Posted by: Psw1811 Jun 18 2020, 03:22 PM
I know the roof changed mid 1973 - I understand from chassis number 4732926221. Well my car is number 4732920086 - April 1973. My roof is missing but I’ve found a great condition late roof. My car has late doors so I’m guessing if I use all late seals I should be ok??? I’ve searched but there is no definitive answer. Mid 73 cars obviously had late doors but an early roof - so is it just seals that are different or are mid 73 cars a hybrid of early/late.
Posted by: bandjoey Jun 18 2020, 04:03 PM
http://www.914world.com/bbs2/index.php?showtopic=73129
all you need...
Posted by: Psw1811 Jun 18 2020, 04:14 PM
QUOTE(bandjoey @ Jun 18 2020, 04:03 PM)
all you need...
Hi, that’s what I’ve read but it doesn’t answer the question! It just confirms that some early 1973 cars had late doors and early roofs - what seals are they using?? Are early and late roof interchangeable with different seals? Late roofs don’t just match late doors - many people say the wrong roof won’t seal???! But what’s the wrong roof??????
Posted by: Mikey914 Jun 18 2020, 05:10 PM
They are interchangeable.
The seals have to be cut for the car they are installed on,
but they are the same profiles. So if cut to fit on another car, I would not expect them to fit your car precisely.
Also note that there was an early version of the targa to window seal that doesn’t have a wiper on the outside edge. Factory superseded this part to the one that seals better for a reason. We saw no need to duplicate an inferior seal.
You can see how this is an improvement by creating a 2nd barrier for water.
It just needs to be adjusted properly for your car.
If you really wanted the old profile you could carefully cut off the lip
Note this is shown with the front main targa seal not installed. It would normally but up against this end
Posted by: gtbarnes Jan 17 2021, 01:05 AM
QUOTE(Psw1811 @ Jun 18 2020, 02:14 PM)
all you need...
Nobody seems to know----The 2 tops are different here-The rear seal sides are different. one top has a flat area and the other style top has a deep molded channel for the seal sides. Which is what? Dont know
Posted by: bdstone914 Jan 17 2021, 01:21 PM
QUOTE(gtbarnes @ Jan 17 2021, 01:05 AM)
all you need...
In addition to the seal difference the rear latches and the rubber blocks which fit into them are different. Don't trust that they change at a particular VIN. My early 73 has late latches. The later tops have latches with shorter and more closely spaced locating bumps. The rubber blocks on the early tops are taller and more narrow blocks. I have not yet tried swapping the early and late latches and blocks to the different top to see if the fit is correct.
the second picture shows an early latch with a late block. This combination will cause the top to move side to side and squeak.
An early top on a late car will not fit into the locating blocks and sit high.
