I’ve always been fascinated by the front lower spotlight mounting that appears on some of the GT cars, notably the winning 1970 Marathon de la Route cars. A few years ago I got a chance to obtain some original Cibie Iode 45 lamps from a seller in France. These had yellow lenses – one fog, one driving - which matched the yellow Cibie Tango’s I have mounted in my GT tribute car already, in the “standard” fog light position within the fiberglass front bumper.
Not clear to me was how the factory fabricated brackets were designed. The inverted “T” cut into the fiberglass bumper meant that the brackets must somehow get fed through that to get mounted; also somehow they mount to the body and may / may not hold the bumper on? Searching in-period as well as recent pictures did not yield many clues; a few detailed the outside construction and bracing, but I had no clear idea of what was behind the bumper cut out. Until: luckily last summer I did get a chance to see the original “Number 2” Marathon car up close at Luft 6, so took the opportunity to crawl around under the front of the car to try and see what was going on.
That is, until folks who were waiting to take unobstructed pictures of the legendary vehicle were bored of waiting for the strange geezer lying on his back peering into the oil cooler opening….!
I took some detailed pics and thought that attempting to make up some brackets might be a good winter project. It is not clear to me (on olde number 2) whether the brackets were the originals or replicas – but I learned enough to want to try and replicate them.
So the brackets themselves (as the pics show) look pretty basic on the face of it. But some thought obviously went into the design, as they need to meet multiple criteria:
- be shaped such that they can be fed through the inverted “T” cut in the bumper
- secure the bumper to the body
- have welded in bracing to prevent the lights vibrating & flexing
- clear the front valance mounting tabs (which are just below the bumper mount holes)
The upper piece in this shot shows the side profile I went for, bent up in aluminum as a test for clearance; one of the main bracket is being fab'ed using mild steel.
The cut in the bumper (fiberglass) was done with fingers crossed but turned out to be correct, the shot below shows a test fit & alignment check before cutting the vertical:
I welded some M6 nuts to the strips to use as mounts, aligned with the holes in the bumper and the body. Cutting the bracing pieces needed some experimentation and mocking up, as looking carefully at the existing photos of the OUTSIDE, it was hard to judge overall dimensions – extension, drop, etc. – so in the end it was basically a visual judgement call.
and....
So on to welding and shaping (lower shot shows braces tacked in):
My welding is quite poor, but I am a dab hand with a grinder ;-) so I went for adding metal and grinding back for a smooth finish on the brace pieces – rather than the “stack of dimes” welds on the originals which I assume were done using aluminum stock - and stitched together by a competent welder. One element that took some degree of hand fettling was the profile of the bracket so that it could be fed into the front of the bumper, so the central brace required some metal removed, as well as the upper part too – not obvious, but part of the three dimensional insertion problem!
I may get them powder coated at some later point, but for now I rattle-canned them for a “cast metal” style finish, bolted on the Iode 45’s and reassembled the front of the car. When I originally did the GT conversion wiring, I added switching, relays and loom for both fogs and spots, knowing I would get to this at some point; but I still need to hook the wiring up and test to complete the job.
You do see some GT’s with Cibie hood lights (which the factory rally cars ran), but few with the Endurance race look, low mounting. The Iode 45’s will be wired so they are optional to low beams, with the Tango’s sync’ed to high beam if needed.
If anyone wants more detail on the brackets – again, I struggled to find details on the web, even combing through Armando’s awesome Pbase site – then am happy to share more info, dimensions, etc. Better would be someone with access to OG factory units and getting them 3D scanned so we have a reference point!
- Tony
Nicely done, looks the part...Ctrl-C, Ctrl-V, for me.
I have the same idea in mind for my project, still need the bumper mind you but I have the lighting set-up awaiting.
I'll gladly take some specs for a starting point.
Thanks,
Marlon
For interest sake, I saved this pic a long time ago and maybe its the appropriate bracket? Only difference would be the interior mount position since it would push the light slight outward from the alignment you did.
Again, yours does the trick too.
Nice job on the bracket.
