I just converted my 914-6 gearbox (901 dogleg) from tail to side shift.
I have now to find a solution for the shift rods. What would you recommend?
Will it work if I am using the complete line (gearshift, front and rear shift rods) coming from a '73 model? What are the points of attention? Any hands-on experience?
Many thanks.
Philippe
use all of the late model stuff 73-76 straighten the rear rod to 39 inches, use a firewall conversion bushing and you will be all set
Excellent. Thank you George. What do you mean by strengthening the rear rod to 39"?
as suggested above
This was assembled from a 4cyl rear shift part with side shift ends welded on.
requires attention to clearance issues .....exhaust etc.etc.
I still do not understand why the rear shift rod needs to be straightened? Why the stock shift rod cannot be used without mods?
I guess that the answer is because of the headers (I am using 914-6 GT type of headers).
stock one cut and straight piece added
stock one cut and turned rewelded
http://www.914world.com/bbs2/index.php?showtopic=46166
I did what 6not4 illustrates in the 1st pic. Straight shot. Also welded in an Apex helo universal joint.
Thanks Folks. Very useful. I know what to do. Will give you an update once completed. Happy Sunday.
I have bought a lot of second hand gear shift rods for the 914. While I am pretty sure about the correctness of the rear shift rod, I have some doubts about the front one.
Does any of you have the exact length of the front shift rod (914-4 >'73)?
Many thanks in advance.
I made a fixture to do them.. Did one for @http://www.914world.com/bbs2/index.php?showuser=17736 and one for another member along with my car. They work really well and not a very convoluted setup
Have Ben make you one (mb911 or Tangerine Racing.
