too hot to touch when we got home) and some electrical problems to solve along with a small oil leak. Leak may be oil temp sender (I hope!). Still possible to make the starting line next Sunday but not sure yet. Since JP is unemployed he may get to come back again.
forgot the proof
Workin' for you, I'm under employed ....fun stuff, tho.