Second bracket was done by Rennmetal. Wish I had gotten my set for supplying the parts for prototype and mockup. Oh well, win some loose some.
Wish they would make those for the masses.
Retroracer,
Nice work on your brackets. When I read your thread I thought of the historic 914/6 GT I took photos of at this years Rolex 24. The auxiliary lights were mounted differently and appear to be mounted to the exterior of the bumpers. If I had seen your thread before the race I would have checked the mounting more closely.
Nice brackets, those lights look great on the car.
Nice! Wonderful custom fab work.
@http://www.914world.com/bbs2/index.php?showuser=19241 and @http://www.914world.com/bbs2/index.php?showuser=87 @http://www.914world.com/bbs2/index.php?showuser=2388 - thanks guys!
@Sway_Bar and @http://www.914world.com/bbs2/index.php?showuser=12876 - At one point I will post dimensions, as there seems to be interest in this version of the bracket. I don't have these in a coherent form , but I think I can figure out all the main dimensions. Stay tuned.
@http://www.914world.com/bbs2/index.php?showuser=632 : So this is one of those areas where some detail differences among the "GT" cars become obvious. I believe the green car you have in your pix is one of the "privateer" GT builds, which along with the yellow Daytona winning car, took a completely different approach to mounting auxiliary lights. The light unit themselves are different too (instead of Cibie Iode 45's, these look like a combo of Oscars and Super Oscars). Whether these were designed and added at the factory, or later in the US (prior to race events) I don't know, but the positions and bracket hardware are very different from (say) the Marathon cars.
BTW, the Sonauto Le Mans class winning car also has signs of having the "center rib" brackets being fitted at one point:
you can clearly see the "inverted T" cut out in the bumper.
If anyone is thinking about a bracket that works with steel bumpers, you may want to look at something similar to the Rennmetal piece. My interpretation is probably more suited to the fiberglass bumpers, where the bracket actually secures the bumper to the car; the Rennmetal version looks as though to fits between the car and the dog bone and gets clamped in place?
- Tony
(photo credit to Mr. Serrano)
So the green car in reply #11 has a mixture of Oscars and Super Oscars ?,I have a set with will go on my car but how do you tell between the 2,is the "super" the larger of the two? mine have 150mm lenses if that means anything.
Just wondering how solid these brackets are ? personally don't like light beams that bounce around.
How did these cars handle the power demand for these lights considering the original were very low output,I have a relay setup with my Cibie's that uses heavier wire thinking I could use that.
Here is the placard placed with the green GT.
@http://www.914world.com/bbs2/index.php?showuser=632 Thanks for posting that; it seems to be this car from the chassis number:
https://pbase.com/9146gt/dealer_9146gt_race_cars_sn9140430691_maxmoritz_19
Exploring around some of the historical shots from that page, there are early shots of the GT showing no extra driving lights brackets at all - just to add to the mystery,
- Tony
I'm inferring the Rennenmetal brackets are NLA - I have a new uninstalled set in storage which I don't want to sell but would loan out for someone to measure/scan for duplication... PM if anyone wants to pursue that.
Finally had some time to start copying out the brackets, sketch has measurements in mm (sorry for the crappy penmanship) and I've cad'ed out of version of them with and with out a little brace piece. Rennenmetal had added a little weld in gusset, I was going to try sheet bending in a tab and welding it after the next bend.
I still haven't set up my new plasma table so haven't had a chance to cut them and compare to the originals but that shouldn't be too far out.
Has anyone produced these brackets yet? I am interested in 2 sets. Please email me if I can purchase them Bill3@CarlisleEvents.com
Thanks
Bill III
Thanks Eric. Please email me as soon as you are ready. i am just finishing 2 (wife and husband) 914 race cars and would love to add some driving lights before i offer them for sale. Thanks again.
Such a weird coincidence, I was just wondering about how this was coming along, and then the thread gets revived
PM'd about production idea, I can get these cut for you with out the slag associated with plasma, tighter tolerances, and many more material options at your disposal.
Wish I saw this earlier, I would have taken Chris up on the offer to duplicate these. I helped with the prototype work on the original brackets, and was offered a set for the help, never got them.
