It looks like the PO installed the sway bar too low. And in so doing cut the frame. See pictures.
I’m not worried about installing a sway bar right now. But the frame - should I be worried about this? Drivable as is? Fix before putting it on the road?
Anybody have a picture of what it looks like with the proper sway bar installation in this area?
It looks like the swaybar is in the right place. Usually you notch the piece instead of cutting it out completely.
Here is a video
https://www.youtube.com/watch?v=l2-iOhb-4Gw
The hole for the bar should be just above the sheet metal that was cut out. It is hard to tell from the angle of the photos it looks like it might be a 1/4" low
Mounts look about an inch low.
It's there for a reason but it's not critical. I'd be OK with putting a few miles on it.
I would drive it until you are ready to go in and fix everything. Brad at 914ltd has a nice set of mounts that don't require the support to be notched. https://914ltd.com/parts/
Yep. Brad's mounts are what I used on my car (and in the video).
