Printable Version of Topic
914World.com _ 914World Garage _ Picking away @ small jobs...leaking speedo drive?
Posted by: porschetub May 4 2020, 05:21 PM
As per question,don't want to change oil because it pisses out the hole due to wrong tilt...thinking full extension on my bigger jackstands ??.
TIA.
Posted by: RickS May 4 2020, 08:23 PM
Get it up as high as possible. If you have some 2x6 pieces to put under your jackstands, use them too. Keep a couple of rags handy. One to plug the hole as fast as you can before much can drain out and one to clean the floor. You have to move fast.
Posted by: Mikey914 May 5 2020, 12:02 AM
2.7 qts is the quantity for complete refill, I've heard it can be done without loosing much, but have yet to see it. Love to see you show us how it's done.
I've just resolved to change it.
PS I sent out new seals to everyone so if you have the brown Viton one on the bushing change it out to the new black one as it will be easier to install. The Viton is harder making it more difficult.
It was mailed in a manila envelope.
Posted by: framos914 May 5 2020, 10:53 AM
Got the new seal in the mail but 2 days too late.
I did have a hard time installing the bushing with the brown seal.
Might have to do it again since a small piece of the brown seal got sheared off.
Lost just a small amount of oil, raised it high on passenger side and plugged the hole with a rag real fast. Make sure you have a pan or bucket underneath.
Posted by: Tdskip May 5 2020, 12:32 PM
I’m thinking we have a new challenge here – let’s see who can change it with the least amount of oil lost!
Posted by: infraredcalvin May 5 2020, 12:39 PM
Ok dumb question and no pics cause I’m at the office. Yesterday I got the package. It came with the new shaft with o rings (2) installed. There was a small rubber gasket also included.... where does that go? I don’t recall this coming out when I swapped my last shaft...
Posted by: porschetub May 5 2020, 01:36 PM
Ok so its basically a no go then ,I will just drain it ,fitted the 914rubber replacement seal but it hasn't lasted long.
Might do the cable also as I have a new one
Posted by: dax1969 May 6 2020, 02:22 AM
QUOTE(infraredcalvin @ May 5 2020, 08:39 PM)
![*](style_images/Howard/post_snapback.gif)
Got mine yesterday as well.... understood the wrong brown seal is on but Mark promised to send me one. In my package there was no small rubber gasket ... can you post a pic pls ? Do I need it ? Why are packages different ?
thks
Dax
Posted by: Mikey914 May 6 2020, 08:29 AM
That looks like black seal. the brown is really brown, and a distinctly different color. That would be why you only have the one. We corrected and just sent you what you need.
I'll post up pics today when I hit the shop
Posted by: infraredcalvin May 6 2020, 05:34 PM
This is the little guy I mentioned, it’s harder rubber.
Posted by: infraredcalvin May 6 2020, 05:37 PM
Now that I’ve got it in hand, assuming it goes like this, inside the bushing...
Posted by: SO.O.C914er May 6 2020, 06:55 PM
I have the brown one and still waiting to hear/see a replacement. My money is spent is sitting on my work bench.
Posted by: Mikey914 May 6 2020, 08:24 PM
QUOTE(infraredcalvin @ May 6 2020, 04:37 PM)
![Attached Image](http://www.914world.com/bbs2/uploads/post-9463-1588808260_thumb.jpg)
You are correct that is the orientation. The seal we put out that we sent the replacement on id the one that we added. The thin one.
Posted by: infraredcalvin May 6 2020, 09:29 PM
Installed! No drama, will check for leaks in the next few days...
Posted by: dax1969 May 7 2020, 12:27 AM
QUOTE(Mikey914 @ May 7 2020, 04:24 AM)
Mikey, in my package there was no such rubber
krgds
Dax
Posted by: 914e May 7 2020, 11:52 AM
QUOTE(Tdskip @ May 5 2020, 11:32 AM)
I was expecting to lose some but didn't lose any, because it was already over a quart low. I picked up gear oil last night to top it off. After I get it running again I plan on driving it around a few days then replacing the gear oil.
Posted by: porschetub May 7 2020, 03:14 PM
QUOTE(dax1969 @ May 7 2020, 06:27 PM)
krgds
Dax
How common is it for the lip seal to fail ?..thinking that could be my issue
![idea.gif](style_emoticons/default/idea.gif)
Posted by: Mikey914 May 7 2020, 03:42 PM
There is no lip seal in the OEM, so my answer is all of them have. It's a poor design, hence the additional seal we added.
Posted by: porschetub May 7 2020, 08:08 PM
QUOTE(Mikey914 @ May 8 2020, 09:42 AM)
Sorry but confused,not talking about O-rings but the small lip seal shown in the pic,are you saying that not fitted to the factory part and only to the one you sell?.
![beerchug.gif](style_emoticons/default/beerchug.gif)
Posted by: Mikey914 May 7 2020, 11:47 PM
Sorry my misunderstanding when you said lip seal I assumed you meant the o ring on the bottom that sits just inside the lip.
The internal seal can leak, for the most part they aren't under any real pressure, so not a bad call to change out every 70-100k.