But will gladly pay for a set as I want to have them around.
Water jet?
If these brackets get produced, put me down for a set !
I’m in for a set too!
Eric, has shared with me his work on this. I will run it trough my cad and do a laser cut in Cardboard Aided design. Then clean up the design a bit to make it easier for production.
None of these issues are from anything Eric has done, it is from the original design.
Eric I agree with you Plasma can make some great cuts. and has it's place. I tend to use laser based on the wider range of materials and higher tolerances that I tend to work with.
@http://www.914world.com/bbs2/index.php?showuser=2388 I just sent you a bunch of pictures to help the process along
Hi
Also in for a set, if possible.
Thanks
Paul
I have a nice set of those Cibie Iode lights with correct covers I might part with.....
I would like to buy a set
Don't forget I was first! lol Just kidding but I am still interested. Bill3@CarlisleEvents.com
Thanks
Put me in for one set please.
Project still on track, I have made a few design changes. should have the parts back end of next week, and will snap some pictures, and update on production costs.
I’d like a set also if not too late, Thanks!
Please put me on the list of folks who are interested in a set (or 2).
Thanks ! Thom
Will do I hope to have the prototypes for this weekends assembly, LOL, after the first one piece design, I have thought of other ways of building these. Bit more CAD time, and I might have something I am proud of.
Not to late the design will allow these to be produced in two ways. One completely done in any color you want as long as its a non color that would be black.
Or a DIY kit that all once done all you have to do is say I want one, and it will be manufactured and sent off as a bare metal piece. You get the fun of bending, clearly marked via engraving and relief cuts. And then welding, after that you can coat it in any color you want and any method you choose.
Must say, Sorry Tony for the thread hyjack
Alpha test unit, this was mocked up, I need to grab a set of Cibi Oscars. That Hella looks out of place with the other lights.
Have a few changes to make. And an idea to make it easier to hold onto the bumper mount to make installation a bit less of a hassle. Right now you need at least 3 hands, in my case, two hands and a leg.
But here it is, the cost will be based of final material choice, an TIG weld time. Lots of little dimes to be added
And I found out an interesting item on my -6 the bumper was being held on by friction and gravity. No nuts on the inside of the bracket. That is the reason for the large clamp in the picture.
I added a few holes to allow for better wire management. The hole that the two wires drop into will be upsized for a grommet and the grommets will be included in the kit. There is a set of rear holes that can be used for a zip tie to hold the wires close to the brake to get them behind the bumper.
Also note the Alpha Prototype was made out of mild steel, no welding was done yet. Metal is strong enough to hold the weight with just the physical bends. I will weld it and do a stress test at a latter date to failure.
As I said I have a couple of changes I need to make to the design, and it will be ready for production.
Want to test fitment with a Set of Cibie Oscars, and Cibie LED Oscars. As I think the back space will be different for each.
These can be made out of various metals, I laser cut these.
Mild Steel $$
Stainless Steel $$.$
Titanium $$$ roughly 4x the price, but would be
I'm in for a set too! Looks great. Let us know when you are able to do a small production run.
I went a little the other way...from the top down. Just seems hanging from the top is better than the bottom. Mark
Just been directed to this thread.
I’m interested in a set if European shipping doesn’t kill it
Just one thought - if they are top mounted will the covers fit upside down?
C
If your running fiberglass bumpers I would not feel bad about putting in the tabs and making them like several GT pictures.
Lots of way to skin this cat.
The reason they are done this way is they slip between the button of the bumper, and the lower valance.
Version number 4 has been sent to my cutter, we will see how this version turns out.
Thread revival. Are these available in ready to mount format? Need two sets.
I like the clean look on mine,
but I am also into the large round lamps on some GT’s.
Is that a special bumper?
Neat bumper. Definitely custom.
I hope to do a night race this year so will need the extra lights for sure. I plan to mount two white and two yellow. Already have the cibies ready to go. Just need these mounts. @http://www.914world.com/bbs2/index.php?showuser=2388
